![]() | #3376 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: SOUSSE / TUNISIA - 21959153 Age: 44
Member: 145225 Status: Offline Thanks Meter: 98 | 2630 Version: SIMLOCK SERVER Provider: S.F.R. , Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2081000000000000 PROFILE_BITS: 800000000001000B BLOCK1: 1=CLOSED(MCCMNC), DATA=20810F [France-S.F.R. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=64710F [French Departments and Territories in the Indian Ocean-Société Réunionnaise du Radiotéléphone ] Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 [CR1]DCT4PLUS remaining credit: 14 Rpl backup saved to "C:\mobileEx\3.5\data\backup\RM-298_35206802890482_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35206802890482 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.688 s |
![]() | #3377 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | 2700c MXKEY Serial: [FT SCR2000 0] - C0820E19 Driver: NMWCD, ver: 7.1.32.66, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: rm561__09.97.mcusw [BB5,BB5 ALGORITHM] size: 19.41 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1F4FB99 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 282001041C85635068691CCEDCE80EB5BF8EFC14 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2329E018 Verifying communication to device OK. Erase size: 21 MB CMT NOR area [00000000-000006BF] erased in 0.703 s CMT NOR area [000006C0-0001FFFF] erased in 0.703 s CMT NOR area [00040000-000BFFFF] erased in 2.609 s CMT NOR area [000C0000-0013FFFF] erased in 2.562 s CMT NOR area [00140000-0137FFFF] erased in 1 min 38.672 s CMT NOR area [01380000-0151FFFF] erased in 8.672 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 3EA22A1DDA660054937DB77F2B8852B100000000 (RAP Certificate 202 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 21.766 s Processing PPM file: rm561__09.97.ppm_ad1 [BB5,BB5 ALGORITHM] size: 5.50 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 47.609 s Flash programming ... Programming completed in 23.141 s Processing CNT file: rm561__09.97.image_ad1_blac [BB5,BB5 ALGORITHM] page size: 128 K size: 8.13 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT NOR area [01DC0000-0215FFFF] erased in 26.328 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 52.094 s Flash programming ... Programming completed in 33.250 s Total time for flashing process(boot+erase+write) was 9 min 39.328 s Waiting for device boot up ... Device found: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: 63AB2A Verifying communication to device OK. Phone Type: RM-561 (Nokia 2700 classic) SW Version: V 09.97 18-06-10 RM-561 (c) Nokia Imei plain: 35694603913209-1 Product Code: 0581967 Battery voltage: 3711 mV, current: 75 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356946039132091 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
![]() | #3378 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2011 Location: Mumbai
Member: 1612956 Status: Offline Sonork: 1605465 Thanks Meter: 70 | Version Info: MCU SW version: V 05wk07v48.1 28-08-07 RM-180 (c) Nokia. HW version: 7001 RFIC version: 150a160f DSP version: rolf_espresso_05wk07v29p1 LCD version: 8618268 APE SW Core version: V 5.0741.4.0.1 08-10-07 RM-180 (C)Nokia APE Variant version: 5.0741.4.0.1-APAC2 08-10-07 RM-180 (c)Nokia. Retu version: 32 Tahvo version: 53 APE HW version: 256 APE ADSP SW version: 16054 Product Info: Production serial number: DQD186048 Product code: 0531541 Basic production code: 0530940 Serial Numbers: IMEI plain: 356966017703762 IMEI spare to net: 3A 65 69 06 71 07 73 06 IMEI SV to net: 33 65 69 06 71 07 73 06 F8 Other Info: Model : Nokia N72 (Imaging Phone) CS type : GSM900/GSM1800/GSM1900 Project Name: Rolf Espresso N72 BSI: 0.5 KOhm Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
![]() | #3379 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | flasing c2-01 Driver: NMWCD, ver: 7.1.32.66, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: rm721__11.10.mcusw [BB5,XSR 1.6] size: 28.57 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1F9FE5B CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 0A20010EE3075F40AF54AD7CFF8CCB5B9330DD0C CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3B40 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0x8F9A0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1F9FE5B Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35741804898510_CE RT.rpl" CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB CMT MuxOneNAND area [00020000-000203FF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 () sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 36.828 s Processing PPM file: rm721__11.10.ppm_e [BB5,XSR 1.6] size: 6.32 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB CMT MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 7.890 s Processing CNT file: rm721__11.10.image_e_059D5D3_006 [BB5,XSR 1.6] size: 16.96 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB CMT MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 21.469 s Total time for flashing process(boot+erase+write) was 1 min 21.953 s Waiting for device boot up ... Device found: nmwcdc\Nokia C2-01 USB Phonet, PORT_ID: 2C586647 Verifying communication to device OK. Phone Type: RM-721 (Nokia C2-01) SW Version: V 11.10 13-05-11 RM-721 (c) Nokia Imei plain: 35741804898510-8 Product Code: 059D5L6 Battery voltage: 3931 mV, current: 79 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357418048985108 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
![]() | #3380 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: PAKISTAN
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 2690 Usb flash done MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C*****FD Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm635__10.10.mcusw [BB5,BB5 ALGORITHM] size: 17.99 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2E66E91F CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0D60011579C6005681BA25A0ADB996C535AD16AC CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3252BC99 Verifying communication to device OK. Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.688 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.734 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.391 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.593 s CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 31.297 s CMT FLASH,NOR area [01380000-0151FFFF] erased in 7.766 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: C6B9354E [RAP Certificate v1 246] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 7.250 s Processing PPM file: 4673D235_rm635__10.10.ppm_m_c [BB5,BB5 ALGORITHM] size: 3.09 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 41.797 s Flash programming ... Programming completed in 11.531 s Processing CNT file: D16F22B7_rm635__10.10.image_m_c_blue_v2 [BB5,BB5 ALGORITHM] page size: 128 K size: 6.38 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 26.375 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 20.282 s Flash programming ... Programming completed in 23.203 s Total time for flashing process(boot+erase+write) was 8 min 18.453 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 2690 USB Phonet, PORT_ID: 1CF8ED5D Verifying communication to device OK. Phone type: RM-635 (Nokia 2690) SW version: V 10.10 22-04-10 RM-635 (c) Nokia Imei plain: 3534110******54-2 Product code: 0592078 Battery voltage: 3592 mV, current: 66 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3534110*****542 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
![]() | #3381 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | 5130 Driver: NMWCD, ver: 7.1.32.66, NTMP ver: Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1F4FB99 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1AB00117918D7D563B70B4E7E50316C5D6B0414E CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2329E018 Verifying communication to device OK. Erase size: 21 MB CMT NOR area [00000000-000006BF] erased in 0.609 s CMT NOR area [000006C0-0001FFFF] erased in 0.641 s CMT NOR area [00040000-000BFFFF] erased in 1.954 s CMT NOR area [000C0000-0013FFFF] erased in 2.062 s CMT NOR area [00140000-0137FFFF] erased in 1 min 20.125 s CMT NOR area [01380000-0151FFFF] erased in 7.531 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 10.031 s Processing PPM file: rm495__07.97.ppm_mena_a1 [BB5,BB5 ALGORITHM] size: 6.07 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 38.281 s Flash programming ... Programming completed in 22.485 s Processing CNT file: rm495__07.97.image_mena_a1_red [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT NOR area [01DC0000-0215FFFF] erased in 23.297 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 18.937 s Flash programming ... Programming completed in 39.172 s Total time for flashing process(boot+erase+write) was 8 min 33.469 s Waiting for device boot up ... Device found: nmwcdc\Nokia 5130 XPressMusic USB Phonet, PORT_ID: 1308326D Verifying communication to device OK. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35417903121443-4 Product Code: 0575328 Battery voltage: 4063 mV, current: 87 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354179031214434 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
