12-17-2005, 19:32 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Somewhere only we know Age: 42
Member: 102326 Status: Offline Thanks Meter: 0 | t610 cant attach T610_TAE_Standard_CXC125562_R4C003.ARM.flp T610_EU1_CXC125565_R4C003.AVR.flp then i power on phone and frezes in sand clock i try to reflash but when i connect to cruiser get this: Version 7.10 beta ready! Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x5B08 Protocol version: 2.1 Trying CID29 applet... Trying CID27 applet... RSA protection feature inactive. Bypassing authority check... and retry to connect and always its the same, anyone has been in this problem?? thanks BR |
12-17-2005, 20:41 | #2 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Tarragona, Spain
Member: 36126 Status: Offline Thanks Meter: 311 | somtimes it gives problem with attaching do one thing when it stops then put out battery and put in again it will jump 10% more then do it till it will attach the phone after attaching like this way evrything will work as unlock flash i got that problem also always in 610 but this is normal try as i said hope it will work P.s. When phone will attach plz put the battery cover back so that conection will not drop again WBR Wykie |
12-18-2005, 00:45 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | @lgrz55: Do you let it finish the Authority check bypass? It can take up to a minute sometimes... You've flashed an old firmware to the phone that doesn't use RSA, it uses a different boot method. It'll take Cruiser a little longer to boot this phone. |
Lead, cant attach k750 via cruiser, cable is right. | yardh | Cruiser Suite | 16 | 08-18-2006 20:46 |
t610 not attaching | navneet | Cruiser Suite | 1 | 02-11-2006 15:54 |
Help I cant attach K750 | Weasley | Cruiser Suite | 8 | 07-03-2005 15:21 |
help!!!Cant attach p900 PDA Part~ | shingo000 | Cruiser Suite | 0 | 08-22-2004 06:16 |
Cant attach t68ie..... help | Keller | Cruiser Suite | 3 | 04-09-2004 17:38 |
