03-14-2010, 09:06 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: USA
Member: 530410 Status: Offline Sonork: 100.1582823 Thanks Meter: 100 | SX4 Problem!! please inform why....? Code: Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v48.3 02-07-07 RM-133 (c) Nokia. Imei plain: 35643801823036-9 Product Code: 0529607 ApeCoreSw: V 4.0727.2.2.1 04-07-2007 RM-133 ApeVariant: V 4.0727.2.2.1-08 04-07-2007 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356438018230369 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.223.203.17 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
03-14-2010, 13:14 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: libya Age: 44
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | bro it's simple use BB5Erase_EE_16MBrap as mcu and make flash now you see SIMLOCK not valid SUPERDONGLE_not valid now go to service imei & security imei rebuild press repair SD you will get rpl to repair sim & sd now go to pm and select pm 1 & 309 make super sd auth after that write DON'T forget thanks best regards GSM Libya Last edited by Gsm Benghazi; 03-14-2010 at 13:22. |
The Following User Says Thank You to Gsm Benghazi For This Useful Post: |
03-14-2010, 18:29 | #4 (permalink) | |
Member: 530410 Status: Offline Sonork: 100.1582823 Thanks Meter: 100 | Quote:
Steps have been successful, But not repair this info after repair Code: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! | |
03-14-2010, 18:33 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | pls do it step by step 1_mxkey>serves>imei&securty>imei rebuild>repair sd 2_go to pm >click sd auth writ pm 1 and 309 and wait 2 mnt 3_full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
03-14-2010, 19:45 | #6 (permalink) | |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | Quote:
SECURITY_TEST failed! this mean your phone need pm (1& 309 ) but with some n73 phones it,s don't accept pm file mr use erase file and generate sd rpl and use super sd auth and not pm sx4 best regards | |
03-15-2010, 08:41 | #7 (permalink) | |
1- used erase file BB5Erase_EE_16MBrap Report Code: Version from phone: 4.0839.42.2.1 Version from file: EE Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Rpl backup already exist (C:\mobileEx\3.3\data\backup\BB5_35643801823036_BACK.rpl). Processing file: BB5Erase_EE_16MBrap.bin as MCU [BB5,BB5 ALGORITHM] size: 93 Bytes APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 6901870122A9A51E9DA040B5A294B212747B739E ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2300010C42CD015451A7BA877925152EF5E0CC93 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Total erase size: 64.00 KB CMT NOR area [00FF0000-00FFFFFF] erased in 0.797 s Flash programming ... Programming completed in 0.328 s Flashing completed in 19.906 s Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35643801823036-9 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 356438018230369 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Total time to process is 33.438 s Report Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 17.484 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_356438018230369_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK Report Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 6 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 44, size 182 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 0.954 s Code: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! | |
The Following User Says Thank You to .:HeRo:. For This Useful Post: |
03-15-2010, 13:30 | #8 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | write RPL CCC, HWC, VARIANT from SAME phone model ( use jaf old ver. ) http://forum.gsmhosting.com/vbb/5378736-post1.html and tell me " What happened ?" |
03-15-2010, 13:32 | #9 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | detailed info here about this error Click here --> http://forum.gsmhosting.com/vbb/f550...l-here-945700/ Quote:
The Following User Says Thank You to hasnain For This Useful Post: |
03-15-2010, 19:32 | #11 (permalink) | |
Member: 231153 Status: Offline Thanks Meter: 313 | Quote:
1 back rpl 2 full erase on mxkey 3 flash phone 4 writ rpl then writ this rpl too 4shared.com - online file sharing and storage - download N73_without_NPC_DATA__made_by_MxKey.rpl 5 mxkey>serves>imei&securty>imei rebuild>repair sd 6 go to pm >click sd auth writ pm (wait 2mnt) 7 full factory | |
03-15-2010, 20:38 | #12 (permalink) | |
ok bro I will try again in the morning | |
SX4 Problem!! please inform why....? | abellcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-21-2010 11:44 |
Sx4 problem please explain.. | lorenzo roberto | J.A.F. By Jafsupport.com | 16 | 04-16-2009 21:35 |
sx4 problem please check | hamed_karamouz | MT-BOX | 9 | 03-28-2009 15:56 |
Help me please. I use JAF (Thomus) sx4 problem. | ratthaphon1 | J.A.F. By Jafsupport.com | 1 | 01-13-2009 19:19 |
