06-13-2008, 17:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: GSMHOSTING Age: 42
Member: 57652 Status: Offline Thanks Meter: 1,893 | Post here Successful Unlocked phones With JavaUnlocker K610I Code: 17:34:31 SE A1 Java Unlocker v1.02 by Cruiser Team 17:34:31 Initializing... ! 17:34:31 1. Choose the phone model ! 17:34:31 2. Select main firmware flash file (*.a1sw) ! 17:34:31 3. Select raw FS flash file (*.a1fs) ! 17:34:31 4. Please connect the phone while holding its C button… 17:57:16 Connecting via SEMC USB Flash Device (USB3)… 17:57:16 Device driver version: 2.0.0.4 17:57:16 Device driver date: 9-12-2007 17:57:16 Connecting to the baseband CPU... 17:57:16 Entering baseband CPU service mode... 17:57:17 Detected chipset: DB2020 17:57:17 Boot mode: EROM 17:57:17 EROM version: R3A016 prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 17:57:17 Initializing flash files... 17:57:31 Sending loader... 17:57:31 Sending loader... 17:57:32 Sending loader... 17:57:32 About to flash 37 MB of data… 18:02:19 Sending loader... 18:02:21 System starting up... 18:02:21 GDFS starting up... 18:02:34 FS starting up... 18:02:55 FS data uploading... ! 18:03:06 1. Please disconnect battery and cable from the phone! ! 18:03:06 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 18:03:06 3. Wait to customize finish ! 18:03:06 4. Turn off the phone ! 18:03:06 5. Please connect the phone while holding its C button… 18:06:15 Connecting via SEMC USB Flash Device (USB3)… 18:06:15 Device driver version: 2.0.0.4 18:06:15 Device driver date: 9-12-2007 18:06:15 Connecting to the baseband CPU... 18:06:15 Entering baseband CPU service mode... 18:06:15 Detected chipset: DB2020 18:06:15 Boot mode: EROM 18:06:15 EROM version: R3A016 prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 18:06:15 Sending loader... 18:06:16 Sending loader... 18:06:16 Sending loader... 18:06:17 Sending loader... 18:06:19 System starting up... 18:06:19 GDFS starting up... 18:06:36 FS starting up... 18:06:43 FS data uploading... ! 18:06:58 1. Please disconnect battery and cable from the phone! ! 18:06:58 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 18:06:58 3. Connect the phone again ! 18:06:58 4. If asked, Install phone drivers ! 18:06:58 5. Choose 'PHONE MODE' in the phone ! 18:33:30 After choosing 'PHONE MODE' press the Ready button 18:33:36 Connecting via SEMC WMC Device (COM22, COM34)… 18:33:36 Device driver version: 4.34.0.2705 18:33:36 Device driver date: 5-1-2006 ! 18:33:47 1. Please disconnect battery and cable from the phone! ! 18:33:47 2. Please connect the phone while holding its C button… 18:34:31 Connecting via SEMC USB Flash Device (USB3)… 18:34:31 Device driver version: 2.0.0.4 18:34:31 Device driver date: 9-12-2007 18:34:31 Connecting to the baseband CPU... 18:34:31 Entering baseband CPU service mode... 18:34:31 Detected chipset: DB2020 18:34:31 Boot mode: EROM 18:34:31 EROM version: R3A016 prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 18:34:31 Sending loader... 18:34:32 Sending loader... 18:34:32 About to flash 1 MB of data… 18:34:52 Done. ! 18:34:52 Please disconnect battery and cable from the phone! |
The Following 8 Users Say Thank You to EMINEMGSM For This Useful Post: |
06-13-2008, 22:33 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | Guys, it will help if you can post phone's model and phone's CID instead of name of original network. "OTP CID" is NOT Phone's CID, ignore it. Use Cruiser 13.11. If Cruiser don't show you "Phone CID:", you can see CID of your phone if you'll look at the attaching process. CID52 phone: Booting via EROM... Trying Red CID50 flash applet... Trying Red CID51 flash applet... Trying Red CID52 flash applet... Sending applet prologue... CID51 phone: Booting via EROM... Trying Red CID50 flash applet... Trying Red CID51 flash applet... Sending applet prologue... CID50 phones: Booting via EROM... Trying Red CID50 flash applet... Sending applet prologue... In other words, important is what flash applet is used as the last one. That is CID of your phone. |
The Following 3 Users Say Thank You to Mainboard For This Useful Post: |
