Old 03-04-2010, 09:31   #1 (permalink)
md jawad's Avatar
Member: 729723
Thanks Meter: 211
2700 SECURITY_TEST failed!
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.80 02-12-09 RM-561 (c) Nokia
Imei plain: 35826203908127-2
Product Code: 0579811
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 358262039081272
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to md jawad For This Useful Post:
Old 03-04-2010, 09:33   #2 (permalink)
bk.gsm's Avatar
Member: 869809
Thanks Meter: 1,709
write good pm to the phone your problem will be solved
b.r.
Old 03-04-2010, 09:34   #3 (permalink)
Member: 690327
Thanks Meter: 17
Write PM field 1 and 309 only
Old 03-04-2010, 09:39   #4 (permalink)
kidgz's Avatar
Member: 551599
Thanks Meter: 139
pm auth then write pm 1-309 only
Old 03-04-2010, 09:42   #5 (permalink)
md jawad's Avatar
Member: 729723
Thanks Meter: 211
i want 2700 gud pm ....where i get
Old 03-04-2010, 09:45   #6 (permalink)
Member: 757799
Thanks Meter: 782
2700 is pure SL3 i think its not supported atm on mxkey
Old 03-04-2010, 09:48   #7 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
wahhehehe i think 2700 is sl3 not yet supported at this moment
br
Old 03-04-2010, 09:56   #8 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
yea simlock not supported but u can repair security test failed. just first of all Do SX4 than PM1 and PM309
if no success than
b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process
before any operation save backup
Old 03-04-2010, 10:03   #9 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
make simlock repair then write pm1 and pm 309 try that in rpl mx key release
Old 03-04-2010, 11:04   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
phone have this error
SIMLOCK_TEST passed
can be repair with
SX-4 and write PM with out [308] and [120] area
br,
2700 flash faile huong2 Nokia Base Band 5 ( BB-5 ) 2 03-03-2010 22:18
7210c show SECURITY_TEST failed! aukonline MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 02-13-2010 13:39
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! mohit_kripalu01 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-06-2010 11:36
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-03-2010 15:58
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! Raven21 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 01-27-2010 08:15
Page generated in 0.17127 seconds with 9 queries
