11-22-2006, 11:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: -Algeria- Age: 47
Member: 51746 Status: Offline Thanks Meter: 47 | flash fs w810i 91% stop Applet error: ERROR|EraseBlock| 10 00 00 1C 46 Error flashing block at address: 0x461E0000 Script error: Flash error [10.05.75] Error uploading applet |
11-25-2006, 15:40 | #3 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 242322 Status: Offline Thanks Meter: 17 | 4. w810i flash error help please hello.help me freinds please that makes me 4w810i that i wanted to put french with cruiser and all died because has each faith by flashant the fs ca puts error to me often has 17% a20% whereas the other phons pass without problem a 100%.avec the w810i each faith it is error flashing block at address:0x45A10000 Script error(10.05.75).I'did everything but it is always the same thing msn:[email protected] icq:390-397-392 |
11-26-2006, 19:58 | #6 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 18262 Status: Offline Thanks Meter: 160 | hallo mainboard ihave w810i also face same problem Error flashing block at address: 0x461E0000 i try all of the solutions suggested in forum can u guide me what can i do what is the right procedure to repair w810i thanks waiting for reply |
11-26-2006, 22:36 | #7 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | my reply is same as before, you just need read it: http://forum.gsmhosting.com/vbb/showthread.php?t=215456 also use latest firmware R4EA031 |
11-26-2006, 23:15 | #8 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Austria
Member: 57108 Status: Offline Thanks Meter: 7 | had same problem with error: Applet error: ERROR|EraseBlock| Error flashing block at address: Script error: Flash error [10.05.75] Error uploading applet charge battery and try again br stupsi |
11-27-2006, 07:49 | #11 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | buddy take a look it this FOR FLASHING W810i WITH CRUISER 10. 1. ATTACH PHONE 2. UNLOCK RSA. 3. ATAACH PHONE AGAIN 4. FLASH MAIN SOFTWARE 5. DETACH PHONE 6. ATTACH PHONE AGAIN 7. UNLOCK RSA AGAIN 8. ATTACH PHONE AGAIN 9. FLASH RAW FS 10. CUSTOMISE FS 11. RESTORE FIRMWARE IF YOUR PHONE IS STILL DEAD THAN, 12. ATTACH PHONE 13. CLICK ON FLASH MAIN & SELECT W810i_FullGDFS_Brown49.cw81sw 14. FINALIZE GDFS 15. ATTACH PHONE 16. RESTORE FIRMWARE 17. DETACH PHONE NOW IF YOUR PHONE SHOWS "PLEASE WAIT" 18. ATTACH PHONE 19. UNLOCK RSA 20. GO TO LOCK'S TAB & PRESS RESTORE SECURITY SELECT UR PHONE'S IMEI NAMED .mdcFILE FROM C:\Program files\cruiser\data\GDFS Zone Backups\W810i\ur phones imei no. folder\ur phones imei no.mdc 21. RESTORE FIRMWARE 22. DETACH PHONE try this and tell us Salman Ahmed |
11-27-2006, 13:03 | #12 (permalink) |
Registered User Join Date: Dec 2005 Location: Syria
Member: 212458 Status: Offline Thanks Meter: 3 | I have the same problem ...W300--w810i solution of this problem in the pit that the non-use of battery and the use of Port Splai + speed for the lowest speed, and thanks to all of you |
11-27-2006, 18:18 | #13 (permalink) |
Member: 18262 Status: Offline Thanks Meter: 160 | Error flashing block at address: 0x461A0000 Script error: Flash error [10.05.75] what can i do ?????????????????????????????????????????????????? ????????????????? solve this mystry w810i |
W810i PROBLEM FLASH FS RAW!!! | denard | Cruiser Suite | 3 | 02-20-2008 06:57 |
sony eric z1010 stop in 13°/° flash FS | ali25 | Cruiser Suite | 2 | 06-11-2007 08:27 |
Cant Flash Fs On W810i Main Flash Ok | chiragp | Cruiser Suite | 1 | 04-01-2007 11:22 |
w550i flashing FS stop at 41% | cellbhai | Cruiser Suite | 7 | 01-07-2007 05:36 |
W550i stop flashing FS at 59%!!!! | zeozea | SonyEricsson (USB-Smart) | 3 | 12-28-2005 16:36 |