06-14-2008, 08:17 | #7 (permalink) |
No Life Poster Join Date: Aug 2006 Location: South Africa
Member: 340957 Status: Offline Thanks Meter: 65 | w850 success Code: 08:58:26 SE A1 Java Unlocker v1.02 by Cruiser Team 08:58:27 Initializing... ! 08:58:27 1. Choose the phone model ! 08:58:27 2. Select main firmware flash file (*.a1sw) ! 08:58:27 3. Select raw FS flash file (*.a1fs) ! 08:58:27 4. Please connect the phone while holding its C button… 08:58:44 Connecting via SEMC USB Flash Device (USB1)… 08:58:44 Device driver version: 1.1.0.12 08:58:44 Device driver date: 9-25-2006 08:58:44 Connecting to the baseband CPU... 08:58:44 Entering baseband CPU service mode... 08:58:45 Detected chipset: DB2020 08:58:45 Boot mode: EROM 08:58:45 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 08:58:45 Initializing flash files... 08:58:49 Sending loader... 08:58:49 Sending loader... 08:58:49 Sending loader... 08:58:49 About to flash 45 MB of data… 09:04:30 Sending loader... 09:04:32 System starting up... 09:04:32 GDFS starting up... 09:04:46 FS starting up... 09:05:17 FS data uploading... ! 09:05:27 1. Please disconnect battery and cable from the phone! ! 09:05:28 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 09:05:28 3. Wait to customize finish ! 09:05:28 4. Turn off the phone ! 09:05:28 5. Please connect the phone while holding its C button… 09:07:08 Connecting via SEMC USB Flash Device (USB1)… 09:07:08 Device driver version: 1.1.0.12 09:07:08 Device driver date: 9-25-2006 09:07:08 Connecting to the baseband CPU... 09:07:08 Entering baseband CPU service mode... 09:07:08 Detected chipset: DB2020 09:07:08 Boot mode: EROM 09:07:08 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 09:07:08 Sending loader... 09:07:09 Sending loader... 09:07:09 Sending loader... 09:07:10 Sending loader... 09:07:11 System starting up... 09:07:11 GDFS starting up... 09:07:27 FS starting up... 09:07:30 FS data uploading... ! 09:07:45 1. Please disconnect battery and cable from the phone! ! 09:07:45 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 09:07:45 3. Connect the phone again ! 09:07:45 4. If asked, Install phone drivers ! 09:07:45 5. Choose 'PHONE MODE' in the phone ! 09:08:41 After choosing 'PHONE MODE' press the Ready button 09:08:45 Connecting via SEMC WMC Device (COM9, COM8)… 09:08:45 Device driver version: 4.34.0.2705 09:08:45 Device driver date: 5-1-2006 ! 09:08:59 1. Please disconnect battery and cable from the phone! ! 09:08:59 2. Please connect the phone while holding its C button… 09:09:06 Connecting via SEMC USB Flash Device (USB1)… 09:09:06 Device driver version: 1.1.0.12 09:09:06 Device driver date: 9-25-2006 09:09:06 Connecting to the baseband CPU... 09:09:06 Entering baseband CPU service mode... 09:09:06 Detected chipset: DB2020 09:09:06 Boot mode: EROM 09:09:06 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 09:09:06 Sending loader... 09:09:07 Sending loader... 09:09:08 About to flash 1 MB of data… 09:09:26 Done. ! 09:09:26 Please disconnect battery and cable from the phone! |
The Following User Says Thank You to joe cellular For This Useful Post: |
06-14-2008, 10:41 | #8 (permalink) |
Freak Poster Join Date: May 2005 Age: 43
Member: 143802 Status: Offline Sonork: 100.1585023 Thanks Meter: 15 | K610i successfully done Code: 14:51:01 SE A1 Java Unlocker v1.02 by Cruiser Team 14:51:01 Initializing... ! 14:51:01 1. Choose the phone model ! 14:51:01 2. Select main firmware flash file (*.a1sw) ! 14:51:01 3. Select raw FS flash file (*.a1fs) ! 14:51:01 4. Please connect the phone while holding its C button… 14:51:39 Connecting via SEMC USB Flash Device (USB1)… 14:51:39 Device driver version: 2.0.0.4 14:51:39 Device driver date: 9-12-2007 14:51:39 Connecting to the baseband CPU... 14:51:39 Entering baseband CPU service mode... 14:51:40 Detected chipset: DB2020 14:51:40 Boot mode: EROM 14:51:40 EROM version: R3A016 prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 14:51:40 Initializing flash files... 14:51:43 Sending loader... 14:51:43 Sending loader... 14:51:44 Sending loader... 