![]() | #3382 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 6233 Usb flash done Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C******D Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm123_145_30005.600.mcusw [BB5,BB5 ALGORITHM] size: 16.29 MB Supported Ids: 0103192101003000, 010C192101003000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2E66E91F CMT SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000232 CMT EM1 ID: 00000353 CMT PUBLIC ID: 1AF0000BE89701549CC37D54F1ED3D8077A6ADC2 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3880 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x39DC0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x400C0 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 3252BC99 Verifying communication to device OK. Erase size: 17.75 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.609 s CMT FLASH,NOR area [000006C0-0000FFFF] erased in 0.015 s CMT FLASH,NOR area [00010000-0007FFFF] erased in 1.781 s CMT FLASH,NOR area [000A0000-0021FFFF] erased in 6.656 s CMT FLASH,NOR area [00220000-011DDFFF] erased in 1 min 4.453 s CMT FLASH,NOR area [011DE000-011DEFFF] erased in 0.016 s CMT FLASH,NOR area [011DF000-011DFFFF] erased in 0.016 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 2F36DDC4 [Rap certificate 24 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 1 min 32.375 s Processing PPM file: Products_rm-145_rm123_145_3005.60.ppm_g [BB5,BB5 ALGORITHM] size: 3.81 MB Supported Ids: 0103192101003000, 010C192101003000 Erase size: 5 MB CMT FLASH,NOR area [011E0000-016DFFFF] erased in 18.828 s Flash programming ... Programming completed in 22.094 s Processing CNT file: Products_rm-145_rm123_145_30005.60.image_g [BB5,BB5 ALGORITHM] page size: 64 K size: 1.94 MB Supported Ids: 0103192101003000, 010C192101003000 Erase size: 9 MB CMT FLASH,NOR area [016E0000-01E7FFFF] erased in 36.468 s CMT FLASH,NOR area [01E80000-01FDFFFF] erased in 6.922 s Flash programming ... Programming completed in 10.969 s Total time for flashing process(boot+erase+write) was 4 min 37.657 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6233 USB Phonet, PORT_ID: 1FD3EFE Verifying communication to device OK. Phone type: RM-145 (Nokia 6233) SW version: V 05.60 14-09-07 RM-145 (c) Nokia Imei plain: 3548210******2-1 Product code: 0532188 Battery voltage: 3725 mV, current: 77 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3548210*****21 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
![]() | #3383 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 5130c White display done 5130c White display problem done by writing Rpl without npc data Code: CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1230020E37E704566228B48F124DCFC06B1FBB8C ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NOR: Success Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35698504*****5-4 Product code: 0586824 Battery voltage: 4768 mV, current: 61 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35698504*****54 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.391 s |
![]() | #3384 (permalink) |
Member: 145225 Status: Offline Thanks Meter: 98 | Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12F31116 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0290010690927D56B37E5EC92E6659B1B4815545 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2A666803 Verifying communication to device OK. Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.687 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.641 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.562 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.656 s CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 41.875 s CMT FLASH,NOR area [01380000-0151FFFF] erased in 8.828 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 9.047 s Processing PPM file: rm495__07.97.ppm_mena_a1 [BB5,BB5 ALGORITHM] size: 6.07 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 48.265 s Flash programming ... Programming completed in 23.047 s Processing CNT file: rm495__07.97.image_mena_a1_red [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 26.234 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 48.500 s Flash programming ... Programming completed in 39.656 s Total time for flashing process(boot+erase+write) was 10 min 19.234 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 5130 XPressMusic USB Phonet, PORT_ID: 50AF5C9 Verifying communication to device OK. Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35932902606541-7 Product code: 0572164 Battery voltage: 3994 mV, current: 0 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359329026065417 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
