09-13-2010, 12:12 | #1 (permalink) |
Registered User Join Date: Dec 2006 Location: punjab india
Member: 419331 Status: Offline Thanks Meter: 101 | after sd repair SECURITY_TEST failed! 3110c Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Elapsed: 3.485 s (session timeout out after 3 second) what i do now |
09-13-2010, 12:23 | #3 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | Quote:
go to pm section and tick on load rfbb from server and super sd auth after phone goes to server click on write pm .. tested . | |
09-13-2010, 12:57 | #7 (permalink) | |
No Life Poster Join Date: May 2008 Location: Bermuda Triangle
Member: 776382 Status: Offline Thanks Meter: 105 | 100%%% solution for security test failed Quote:
SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...) Now all SD repair should work well. Here is general repair procedure. It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....). It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones. 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here: RapidShare: 1-CLICK Web hosting - Easy Filehosting | |
The Following User Says Thank You to kfkevin For This Useful Post: |
09-13-2010, 13:24 | #9 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | |
09-13-2010, 13:32 | #10 (permalink) |
Member: 419331 Status: Offline Thanks Meter: 101 | i find it problam my phone working fine i do this proceser 1.Go to tab 'imei & security' press 'Recover Cert' 2.Go to tab 'PM' Make 'Super SD auth' then write pm 1 and 309 thanks all who reply |
The Following User Says Thank You to SHARMA NEERAJ For This Useful Post: |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
