Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-21-2009, 13:57   #1 (permalink)
Member: 602540
Thanks Meter: 20
Cant Repair GDFS for w200i, please help me..
hello.. i have 2 piece of w200i red blinking. for the 1st one, i use SE Ultimate Unlocker option i chose is GDFS reconstruction n i write GDFS which i download from GDFS collection area "w200.gdfs" operation failed, this is the log
  19:16:35  SE Ultimate Unlocker v3.07 by Cruiser Team
  19:16:35  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  19:16:35  Initializing...
! 19:16:35  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 19:16:35  2. Choose the phone model
! 19:16:35  3. Select the desired options
! 19:16:35  4. Please connect the phone either via USB while holding 2-5…
! 19:16:35  - or via a serial cable and double-click on it in the device list
  19:19:46  Selected phone: W200
  19:19:46  Connecting via Generic FTDI Cable (COM4)…
  19:19:46  Device driver version: 2.2.4.0
  19:19:46  Device driver date: 6-27-2007
  19:19:47  Connecting to the baseband CPU...
  19:19:57  Entering baseband CPU service mode...
  19:19:57  Detected chipset: DB2012
  19:19:57  Boot mode: ROM
  19:19:57  Sending loader...
  19:19:58  IMEI: 35970701848962
  19:19:58  OTP CID: 51
  19:19:58  Effective CID: 52
  19:19:58  Restarting phone …
  19:20:01  Sending loader...
  19:20:01  Communicating with server…
! 19:20:05  News: Your credit consumption policy: Level 3 (Skilled)
  19:20:05  Remainig credit (supreme): 5.00
  19:20:07  Remainig credit (supreme): 4.80
  19:20:08  Restarting phone …
  19:20:11  Sending loader...
  19:20:24  Initializing GDFS access...
  19:20:24  Writing GDFS…
E 19:21:24  Error: 0x07F5EFDA
E 19:21:24  Error: 0x3173E984
E 19:21:24  Error: 0x4B055A8F
E 19:21:24  Error: 0xE9FB48DF
E 19:21:24  Error: 0xCC9B40DA
E 19:21:24  Error: 0x8F6C03FD
E 19:21:24  Error: 0x980B6A88
E 19:21:24  Error: 0x8118A648
E 19:21:24  Error: 0x59AF7680
E 19:21:24  Failed!
! 19:21:24  To report errors right-click this window
phone position now white blank, cannot flash anymore, i attact it with cruiser 13.20 this is what it say
[ --- Attach to Phone --- ]
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x8040
Protocol version: 3.1
Baudrate = 460800Bd
Booting via ROM...
Sony Ericsson phone detected.
Phone CID: 51
Phone color: Brown
Flash certificate: A1_DB2010_51_BROWN
Terminating threads...
All threads terminated.
no suitable applet found
n then for the second fone, i do not write GDFS anymore, what i do is just direct unlocking n repair erom. but result is same, process error when sending loader, this is the log
code]
19:46:28 SE Ultimate Unlocker v3.07 by Cruiser Team
19:46:28 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
19:46:28 Initializing...
! 19:46:28 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 19:46:28 2. Choose the phone model
! 19:46:28 3. Select the desired options
! 19:46:28 4. Please connect the phone either via USB while holding 2-5…
! 19:46:28 - or via a serial cable and double-click on it in the device list
19:46:45 Selected phone: W200
19:46:45 Connecting via Generic FTDI Cable (COM4)…
19:46:45 Device driver version: 2.2.4.0
19:46:45 Device driver date: 6-27-2007
19:46:46 Connecting to the baseband CPU...
19:46:49 Entering baseband CPU service mode...
19:46:49 Detected chipset: DB2012
19:46:49 Boot mode: ROM
19:46:49 Sending loader...
19:46:50 IMEI: 35379602583124
19:46:50 OTP CID: 51
19:46:50 Effective CID: 53
19:46:50 Restarting phone …
19:46:52 Sending loader...
19:46:53 Communicating with server…
! 19:46:55 News: Your credit consumption policy: Level 3 (Skilled)
19:46:55 Remainig credit (supreme): 4.80
19:46:57 Remainig credit (supreme): 4.60
19:46:58 Restarting phone …
19:47:01 Sending loader...
E 19:48:05 Error: 0x07F5EFDA
E 19:48:05 Error: 0x6C729765
E 19:48:05 Error: 0x8CDFAB78
E 19:48:05 Error: 0xFA7863EC
E 19:48:06 Error: 0x780BA8B0
E 19:48:06 Error: 0x599D63C1
E 19:48:06 Error: 0x10BE36DC
E 19:48:06 Error: 0x59AF7680
E 19:48:06 GDFS start-up problem
E 19:48:06 Failed!
! 19:48:06 To report errors right-click this window
[/code]
phone position is the same, white blank n cannot flash anymore using cruiser 13.20. is my step wrong?
yeerk05
Old 09-15-2009, 11:48   #2 (permalink)
rockgsm's Avatar
Member: 420862
Thanks Meter: 51
Exclamation
hi
same problem here pl help
16:06:28 SE Ultimate Unlocker v4.01 by Cruiser Team
16:06:28 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
16:06:28 Initializing...
! 16:06:29 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 16:06:29 2. Choose the phone model
! 16:06:29 3. Select the desired options
! 16:06:29 4. Please connect the phone either via USB while holding 2-5…
! 16:06:29 - or via a serial cable and double-click on it in the device list
16:07:03 Selected phone: W200
16:07:03 Connecting via Generic FTDI Cable (COM10)…
16:07:03 Device driver version: 2.2.4.0
16:07:03 Device driver date: 6-27-2007
16:07:04 Connecting to the baseband CPU...
16:07:07 Entering baseband CPU service mode...
16:07:07 Detected chipset: DB2012
16:07:07 Boot mode: ROM
16:07:07 Sending loader...
16:07:08 IMEI: 35544xxxxxxxxxx
16:07:08 OTP CID: 51
16:07:08 Effective CID: 51
16:07:08 Restarting phone …
16:07:12 Sending loader...
16:07:24 Initializing GDFS access...
16:07:24 Writing GDFS…
E 16:08:25 Error: 0xE1E2479D
E 16:08:25 Error: 0x3173E984
E 16:08:25 Error: 0x4B055A8F
E 16:08:25 Error: 0xE9FB48DF
E 16:08:25 Error: 0xCC9B40DA
E 16:08:25 Error: 0x8F6C03FD
E 16:08:25 Error: 0x980B6A88
E 16:08:25 Error: 0x8118A648
E 16:08:25 Error: 0x59AF7680
E 16:08:25 Failed!
! 16:08:25 To report errors right-click this window
now handset white display , not able to flash
How Can I Repair Gdf For W200 Please Gsmboutique.ma DreamBox 7 05-30-2010 17:29
i cant repair u900 samsung imei.please help. sirnavid2010 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 05-19-2009 10:51
Repair GDFS S500i failed please help me Tamansu D-Unlock Suite 3 04-27-2009 19:28
repair GDFS PROBLEM K800i please help zakiyyboss SETool2 8 03-26-2009 00:37
K530i unlock repair gdfs write failed PLEASE ADVICE ME! gsm8g DreamBox 2 05-12-2008 08:19
Page generated in 0.16381 seconds with 9 queries
