02-10-2010, 20:39 | #46 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Nord Romania Age: 42
Member: 323481 Status: Offline Thanks Meter: 43 | Quote:
SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed Here is the procedure that worked for me... 1. Make full rpl back-up. 2. Downgrade from V400 to V100 Steps to downgrade... A.You need to backup Certificate first. NPC ONLY. BB5 > Servie > Imei & Security - Select NPC from drop down menu. B. You need to COMPLETELY ERASE the whole flash. BB5 > Flash > Advanced, Get Addr, untick SAFE Erase>Get Addres>Erase Flash C. Reflash all necessary data to phone. ( MCU, PPM, CNT, ENO etc) with Mx-key (Jaf not autoselect Eno fille in v300, 400). D.Next step is Certificate restore. Write back your NPC Backup. 3. Repair SD 4. Proceed with SUPER SD Auth, and write PM after it. Load PM > Suped SD Auth 5.REPAIR SIMLOCK - Determind first what SL level you got > Tick PA_SL2 > Choose Repair SIMLOCK > Tick make SIMLOCK RPL > Click Repair SPLock 5. After that SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Inject the CCC and HWC field from your first back-up of rpl... if you have(in my case..) in your actual readed rpl from phone... and write to phone...if you not have you must have rpl back-up from same phone with same product key and replace ccc+hwk field in your new rpl..... Thanks mx-key... | |
02-10-2010, 22:23 | #47 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: NIGERIA, DELTA STATE, WARRI
Member: 53891 Status: Offline Thanks Meter: 41 | Quote:
I tried the above but got stuck in no 3. with the following error: missing NPC data whenever i do repair sd. I tried about 5 times but still same. Is it server problem or phone problem, cos sometimes it goes through but at the end it will still get to security_test_failed | |
I need to fix E71 SD data, I began to PM Auth, always server error! ! Please check! ! | liufeifei | Universalbox | 26 | 03-02-2010 22:50 |
Unable to unlock E71 v210 why ? | jawad8305 | Cyclonebox | 7 | 01-13-2010 16:43 |
*** Ended Up Buying Customer New Gx17 As I Was Unable To Fix Start Ng *** | moni108 | Sharp | 3 | 08-05-2006 16:35 |
Unable To Fix 1100 Again | yousha | UFS2 + UFS3-Tornadoflasher | 16 | 02-16-2004 19:43 |
Unable to fix C25 with 'Wrong softw.' | Johnny | x1x to x45/x50 | 2 | 10-13-2000 16:02 |
