07-07-2009, 14:51 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | Some one Point "Check LM1950t / CS 8240 power supply ICs" Please after search i found that the problem maybe in "LM1950t / CS 8240 power supply ICs" so please Some one Point me "Check LM1950t / CS 8240 power supply ICs" on this board |
07-08-2009, 01:25 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Hi, what kind of problem have you with the box? If you want info about LM1950T see http://www.alldatasheet.com BR |
07-08-2009, 08:25 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | Check LM1950t / CS 8240 power supply ICs" on this board http://rapidshare.com/files/25330352...mall_.jpg.html keep it up make cyclone 2 thanks |
07-09-2009, 10:44 | #5 (permalink) | |
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | Quote:
"Box Selftests Failed -> VPP Supply Voltage test failed, 0.04v is out of valid range" and Mr CycloneBox, thankfully gives the answer there so i don't know what is exactly the component he talks about but now i now it, thank you Mr "yasermalik" thank you all | |
07-09-2009, 16:08 | #6 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Hi see this posts, maybe you found your answer... My Cyclone PCB is like this : http://forum.gsmhosting.com/vbb/show...4&postcount=45 This is like yours, and have VPP mod: http://forum.gsmhosting.com/vbb/show...9&postcount=40 and here is an simple explanation how VPP are routed: http://forum.gsmhosting.com/vbb/show...9&postcount=61 BR |
3110c with power supply, power on is ok. but with battery can't power on. | unnang | Nokia Hardware & Hardware Repair | 16 | 02-10-2013 13:28 |
Please help -> Accidentally used high voltage on power supply | ham_sang | Nokia Hardware & Hardware Repair | 2 | 01-16-2009 16:31 |
My X5 Wont power with battery but power on with power Supply | GSM SNIPER | Sagem Hardware Repair Area | 2 | 04-28-2006 22:14 |
C55 powered by power supply instead of battery | Otik | E-Gold Based Phones | 2 | 11-10-2003 11:20 |
R310 after change power supply can power on, but only 2 seconds dead back | genocite | Sony Ericsson Hardware Repair | 4 | 01-28-2003 17:21 |
