07-27-2011, 12:10 | #3331 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Balochistan
Member: 952072 Status: Offline Sonork: 100.159775 Thanks Meter: 107 | Secessfull flash Nokia 6230i Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: uhci:hub:UFS2XX, ver: 1.6.6.0 , NTMP ver: 1.6.6.1 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 004E3BDA:3B8ADA60 ASIC type: 6 UEM Imei: 35882700311195 Flash Imei: 35882700311195 RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35882700311195_BA CK.rpl" Processing MCU file: rm72_73_11003.890 [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 004E3BDA:977ADA60 Area [00000000-0000FFFF] erased in 0.516 s Area [00010000-009FFFFF] erased in 1 min 25.765 s Area [00A00000-00B3FFFF] erased in 10.734 s Area [00B60000-00FAFFFF] erased in 36.359 s Flash programming ... Programming completed in 2 min 21.734 s File Processed in 4 min 53.281 s Processing CNT file: rm72_73_110M_03.89.ucp_e [TIKU BT2,TIKU MON CSM] size: 3.98 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Programming completed in 1 min 12.281 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.750 s File Processed in 2 min 16.093 s Processing PPM file: rm72_73_110M_03.89e [TIKU BT2,TIKU MON CSM] size: 4.74 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Programming completed in 1 min 38.890 s File Processed in 1 min 56.828 s Total time for flashing process(boot+erase+write) was 9 min 6.218 s Phone Type: RM-72 (Nokia 6230i) SW Version: V 03.89 7-Mar-07 RM-72 GSM P1.1 (c) NMP. Imei plain: 35882700311195-6 Imei OTP: 35882700311195 Product Code: 0522069 Cellular System: GSM ASIC ID: 0x2051, type: 6 Ppm Id: E Language Pack: English,German,Lithuanian,Latvian,Russian,Estonian ,Bulgarian,Romanian,Ukrainian Imei net: 35882700311195 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000006 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
08-01-2011, 09:33 | #3334 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 7610s Flash done Code: MXKEY Serial: [FT SCR2000 0] - ********** Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: uhci:hub:hub:UFS2XX, ver: 3.1.5.0 , NTMP ver: 2.4.16.0 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11773(23-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0BB00109F4E558503A55A85128E98652BB126B19 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: B8DE3D7D6082E003C97C849AB11191FAF7F48056 TransmissionMode: DDR&TX2 Processing MCU file: rm354__07.23.mcusw [BB5,BB5 ALGORITHM] size: 21.36 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 22.37 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-014DFFFF] CMT FLASH,NOR area [014E0000-0167FFFF] erased in 57.953 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: B8DE3D7D [RAP Certificate 113 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 11 min 58.109 s Processing PPM file: rm354__07.23.ppm_ma [BB5,BB5 ALGORITHM] size: 6.15 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01680000-01F1FFFF] erased in 18.828 s Flash programming ... Programming completed in 3 min 41.641 s Processing CNT file: rm354__07.23.image_ma [BB5,BB5 ALGORITHM] page size: 128 K size: 9.51 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 32.62 MB CMT FLASH,NOR area [01F20000-022BFFFF] CMT FLASH,NOR area [022C0000-03FBFFFF] erased in 1 min 32.937 s Flash programming ... Programming completed in 4 min 58.875 s Total time for flashing process(boot+erase+write) was 23 min 38.750 s Phone Type: RM-354 (Nokia 7610 Supernova) SW Version: V 07.23 17-07-09 RM-354 (c) Nokia Imei plain: 3563880*****03-3 Product Code: 0563011 Battery voltage: 4866 mV, current: 58 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3563880*****033 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
08-06-2011, 07:58 | #3335 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 37
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | 2720a Imei net: 35627504755917 Version: SIMLOCK SERVER Provider: Vodafone Espaņa, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=CLOSED(MCCMNC), DATA=21401F [Spain-Vodafone Espaņa, SAU ] Calculating SIMLOCK RPL ... Rpl backup saved to "C:\mobileEx\3.5\data\backup\RM-519_35627504755917_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35627504755917 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
08-08-2011, 07:43 | #3336 (permalink) |
Insane Poster Join Date: May 2011 Location: Lebanon, Akkar
Member: 1574196 Status: Offline Thanks Meter: 9 | n70-1 RM:84 not booting completly but boot to nokia logo & not flashing plz help me[IMG]C:\Users\power\Pictures[/IMG], |
The Following User Says Thank You to MDH_2011 For This Useful Post: |
08-08-2011, 07:46 | #3337 (permalink) |
Member: 1574196 Status: Offline Thanks Meter: 9 | MXKEY Serial: [FT SCR2000 0] - C0851A9A Using device: AdvanceBox Turbo Flasher Driver: ehci:hub:ccgp:FTDIBUS, ver: 2.6.0.0 , NTMP ver: 2.6.2.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000352 PUBLIC ID: 16000118A15154510F7F15FA0198CA4C6ED59CFA ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 Storage0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 Original Imei: 35455101116308 Original Product code: 0539240 Bluetooth ID: 001A8900CD08 Phone not responding ! |
08-08-2011, 07:48 | #3338 (permalink) |
