02-09-2010, 15:44 | #16 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Nord Romania Age: 43
Member: 323481 Status: Offline Thanks Meter: 43 | 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock SIMLOCK_DATA corrupted! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.781 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_352924021297465_SIM.RPL" missing NPC data. Certificate programmed successfully ! Reading Simlock info ... And hangs...Please help! SIMLOCK_DATA corrupted! How to repair? |
02-09-2010, 18:24 | #17 (permalink) |
Member: 323481 Status: Offline Thanks Meter: 43 | After 100 tryes ............. Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 9.250 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-346_352924021297465_SIM.RPL" Updating SIMLOCK...missing NPC data. Certificate programmed successfully ! Reading Simlock info ... Imei net: 352924021297465 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Last edited by kosta25; 02-09-2010 at 18:34. |
The Following User Says Thank You to kosta25 For This Useful Post: |
02-09-2010, 20:44 | #18 (permalink) |
Banned Join Date: May 2002 Location: GERMANY Age: 43
Member: 11549 Status: Offline Thanks Meter: 6 | i have same problem Phone Type: RM-346 (Nokia E71) SW Version: V 110.71.831 02-09-08 RM-346 (c) Nokia Imei plain: 35292402765981-7 Product Code: 0575036 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 352924027659817 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF phone start-up failed i can't repair this problem |
02-09-2010, 20:59 | #19 (permalink) | |
Junior Member Join Date: Nov 2009 Location: Russian Federation, Moscow
Member: 1153888 Status: Offline Thanks Meter: 4 | Quote:
02-09-2010, 22:06 | #21 (permalink) |
No Life Poster Join Date: Feb 2004 Location: NIGERIA, DELTA STATE, WARRI
Member: 53891 Status: Offline Thanks Meter: 41 | Up till this very moment, i've not been able to fix my problem. I've tried all possibilities in this forum but no way. Really don't know what else to try anymore. I'm still waiting for manole to come up with something clever on this issue. |
02-10-2010, 01:05 | #22 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | learning something is need time i thinks this is more clearly ways. 1.do SX-4 and write PM without [308] area in case after Superdongle repair , please use "SUPER SD Auth" 2.Check BB5 Secure Validation [MXKEY - INFO] !!! NEW magic button inside mxkey !!! this is have important info, where the real problem 3.if "Recover CERT" doesn't work ?? Code: Begin Certificate Request ... Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Just in case if Recovery via Server doesn't work....... need more file about CCC,HWC and VARIANT [MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
02-10-2010, 01:06 | #23 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Quote:
b.r. | |
02-10-2010, 08:59 | #24 (permalink) |
Member: 323481 Status: Offline Thanks Meter: 43 | SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1BC001054AAC0158978A63B89FDA948A08560E00 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7 Reading RAP NPC (0x190 bytes) Original Product Code: 0558794 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0569999 Product Code missmatch ! Reading RAP HWC (0xD4 bytes) Product Code: 0558794 HWC seems to be valid |
02-10-2010, 09:03 | #25 (permalink) |
Member: 323481 Status: Offline Thanks Meter: 43 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V ICPR71_09w22.9 16-10-09 RM-346 (c) Nokia ApeCoreSw: 400.21.013 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 1.219 s ApeCoreSw: 400.21.013 ApeVariant: 400.21.013, ApeTest: RM346ENO74110842.a36 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 352924021297465 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-10-2010, 09:09 | #26 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 1. backup your RPL data 2. open with notepad 3. inject the CCC and HWC field from other backup 4. after rewrite, save 5. rewrite your RPL again. br, |
02-10-2010, 10:07 | #27 (permalink) | |
Banned Join Date: Jul 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 318781 Status: Offline Thanks Meter: 50 | Quote:
now only write ur full phone rpl backup | |
02-10-2010, 11:08 | #29 (permalink) | |||
Freak Poster Join Date: Aug 2009 Location: ...............
Member: 1104369 Status: Offline Sonork: 78954213 Thanks Meter: 14 | same problem e71 after unlock SECURITY_TEST failed! Quote:
need the CCC and HWC field from other backup | |||
I need to fix E71 SD data, I began to PM Auth, always server error! ! Please check! ! | liufeifei | Universalbox | 26 | 03-02-2010 22:50 |
Unable to unlock E71 v210 why ? | jawad8305 | Cyclonebox | 7 | 01-13-2010 16:43 |
*** Ended Up Buying Customer New Gx17 As I Was Unable To Fix Start Ng *** | moni108 | Sharp | 3 | 08-05-2006 16:35 |
Unable To Fix 1100 Again | yousha | UFS2 + UFS3-Tornadoflasher | 16 | 02-16-2004 19:43 |
Unable to fix C25 with 'Wrong softw.' | Johnny | x1x to x45/x50 | 2 | 10-13-2000 16:02 |
