07-09-2009, 23:10 | #1 (permalink) |
Freak Poster Join Date: May 2005
Member: 144806 Status: Offline Thanks Meter: 22 | Tma help to convert to 10 pin mt cables i have new cyclone box now Fully Working this Time and im looking to convert my TMA to work With MT 10 pin Cables is this possible and how can i convert it So that my 10 pin Mt Cables Can Work Via My TMA this has to me a Way to convery this TMA With REWIREING PLEASE POST REPLYs If Anyone have Already Solver this Prob Thne Post the Pic thanks WideOn New Cyclone User |
07-10-2009, 08:41 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Is a quite easy modify as you won't use the 10pin MT plug.. Just modify the connection of the 10 pin Plug in this mode... deconnect pin 10 and 2 from the input and connect the wire of the pin 2 where was originally the pin 10 (for the version with USB cable add a diode to prevent box errors) connect directly the unused pin 3 to the pin 2 if the tma you have has the USB cable move the positive (+) from the pin 2 to the pin 10 as well use it without the TX2 adapter. BR Alex |
07-10-2009, 08:59 | #4 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Important!!! If the tma you have has the USB cable and you move the positive (+) from the pin 2 to the pin 10 the USB cable won't work any more with the JAF cables!!! BR Alex |
07-10-2009, 10:39 | #5 (permalink) |
Member: 144806 Status: Offline Thanks Meter: 22 | so please explane how i can use 10 pin cables i have a full set of 10 pin MT cables so what mod can i do on the TMA and then the 10 pin cables Will Work Please Explane With Pics if possible thanks |
07-10-2009, 14:25 | #6 (permalink) | ||
Freak Poster Join Date: Apr 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 258446 Status: Offline Thanks Meter: 26 | Quote:
pin 10 (violet wire removed dont use) pin 2 ( red wire transfer to the place of the violet wire pin 10) pin 3 ( yellow wire connect to original place of red wire pin 2) dont use anymore the add on usb plug | ||
07-10-2009, 16:11 | #8 (permalink) | |
TMA have RJ48 10pin and RJ45 8pin modify RJ48 10pin connection stated above can use to MT cables RJ45 8pin no modify for JAF/UFS cable also RJ48 10pin no modify the problem here in cyclone VPP pinout program only VPP while in JAF VPP for DCT4 and TX2 in BB5 share same pin, its a cable mess for this new box that is why they use a TX2 adapter. maybe bb5 ok not DCT4 refer to this links pinouts of every box for reference. http://forum.gsmhosting.com/vbb/show...ht=tx2+adapter | |
07-10-2009, 20:02 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | If he does the modify on the 10 pin section of tma he can use always the MT cables on DCT4 and BB5 without any problem as the pinouts is always the same... The tx2 adapter is to fix a bad use of the old boxes (Jaf and HWK) which were using the pin 8 as VPP in the dct4 and as TX2 in the BB5.. obviously Cyclone as all the new generation box has always the same pinout as MT does. So no worries.. just modify the 10 pin side and you MT-Box cables will be ok.. if you connect instead the 8 pin connector you will have full compatibility with the jaf cables (And you will need the TX2 adapter when you work with the BB5 mobiles with the Jaf cable) BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
07-10-2009, 21:41 | #10 (permalink) |
Member: 144806 Status: Offline Thanks Meter: 22 | so just 3 wires to change in the TMA what i was looking on the Forums and i see the TX and RX are the wrong way round on the stuff so i mod them 3 wire then i can use MT 10 Pin Cables Brilliant |
Need Nokia 7100 supernova pinout for 10 pin MT box cable... | Spalato | Genie Universal | 1 | 01-09-2010 18:11 |
10 pin mt cables adapter | trabant gti | Cyclonebox | 9 | 05-23-2009 05:11 |
where can i get 10 pin n95 cable to buy? | gorgans | MT-BOX | 4 | 07-17-2007 12:35 |
Cable converter -Prodigy 10 pin to UFS 8 pin... | omega_plus | UFS2 + UFS3-Tornadoflasher | 2 | 03-28-2006 09:44 |
