Old 11-17-2009, 19:03   #1 (permalink)
Member: 72341
Thanks Meter: 7
N90 only nokia help !
i have an n90 phone that shows only nokia at screen ....and when i want to flash it with mx key says bootstrap failed .....what should i proceed now ?
Version from phone: 05wk07v28
Version from file: RM42.C0
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.10913, Date: 05-11-2009
Read Certificate failed.
NPC_DATA is empty.
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to ".rpl"
Processing file: 5060773_RM42.C0 as MCU
[BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 31.35 MB
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200
Supported APE Ids: 17100701, 17100702
Bootstrap failed!
Flashing terminated with error(s) in 1 min 11.797 s
RX Buffer:
Old 11-17-2009, 19:10   #2 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Bro try to flash with ufs.I hope ur prob. will be solved
Old 11-17-2009, 19:41   #3 (permalink)
Member: 72341
Thanks Meter: 7
same with ufs :
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Boot error: 02 FF 72 00
UPP not responding !
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
NPC_DATA is empty.
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to ".rpl"
Bootstrap failed!
Flashing terminated with error(s) in 1 min 7.890 s
RX Buffer:
Old 11-17-2009, 21:07   #4 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
bro fist chek ur cable and flash wid latest version.....if problem not solve then uninstall ur mxkey setup and also delete ur mx key folder from c: drive then install mx key setup again......then flash it
ak
Old 11-18-2009, 00:01   #5 (permalink)
Member: 72341
Thanks Meter: 7
i have 3 diferent cables bro its the same
Old 11-18-2009, 00:45   #6 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
mate use hwk surly il will solve your problem with flashing
Nokia n73-1 after flash only nokia logo. Please help ! Unlocker_001 HWK 16 03-07-2013 07:10
nokia 1208 only nokia disply and stope plz helpe meeee kashig Nokia Hardware & Hardware Repair 5 01-09-2010 13:43
6233 Only Nokia.....Help snisar Nokia Hardware & Hardware Repair 4 09-11-2009 15:27
6600 only nokia help me shivam4you Nokia Hardware & Hardware Repair 7 08-06-2009 13:55
help experts nokia 6680 only nokia logo rippysingh Nokia Hardware & Hardware Repair 9 06-15-2008 12:26
Page generated in 0.15230 seconds with 9 queries