Member: 1574196 Status: Offline Thanks Meter: 9 | n70-1 RM:84 not booting completly but boot to nokia logo & not flashing plz help me MXKEY Serial: [FT SCR2000 0] - C0851A9A Using device: AdvanceBox Turbo Flasher Driver: ehci:hub:ccgp:FTDIBUS, ver: 2.6.0.0 , NTMP ver: 2.6.2.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000352 PUBLIC ID: 16000118A15154510F7F15FA0198CA4C6ED59CFA ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 Storage0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 Original Imei: 35455101116308 Original Product code: 0539240 Bluetooth ID: 001A8900CD08 Phone not responding ! |
08-08-2011, 07:54 | #3339 (permalink) |
Member: 1574196 Status: Offline Thanks Meter: 9 | n70 not flashing , not scanning: plz hlp me AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01002200 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000352 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16000118 ID DWORD 1 : A1515451 ID DWORD 2 : 0F7F15FA ID DWORD 3 : 0198CA4C ID DWORD 4 : 6ED59CFA 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : CEA7B19D Checksum A0 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv2_2nd.fg Boot File - Version 01.021.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 2250 -> K8S6415ETB Extended/Fixed ID : 0000 Revision ID : 0121 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 20 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :2250 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 2250 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00800000 (8 MB) VPP Info : 0009 Erase10s : 0F Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ============================================ OLD Protocol Detected... Using Turbo Mode... ============================================ Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= FlashInfo.RestartMode : 2 ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... Last edited by MDH_2011; 08-08-2011 at 08:00. |
08-08-2011, 10:58 | #3340 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | nokia 5220 flashed by usb Code: MXKEY Serial: [FT SCR2000 0] - C080066C Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm411__07.23.mcusw [BB5,BB5 ALGORITHM] size: 19.92 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 73747B3 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 02F0000D97DE5550EFA2A626F5DB67F3690E5687 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AF40 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1AC14B80 Verifying communication to device OK. Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.578 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.625 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.422 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.093 s CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 31.328 s CMT FLASH,NOR area [01380000-0151FFFF] erased in 8.156 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: D93826B2 [RAP Certificate 130 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 7.234 s Processing PPM file: rm411__07.23.ppm_mr [BB5,BB5 ALGORITHM] size: 7.20 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 42.579 s Flash programming ... Programming completed in 24.469 s Processing CNT file: rm411__07.23.image_mr_in_red [BB5,BB5 ALGORITHM] page size: 128 K size: 9.89 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 24.531 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 40.062 s Flash programming ... Programming completed in 36.453 s Total time for flashing process(boot+erase+write) was 9 min 3.719 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 5220 XpressMusic USB Phonet, PORT_ID: 1375BD50 Verifying communication to device OK. Phone type: RM-411 (Nokia 5220 XpressMusic) SW version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: 35366201305911-8 Product code: 0563611 Battery voltage: 3409 mV, current: 73 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353662013059118 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
08-09-2011, 14:16 | #3342 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | c1-01 flashing done Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 27.906 s Checksum verified (0x2ED4) Processing file: rm607__05.50.ppm_mh Downloading item CUSTackage_mh.ppm_ebl_psi.fls, num block: 1, size: 3.83 MB Erasing area 0x41C00000-0x41FD494E ...OK Programming completed in 4.703 s Checksum verified (0x420F) Processing file: rm607__05.50.image_mh_059B0Z6 Downloading item CUSTackage_mh_059B0Z6.image.fls, num block: 1, size: 12.50 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 15.078 s Checksum verified (0xF19D) Total time for flashing process(boot+erase+write) was 3 min 8.453 s Waiting for device boot up ... Device found: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 182BE69C Verifying communication to device OK. Phone Type: RM-607 (C1-01) SW Version: V 05.50 08-07-11 RM-607 (c) Nokia Imei plain: 35702104157783-9 Product Code: 059B0Z6 Battery voltage: 3795 mV, current: 107 mA Language Pack: - not available. Imei net: 35702104157783 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
08-11-2011, 10:20 | #3343 (permalink) |
Registered User Join Date: Mar 2005 Location: kolkata , india Age: 41