![]() | #3385 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2011 Location: KPK Mardan Age: 37
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C08 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing CNT file: rm495__07.97.image_mena_a1_red [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 13AAA1D1 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B21 CMT PUBLIC ID: 0FA002086E747F56ECADC71DD91BACDDA29A2DE8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 209E04 Verifying communication to device OK. Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 26.125 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 47.297 s Flash programming ... Programming completed in 34.765 s Total time for flashing process(boot+erase+write) was 5 min 6.110 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 5130 XPressMusic USB Phonet, PORT_ID: 10424BAF Verifying communication to device OK. Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 3552 Product code: 0572167 Battery voltage: 3758 mV, current: 119 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed |
![]() | #3386 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0 Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 237001070FF058502FC6D06C4CDBADFE51F740A3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0119FFFF] CMT FLASH,NOR area [011A0000-0133FFFF] erased in 25.313 s Prog.status for Asic CMT ... NOR: Success Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: F1DCA5EA [RAP Certificate 142 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: Success Programming completed in 1 min 22.625 s Processing PPM file: rm436__07.23.ppm_mb [BB5,BB5 ALGORITHM] size: 6.15 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01340000-01BDFFFF] erased in 26.015 s Prog.status for Asic CMT ... NOR: Success Flash programming ... Prog.status for Asic CMT ... NOR: Success Programming completed in 27.344 s Processing CNT file: rm436__07.23.image_mb [BB5,BB5 ALGORITHM] page size: 128 K size: 20.27 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 35.87 MB CMT FLASH,NOR area [01BE0000-01F7FFFF] CMT FLASH,NOR area [01F80000-03FBFFFF] erased in 3 min 42.125 s Prog.status for Asic CMT ... NOR: Success Flash programming ... Prog.status for Asic CMT ... NOR: Success Programming completed in 1 min 28.032 s Total time for flashing process(boot+erase+write) was 8 min 4.719 s Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 359 Product code: 056 Battery voltage: 4854 mV, current: 60 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3593 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 2.469 s |
![]() | #3387 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | N8 dead with other tool.... And live again only with hti mx-box Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0XXXXXX Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 22700119F8A40344F3E3ED6BC3BCF15E8F5880E2 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 9.50.0 revision: 3.0 size: 0x3A40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 9.50.0 revision: 3.0 size: 0x7F29B Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS is blank/erased. Processing MCU file: RM-596_014.002_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 131.38 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 6 min 30.938 s Processing PPM file: RM-596_014.002_32.01_LTA_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 41.55 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 2 min 3.531 s Processing PPM file: RM-596_014.002_C10.01_LTA_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.30 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Prog.status for Asic CMT ... NAND: Success Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: Success Programming completed in 0.469 s Total time for flashing process(boot+erase+write) was 8 min 42.578 s Phone type: RM-596 (Nokia N8-00) SW version: V 92PS1_10w46.9 01-03-11 RM-596 (c) Nokia Imei plain: 35536104316550-2 Product code: 059B3W9 Battery voltage: 4776 mV, current: 79 mA ApeCoreSw: 014.002 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355361043165502 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN THANKS MX-KEY TEAM!! |
