03-15-2010, 10:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: BD.UAE. QATAR SAUDI INDIA
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | SECURITY_TEST failed! 1000%ok SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! 1.repair sd 2.super sd auth 3.erase pm 4.write pm 5.repair sd 6.super sd auth 7.write pm only pn1----309 8.reset all |
03-15-2010, 10:08 | #2 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | result Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35643801624049-3 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356438016240493 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to AllGsmStore For This Useful Post: |
03-15-2010, 10:33 | #4 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | load pm file and select pm 1 and pm 309 then write pm |
03-15-2010, 10:51 | #6 (permalink) |
Member: 99509 Status: Offline Sonork: Whatsapp +971508482353 Thanks Meter: 210 | go service---select pm option---loaded pm file and see list pm file select 1---and 309 then write |
7210c show SECURITY_TEST failed! | aukonline | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-13-2010 13:39 |
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! | mohit_kripalu01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 11:36 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! | Raven21 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-27-2010 08:15 |
nokia 3110 SECURITY_TEST failed | CellWorm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-04-2009 06:48 |
