Old 04-08-2010, 07:41   #1 (permalink)
Member: 744438
Sonork: 100.1640287
Thanks Meter: 279
1200 Imei ???????????4 plz help mx teem
i have a set nokia 1200 with imei ??????????4
when i press online logger>dct4plus imei>do selected job
its show
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 00C53FEBA3BDA66
ASIC type: 11
UEM Imei: 35352602150767
Connecting to server ...Socket error (10060): Connection timed out
Or
Connecting to server ...OK, Login ...
then not responding affter that
Old 04-08-2010, 07:48   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
try manual u get sucsess.............
Old 04-08-2010, 08:11   #3 (permalink)
Member: 744438
Sonork: 100.1640287
Thanks Meter: 279
Manual
i tried manual but show this error
Programming FLASH Imei ...
FLASH programmed successfully.
warning: For UEM write, VBAT needs to be atleast: 5.2V
Programming UEM Imei
(OTP) ...failed
Operation done with error.
Old 04-08-2010, 09:06   #4 (permalink)
babloojaved's Avatar
Member: 890104
Sonork: 100.1597567
Thanks Meter: 138
(OTP) ...failed
Try to write with jaf or hwk after creating IMEI in mxkey..
i have also get same problems but solved with above.
thanks
Old 04-08-2010, 10:01   #5 (permalink)
Member: 744438
Sonork: 100.1640287
Thanks Meter: 279
thanks
Power on the phone...
Reading imei...
Opening RPL file...
Inspecting...
IMEI: 35352602150767
Booting phone...
MCU ID: 0x2292
Sending algo...
Algo is ready...
Writting UEM...
Error writting uem...
Old 04-08-2010, 10:48   #6 (permalink)
Member: 644616
Sonork: 100.1608012
Thanks Meter: 257
(OTP) ...failed
bro tick manual put ur imei n select asic11 press do job
take care
Old 04-08-2010, 10:49   #7 (permalink)
Member: 291071
Sonork: 100.1663377
Thanks Meter: 18
use ufs hwk free rpl genrator
The Following User Says Thank You to sagheer For This Useful Post:
Old 04-08-2010, 11:18   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
when write new UEM have
Programming UEM Imei (OTP) ...failed
put 5.2V in your phone VBAT betray
then retry your operation
br,
NOKIA 3110c imei 12345610654321? plz help abi.m Cyclonebox 8 04-08-2010 05:34
plz help mx-key team(1209 UEM imei empty) debapra_gsm Nokia Hardware & Hardware Repair 0 03-09-2010 11:13
(7210c phone will reboot itself after 3 min) plz help mx-key teem................. shahinur MXKEY Nokia Flasher and Unlocker (by Alim Hape) 12 02-04-2010 13:09
1200 imei????????????????4 help me csm world Nokia Hardware & Hardware Repair 3 12-16-2008 18:36
1110i imei ????????????????4 plz help shivamobiles Nokia Digital Core Technology 4 ( DCT-4 ) 0 07-25-2008 16:54
Page generated in 0.24291 seconds with 9 queries