Member: 128335 Status: Offline Thanks Meter: 8 | Nokia 5233 done sucessfully MXKEY Serial: [FT SCR2000 0] - C****** Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.62 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35338504410553_PM .rpl). Processing MCU file: RM-625_50.1.001_prd.core.C00 [BB5,XSR 1.6] size: 95.73 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Battery voltage: 3805 mV Version from phone: Version from file: 50.1.001 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1648171D CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 18E00113BB970052C3DB621B23940AFCA674AAD5 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 26.532 s Processing PPM file: RM-625_50.1.001_prd.rofs2.V21 [BB5,XSR 1.6] size: 12.04 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 36.50 MB CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 11.297 s Processing PPM file: RM-625_50.1.001_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 5.797 s Processing CNT file: RM625_50.1.001_000_000_U001.uda.fpsx [BB5,XSR 1.6] size: 17.05 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 17.157 s Total time for flashing process(boot+erase+write) was 3 min 0.719 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 1A516B8D Verifying communication to device OK. Phone type: RM-625 (Nokia 5233) SW version: V ICPR72_11w10.3 24-03-11 RM-625 (c) Nokia Imei plain: 353********************* Product code: 0594743 Battery voltage: 3797 mV, current: 310 mA ApeCoreSw: V 50.1.001 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353385044105532 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia USB ROM disconnected. |
08-11-2011, 15:45 | #3344 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Again 6303 flashed by usb Code: MXKEY Serial: [FT SCR2000 0] - C080066C Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm443__10.12.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3D14CF0 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 16A0010D29336850A64AE0193CC63D6A52A82D7D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 175B50BD Verifying communication to device OK. Erase size: 28.25 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.594 s CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.609 s CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.516 s CMT FLASH,NOR area [00080000-0015FFFF] erased in 4.234 s CMT FLASH,NOR area [00160000-0023FFFF] erased in 3.844 s CMT FLASH,NOR area [01740000-0191FFFF] erased in 9.109 s CMT FLASH,NOR area [00240000-0173FFFF] erased in 1 min 43.266 s CMT FLASH,NOR area [022E0000-0261FFFF] erased in 15.969 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 1 min 28.578 s Processing PPM file: rm443__10.12.ppm_mr2akash [BB5,BB5 ALGORITHM] size: 7.08 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT FLASH,NOR area [01920000-022DFFFF] erased in 47.657 s Flash programming ... Programming completed in 25.516 s Processing CNT file: rm443__10.12.image_mr_in_matt_black [BB5,BB5 ALGORITHM] page size: 128 K size: 10.64 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 25.62 MB CMT FLASH,NOR area [02620000-029BFFFF] erased in 24.578 s CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 2 min 30.547 s Flash programming ... Programming completed in 38.047 s Total time for flashing process(boot+erase+write) was 9 min 18.953 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 35BBFE8B Verifying communication to device OK. Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35933303734937-2 Product code: 0568484 Battery voltage: 3783 mV, current: 70 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359333037349372 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
08-12-2011, 11:04 | #3345 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | Again 7210 flashed by usb Code: MXKEY Serial: [FT SCR2000 0] - C080066C Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2CB26652 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0D700118E3D65850CB415ABECEB768C45B99157B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 4A1A018 Verifying communication to device OK. Erase size: 19.12 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.609 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.609 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.469 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.047 s CMT FLASH,NOR area [00140000-0119FFFF] erased in 1 min 20.203 s CMT FLASH,NOR area [011A0000-0133FFFF] erased in 7.609 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: F1DCA5EA [RAP Certificate 142 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 2.110 s Processing PPM file: rm436__07.23.ppm_mrakash [BB5,BB5 ALGORITHM] size: 7.03 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01340000-01BDFFFF] erased in 38.406 s Flash programming ... Programming completed in 23.750 s Processing CNT file: rm436__07.23.image_mr [BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 35.87 MB CMT FLASH,NOR area [01BE0000-01F7FFFF] erased in 21.719 s CMT FLASH,NOR area [01F80000-03FBFFFF] erased in 3 min 24.625 s Flash programming ... Programming completed in 27.547 s Total time for flashing process(boot+erase+write) was 8 min 45.953 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 7210 Supernova USB Phonet, PORT_ID: 18B170B Verifying communication to device OK. Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35196203203059-1 Product code: 0572571 Battery voltage: 3715 mV, current: 71 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351962032030591 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
