07-14-2005, 17:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | First use at Cruiser 1 'dead' phone! Also I got this message when I turned it on YOU ARE USING A TRIAL CARD Number of logins left: 50 Version 4.30 beta ready! Is this usual? Best Regards Simon |
07-14-2005, 17:51 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Midlands, UK
Member: 57937 Status: Offline Thanks Meter: 34 | F500 is the Voda version of the K500. They both use the same flash, For Unlocking, After Unlock RSA, reattach, and read codes, then enter codes on the phone. |
07-14-2005, 17:53 | #4 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | I know its good mate cos Its the same as fighter with all the new phones, thanks for the info I will flash it as it wont switch on now for whatever reason, so I cant enter codes, thanks guys for the response PS whats the difference in the files R2AA003 and R2Y005 R2AE033 in the support for the K500/F500 any idea? |
07-14-2005, 21:14 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | The Dog: You are getting the "trial logins" message because your Cruiser is not fully activated. Once your reseller has recieved back your Fighter Card then you will be given a new activation key which will make your Cruiser fully activated. About your F500, make sure your battery is fully charged. Then flash ARM, unlock RSA and then flash FileSystem. If you still have problems contact me on ICQ/MSN Edit: Also, read the sticky at the top of the forum for info on the different SE firmware versions. Last edited by muppet; 07-14-2005 at 22:49. |
07-15-2005, 15:40 | #7 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | Going back to the files the post you mention only says this Sony Ericsson firmware version numbering system. -------------------------------------------------------------------------------- R1A001 R1A002 ... R1A999 R1B001 R1B002 ... R1B999 R1C001 ... R1Z999 R1AA001 R1AA002 ... R1AA999 R1AB001 ... R1AZ001 ... R1AZ999 R1BA001 ... R1ZZ999 R2A001 ... etc. Therefore R1Y005 is older than R1AB013 (for the same FW of course).] Doesnt really say a lot about the files etc! Plus those two files mentioned as an example are not even listed. So is it the case of an alphabetically thing where the A after the R1 is newer than a letter further along the alphabet eg the Y in R1Y? So a file R1C is newer then R1D?? |
07-15-2005, 15:51 | #8 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Stockholm www.sumpansmobil.se Age: 57
Member: 79724 Status: Offline Thanks Meter: 15 | Quote:
But firmware with 2 letters EX "R1CA" is newer then firmware with just one letter. For your phone the newest firmware is R2AE033. BR Nizze | |
07-15-2005, 17:03 | #10 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | One more thing if you dont mind! Have gone to download the firmare. We have main firmware and raw firmware, whats the difference is one cooked? |
07-15-2005, 18:29 | #11 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | There is main firmware and raw file-system. Main firmware is the phone software, the raw file-system consists of user data, many non-executable files, java applets, etc. Since it is raw, it has to be cooked by customizing the phone. |
07-15-2005, 18:32 | #12 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | Ok ive got the oven on! But I am having big problems. The F500i now needs a recovery file which I have downloaded every one for CID29 and nothing works so for now the phone is dead! Another phone a K500i I haver unlocked the RSA and succesfully flashed but now the camera is saying: Wrong Camera Driver version(3.9). Please update camera driver to 3.10 or later. Where are the files for this please??! THANKS! |
07-15-2005, 18:41 | #13 (permalink) | |
Member: 1841 Status: Offline Thanks Meter: 469 | Quote:
K500i: Have you used the R2AE033 firmware? (The files are in Raw FS) | |
07-15-2005, 18:51 | #14 (permalink) |
Member: 17351 Status: Offline Thanks Meter: 41 | Hi the F500i I am getting this message Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration not found. Done. The phone contains recovery certificate! You MUST reflash the main firmware part! Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Flash file: "K500i_CXC125879_EU4_R2AE033_Red29.ck5fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Programming flash... Error flashing block at address: 0x44D20000 The K500i I have flashed after pressing on Write Raw FS this file K500i_CXC125879_EU4_R2AE033_Red29.ck5fs" And when it switches on the screen now says Configuration error. Please contact your network operator or service centre. |
which program to use from cruiser suite to flash a1 phones like k750i? | turbosim_gr | Cruiser Suite | 19 | 04-10-2010 17:15 |
Again World First. Only Best Tool For CDMA Phones At Market. | cbz_4383 | Main Sales Section | 0 | 10-03-2009 12:27 |
db2020 flash ic after write imei...still can use at other phone? | jimmyyew1981 | DreamBox | 6 | 08-30-2009 07:15 |
first use, first problem! | .:bono:. | Easy-Unlocker | 6 | 03-18-2008 14:54 |
How to make a VOICE call using AT commands on siemens or se phones? | spaxa | GSM Programming & Reverse Engineering | 2 | 05-19-2007 21:28 |
