Old 03-03-2010, 13:58   #1 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
Question n96 phone startup failed contact retailer
hi
i have 2 n96 phones in that problem.
here is 1st log
Version Info:
MCU SW version: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia
HW version: 1050
RFIC version: 17141715
Tahvo version: 16
APE HW version: 22
Product Info:
Product code: MRE210820
Module code: 0543713
Long production SN: 0
Serial Numbers:
IMEI plain: 359320024861329
IMEI spare to net: 3A 95 23 00 42 68 31 02
IMEI SV to net: 33 95 23 00 42 68 31 02 F6
Other Info:
Model : Nokia N96-1 (Classic Phone)
CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII
BSI: 6.7 KOhm
Imei net: 359320024861329
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
plz complete guide that how i repair that phone
Old 03-03-2010, 14:21   #2 (permalink)
Member: 579426
Thanks Meter: 4
i have same prob with 2 phone
n85 & n96
here is n85
Phone Type: RM-333 (Nokia N85)
SW Version: V ICPR72_08w44.1 10-11-08 RM-333 (c) Nokia
Imei plain: 35637602553405-2
Product Code: 0575404
ApeCoreSw: 11.047
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2008-12-04T09:59:34+00:00
SW Version: 11.047
Variant Version: 001
ProductProfile: RM333_0575404_11.047_001.spr
Simlock: simlock_3gstandard_bb5.bin
Imei net: 356376025534052
Counter: 0/3, 0/10
and here is n96
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 35932002460070-1
Product Code: 0543722
Language Pack:
- not available.
SIMLOCK_TEST passed
TimeStamp: 2009-06-18T13:39:11+00:00
SW Version: 30.033
Imei net: 359320024600701
Counter: 0/3, 0/10
after powering up the phones , the n96 show phone sturtup failed on the screen and n85 terned of after shown nokia logo
anybody can enplane me how to repair this two phnes ?
Old 03-03-2010, 14:30   #3 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
n85 & n96
here is n85
ApeCoreSw: 11.047
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 11.047
Counter: 0/3, 0/10
and here is n96
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 30.033
Counter: 0/3, 0/10
after seeing ur phone logs both log are okay ...
but regarding ur problem ..
first upgrade the firmware of ur phone ...
if then it is not solve then it may be due to hardware...
in hardware try to change avilma ic....
post result.....
The Following User Says Thank You to digitized For This Useful Post:
Old 03-03-2010, 14:37   #4 (permalink)
software zone's Avatar
Member: 494167
Thanks Meter: 292
n85 & n96
here is n85
ApeCoreSw: 11.047
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 11.047
Counter: 0/3, 0/10
and here is n96
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 30.033
Counter: 0/3, 0/10
try sx4 autho and write pm.then chick
The Following User Says Thank You to software zone For This Useful Post:
Old 03-03-2010, 14:53   #5 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
can any one upload tested pm.??????????????
Old 03-03-2010, 14:58   #6 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
@shami
Self test and post logs, maybe security test failed,
Best Regards,
JAVA Good.
Old 03-03-2010, 15:06   #7 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
Question n96
Originally Posted by JAVA Good View Post
@shami
Best Regards,
JAVA Good.
ok
i m posting its log within few minuites
Old 03-03-2010, 15:07   #8 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
http://forum.gsmhosting.com/vbb/showthread.php?t=941480
Old 03-03-2010, 15:10   #9 (permalink)
Member deceased !!
Mohsin Ali S's Avatar
Member: 390175
Thanks Meter: 19
Post the Bus Check LOgs Plz for better help
Old 03-03-2010, 15:15   #10 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
@shami
Best Regards,
JAVA Good.
agree u bro~i think have 90% is security test failed,please post self test log~
Old 10-09-2010, 12:14   #11 (permalink)
Member: 1279141
need help please,
Flashing finalization failed. Do you like to retry the finalizing?
HRESULT 0x8421001c (-2078212068)
Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry.
Old 10-09-2010, 12:50   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Originally Posted by manilu View Post
need help please,
repeat flashing, by using latest firmware version available.
Old 10-09-2010, 12:58   #13 (permalink)
Member: 1134037
Thanks Meter: 18
Use Enable Rfbb server tick then Select Write ........tnx
Old 10-09-2010, 13:02   #14 (permalink)
Member: 1279141
where to find latest firmware, thx
Old 10-09-2010, 13:13   #15 (permalink)
Member: 1279141
found one, i don't understand this -> Use Enable Rfbb server tick then Select Write ........tnx
N96.. Phone Startup fail...contact retailer Waseem-y MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 01-09-2010 09:55
Repair....phone Startup Failed Contact Retailer krusty.spritz Nokia Base Band 5 ( BB-5 ) 0 05-16-2007 18:41
Nokia 6600 Phone Startup Failed Contact Retailer ktelecom WD2 & APE (Symbian Phones) 16 05-01-2007 11:55
n70 phone startup fail contact retailer fast_alex1123 Nokia Base Band 5 ( BB-5 ) 5 03-08-2007 21:21
Page generated in 0.22584 seconds with 9 queries
