06-20-2010, 19:12 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: INDIA
Member: 1170625 Status: Offline Sonork: 100.1616527 Thanks Meter: 94 | 1661 Content extract fail (ANSWERED) logs here Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rh122_005.010 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0098DCA7:2984DA60 Area [01000000-0100FFFF] erased in 0.828 s Area [01010000-0179FFFF] erased in 1 min 35.718 s Area [017A0000-017EFFFF] erased in 4.234 s Area [01F00000-01FDFFFF] erased in 0.453 s Flash programming ... Programming completed in 19.125 s File Processed in 2 min 11.359 s Processing file: rh1220_nai05.01mn as CNT [DCT4,DCT4 ALGORITHM] size: 142.60 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0098DCA7:2984DA60 Area [01750000-0178FFFF] erased in 3.297 s Flash programming ... Programming completed in 1.235 s Content extract fail, continue anyway ... File Processed in 53.453 s Processing file: rh122_005.01mn as PPM [DCT4,DCT4 ALGORITHM] size: 3.77 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0098DCA7:2984DA60 Area [01250000-0125FFFF] erased in 0.828 s Area [01260000-0174FFFF] erased in 1 min 2.609 s Flash programming ... Programming completed in 30.359 s File Processed in 1 min 44.828 s Flashing completed in 4 min 49.766 s Phone not responding ! Total time to process is 5 min 19.313 s |
06-21-2010, 10:12 | #3 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh
Member: 1220933 Status: Offline Sonork: 100.1590184 Thanks Meter: 471 | prother this is hardware problem! 1. just re-hot upp/ cpu and re-solder or re-bull it 2. or, changed it note: by rehooting most of phone comeback from this problem! |
06-23-2010, 07:51 | #5 (permalink) |
Junior Member Join Date: Apr 2009 Location: india
Member: 1021169 Status: Offline Thanks Meter: 1 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012A3BDA66 ASIC type: 11 UEM Imei: 35799703589038 Processing file: rh122_003.360 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012:2984DA60 Area [01000000-0100FFFF] erased in 0.422 s Area [01010000-0179FFFF] erased in 47.468 s Area [017A0000-017EFFFF] erased in 2.063 s Area [01F00000-01FDFFFF] erased in 0.375 s Flash programming ... Programming completed in 19.234 s File Processed in 1 min 18.640 s Processing file: rh1220_nai03.36ia as CNT [DCT4,DCT4 ALGORITHM] size: 184.49 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012:2984DA60 Area [01760000-0179FFFF] erased in 1.594 s Flash programming ... Programming completed in 1.500 s Content extract fail, continue anyway ... File Processed in 33.204 s Processing file: rh122_003.36ia as PPM [DCT4,DCT4 ALGORITHM] size: 2.74 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012:2984DA60 Area [01240000-0125FFFF] erased in 0.781 s Area [01260000-0175FFFF] erased in 31.375 s Flash programming ... Programming completed in 22.203 s File Processed in 1 min 5.438 s Flashing completed in 4 min 18.344 s Phone not responding ! Total time to process is 4 min 47.500 s how can i solve this rply plz its urgent. |
06-23-2010, 07:52 | #6 (permalink) |
Member: 1021169 Status: Offline Thanks Meter: 1 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012A3BDA66 ASIC type: 11 UEM Imei: 35799703589038 Processing file: rh122_003.360 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012:2984DA60 Area [01000000-0100FFFF] erased in 0.422 s Area [01010000-0179FFFF] erased in 47.468 s Area [017A0000-017EFFFF] erased in 2.063 s Area [01F00000-01FDFFFF] erased in 0.375 s Flash programming ... Programming completed in 19.234 s File Processed in 1 min 18.640 s Processing file: rh1220_nai03.36ia as CNT [DCT4,DCT4 ALGORITHM] size: 184.49 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012:2984DA60 Area [01760000-0179FFFF] erased in 1.594 s Flash programming ... Programming completed in 1.500 s Content extract fail, continue anyway ... File Processed in 33.204 s Processing file: rh122_003.36ia as PPM [DCT4,DCT4 ALGORITHM] size: 2.74 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CB6012:2984DA60 Area [01240000-0125FFFF] erased in 0.781 s Area [01260000-0175FFFF] erased in 31.375 s Flash programming ... Programming completed in 22.203 s File Processed in 1 min 5.438 s Flashing completed in 4 min 18.344 s Phone not responding ! Total time to process is 4 min 47.500 s |
02-08-2011, 15:44 | #14 (permalink) |
No Life Poster Join Date: Jul 2007 Location: kolkata, india
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | I think its cpu ic problem , reball the cpu>> But first of all download latest version of firmware pack and flash it..... my problem solved with latest version software flashing..... |
MCU EEPROM contents: failed | phr3ak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-12-2001 15:58 |
3210-EEPROM OK-ALL 4 LOCKS closed showing content EEEEE / FFFF | JohnDoe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-02-2000 21:04 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