![]() | #3388 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010 Location: pakistan Age: 49
Member: 1275418 Status: Offline Thanks Meter: 432 | mei net: 01128700265785 Version: SIMLOCK SERVER Provider: T-Mobile USA , Country: United States Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK1: 1=CLOSED(MCCMNC), DATA=310160 [United States-T-Mobile USA ] BLOCK2: 1=CLOSED(MCCMNC), DATA=310200 [United States-T-Mobile USA ] BLOCK3: 1=CLOSED(MCCMNC), DATA=310210 [United States-T-Mobile USA ] BLOCK4: 1=CLOSED(MCCMNC), DATA=310220 [United States-T-Mobile USA ] BLOCK5: 1=CLOSED(MCCMNC), DATA=310230 [United States-T-Mobile USA ] BLOCK6: 1=CLOSED(MCCMNC), DATA=310240 [United States-T-Mobile USA ] BLOCK7: 1=CLOSED(MCCMNC), DATA=310250 [United States-T-Mobile USA ] BLOCK8: 1=CLOSED(MCCMNC), DATA=310260 [United States-T-Mobile USA ] BLOCK9: 1=CLOSED(MCCMNC), DATA=310270 [United States-T-Mobile USA ] BLOCK10: 1=CLOSED(MCCMNC), DATA=310310 [United States-T-Mobile USA ] BLOCK11: 1=CLOSED(MCCMNC), DATA=310580 [United States-Inland Cellular Telephone Company ] BLOCK12: 1=CLOSED(MCCMNC), DATA=310660 [United States-T-Mobile USA ] BLOCK13: 1=CLOSED(MCCMNC), DATA=310800 [United States-T-Mobile USA ] Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Rpl backup saved to "C:\mobileEx\3.5\data\backup\RH-87_01128700265785_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 01128700265785 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
![]() | #3389 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Imei net: 01123900039349 Version: SIMLOCK SERVER VERSION 63 Provider: T-Mobile USA , Country: United States Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 8000000000010002 BLOCK1: 1=CLOSED(MCCMNC), DATA=20416F [Netherlands-T-Mobile Netherlands B.V. ] BLOCK2: 1=CLOSED(MCCMNC), DATA=21630F [Hungary-Westel Mobile ] BLOCK3: 1=CLOSED(MCCMNC), DATA=21901F [Croatia-T-Mobile Hrvatska d.o.o./T-Mobile Croatia LLC ] BLOCK4: 1=CLOSED(MCCMNC), DATA=23001F [Czech Rep.-T-Mobile Czech Republic a.s. ] BLOCK5: 1=CLOSED(MCCMNC), DATA=23102F [Slovakia-Eurotel, GSM & NMT ] BLOCK6: 1=CLOSED(MCCMNC), DATA=23203F [Austria-T-Mobile Austria GmbH ] BLOCK7: 1=CLOSED(MCCMNC), DATA=23430F [United Kingdom-T-Mobile UK ] BLOCK8: 1=CLOSED(MCCMNC), DATA=25001F [Russian Federation-Mobile Telesystems ] BLOCK9: 1=CLOSED(MCCMNC), DATA=25502F [Ukraine-Ukranian Radio Systems, URS ] BLOCK10: 1=CLOSED(MCCMNC), DATA=26002F [Poland-ERA GSM (Polska Telefonia Cyfrowa Sp. Z.o.o.) ] BLOCK11: 1=CLOSED(MCCMNC), DATA=26201F [Germany-T-Mobile Deutschland GmbH ] BLOCK12: 1=CLOSED(MCCMNC), DATA=310160 [United States-T-Mobile USA ] BLOCK13: 1=CLOSED(MCCMNC), DATA=310200 [United States-T-Mobile USA ] BLOCK14: 1=CLOSED(MCCMNC), DATA=310210 [United States-T-Mobile USA ] BLOCK15: 1=CLOSED(MCCMNC), DATA=310220 [United States-T-Mobile USA ] BLOCK16: 1=CLOSED(MCCMNC), DATA=310230 [United States-T-Mobile USA ] BLOCK17: 1=CLOSED(MCCMNC), DATA=310240 [United States-T-Mobile USA ] BLOCK18: 1=CLOSED(MCCMNC), DATA=310250 [United States-T-Mobile USA ] BLOCK19: 1=CLOSED(MCCMNC), DATA=310260 [United States-T-Mobile USA ] BLOCK20: 1=CLOSED(MCCMNC), DATA=310270 [United States-T-Mobile USA ] BLOCK21: 1=CLOSED(MCCMNC), DATA=310280 [United States-Contennial Puerto Rio License Corp. ] BLOCK22: 1=CLOSED(MCCMNC), DATA=310300 [United States-Blanca Telephone Company ] BLOCK23: 1=CLOSED(MCCMNC), DATA=310310 [United States-T-Mobile USA ] BLOCK24: 1=CLOSED(MCCMNC), DATA=310580 [United States-Inland Cellular Telephone Company ] BLOCK25: 1=CLOSED(MCCMNC), DATA=310660 [United States-T-Mobile USA ] BLOCK26: 1=CLOSED(MCCMNC), DATA=310800 [United States-T-Mobile USA ] Updating SIMLOCK ...Error 1 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 Rpl backup saved to "C:\mobileEx\3.5\data\backup\RM-225_01123900039349_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 01123900039349 Version: SIMLOCK SERVER VERSION 63 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
![]() | #3390 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Build: May 13 2009 13:25:04 (rdagg) OS info: Version: 5.2.0.64 Hardware ID: 0x8C000F03 (RIM BlackBerry Device) Build: Apr 17 2010 17:28:16 (absadmin) Product info: PlatFormID: 0x8C000F03 FrequencyMap: 0x0F BoardRev: 9.7 BTMAC: 00:5F:BE:A8:00 ![]() WLAN MAC: 40:5F:BE:89:A8:E2 IMEI: 354907041317130 MEP: MEP-06813-002 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7 MEP2(Network,Active,0,10): 1821116628236418 MEP3(Network Subset): 0068463710784599 MEP4(Service Provider): 3270844631374387 MEP5(Corporate): 0584769106834793 |
