05-25-2012, 01:51 | #1 (permalink) |
Freak Poster Join Date: Jun 2005
Member: 154932 Status: Offline Thanks Meter: 6 | Nokia N8-00 No display after flashed When power on the nokia logo appeared & scanned for a minute after no display Only menu lights appeared. I flashed this to fbus 2x successful for 2 different firmware latest version, Why cannot detect USB so cannot flash to Dead USB mode. This is the logs.... Version from phone: 111.030.0609 Version from file: 111.030.0609 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C080B568 Using device: HTI, FW ver: 00.50, SN: 0000299A Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35623704547183_BA CK.rpl). CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 0BB0011330D603440D8F70B6CC4E7F23E0C6C50A ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Processing MCU file: RM-596_111.030.0609_79u_prd.core.fpsx [BB5,XSR 1.6] size: 119.69 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning ...OK Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 5 min 34.906 s Processing PPM file: RM-596_111.030.0609_18.01_APAC_2_79u_prd.rofs2.fpsx [BB5,XSR 1.6] size: 33.13 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 33.250 s Processing PPM file: RM-596_111.030.0609_C02.01_SEAP_79u_prd.rofs3.fpsx [BB5,XSR 1.6] size: 24.97 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15.16 MB CMT FLASH,MuxOneNAND area [01378000-0139FFFF] CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent CMT SOS+IVE3B block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 0.375 s Processing CNT file: RM596_APE_ONLY_ENO_11w36_v0.161.fpsx [BB5,XSR 1.6] size: 4.38 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 12.578 s Processing CNT file: RM-596_111.030.0609_U03.01_79u.uda.fpsx [BB5,XSR 1.6] size: 117.95 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 262 MB CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 5 min 26.765 s Total time for flashing process(boot+erase+write) was 13 min 2.500 s Phone type: RM-596 (Nokia N8-00) SW version: V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia Imei plain: 35623704547183-4 Product code: 0599248 Battery voltage: 4795 mV, current: 144 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356237045471834 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-25-2012, 10:38 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
regards, | |
05-28-2012, 01:52 | #7 (permalink) | |
Insane Poster Join Date: Jan 2011 Location: manila phils.
Member: 1498439 Status: Offline Thanks Meter: 10 | hi sir, try to flash again with same version or highest version... use navifirm to download flash files and use the product code of the unit located at the back of it underneath the battery... or use this product code if it is the origignal .... Quote:
and make sure that the flash files are properly seclected.... hope it helps.... | |