14:51:44 About to flash 37 MB of data… 14:56:19 Sending loader... 14:56:20 System starting up... 14:56:20 GDFS starting up... 14:56:36 FS starting up... 14:56:48 FS data uploading... ! 14:56:58 1. Please disconnect battery and cable from the phone! ! 14:56:58 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 14:56:58 3. Wait to customize finish ! 14:56:58 4. Turn off the phone ! 14:56:58 5. Please connect the phone while holding its C button… 15:02:48 Connecting via SEMC USB Flash Device (USB1)… 15:02:48 Device driver version: 2.0.0.4 15:02:48 Device driver date: 9-12-2007 15:02:48 Connecting to the baseband CPU... 15:02:48 Entering baseband CPU service mode... 15:02:48 Detected chipset: DB2020 15:02:48 Boot mode: EROM 15:02:48 EROM version: R3A016 prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 15:02:48 Sending loader... 15:02:48 Sending loader... 15:02:49 Sending loader... 15:02:49 Sending loader... 15:02:50 System starting up... 15:02:50 GDFS starting up... 15:03:10 FS starting up... 15:03:13 FS data uploading... ! 15:03:27 1. Please disconnect battery and cable from the phone! ! 15:03:27 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 15:03:27 3. Connect the phone again ! 15:03:27 4. If asked, Install phone drivers ! 15:03:27 5. Choose 'PHONE MODE' in the phone ! 15:05:13 After choosing 'PHONE MODE' press the Ready button 15:05:19 Connecting via SEMC WMC Device (COM35, COM34)… 15:05:19 Device driver version: 4.40.2.0 15:05:19 Device driver date: 4-3-2007 ! 15:05:30 1. Please disconnect battery and cable from the phone! ! 15:05:30 2. Please connect the phone while holding its C button… 15:05:47 Connecting via SEMC USB Flash Device (USB1)… 15:05:47 Device driver version: 2.0.0.4 15:05:47 Device driver date: 9-12-2007 15:05:47 Connecting to the baseband CPU... 15:05:47 Entering baseband CPU service mode... 15:05:48 Detected chipset: DB2020 15:05:48 Boot mode: EROM 15:05:48 EROM version: R3A016 prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 15:05:48 Sending loader... 15:05:48 Sending loader... 15:05:49 About to flash 1 MB of data… 15:06:07 Done. ! 15:06:07 Please disconnect battery and cable from the phone! |
06-16-2008, 13:29 | #9 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 111730 Status: Offline Thanks Meter: 118 | z310i unlocked succefully with SE A1 Java Unlocker z310i unlocked succefully with SE A1 Java Unlocker Code: 13:12:48 SE A1 Java Unlocker v1.02 by Cruiser Team 13:12:48 Initialisation en cours… ! 13:12:48 1. Choisir le model du telephone ! 13:12:48 2. Selectionner le principal fichier flash firmware(*.a1sw) ! 13:12:48 3. Selectionner la ligne FS du fichier flash (*.a1sw) ! 13:12:48 4. Connecter le telephone en maintenant le bouton C… 13:13:48 Se connecte via Generic EMP USB Flash Device (USB1)… 13:13:48 Device driver version: 1.1.0.12 13:13:48 Device driver date: 9-25-2006 13:13:48 Connexion a la Baseband CPU en cours… 13:13:48 Baseband CPU service mode entrant… 13:13:49 Chipset detecte: PNX5230 13:13:49 Boot mode: EROM 13:13:49 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 13:13:49 Initializing flash files... 13:13:59 Envoi du loader en cours… 13:14:00 Envoi du loader en cours… 13:14:00 Pret a flasher 31 le MB du data... 13:17:19 Envoi du loader en cours… 13:17:21 System starting up... 13:17:21 GDFS starting up... 13:17:26 FS starting up... 13:17:43 FS data uploading... ! 13:17:55 1. Deconnecter la batterie et le cable du telephone! ! 13:17:55 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 13:17:55 3. Wait to customize finish ! 13:17:55 4. Turn off the phone ! 13:17:55 5. Connecter le telephone en maintenant le bouton C… 13:20:11 Se connecte via Generic EMP USB Flash Device (USB1)… 13:20:11 Device driver version: 1.1.0.12 13:20:11 Device driver date: 9-25-2006 13:20:11 Connexion a la Baseband CPU en cours… 13:20:11 Baseband CPU service mode entrant… 13:20:12 Chipset detecte: PNX5230 13:20:12 Boot mode: EROM 13:20:12 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 13:20:12 Envoi du loader en cours… 13:20:12 Envoi du loader en cours… 13:20:13 Envoi du loader en cours… 13:20:16 System starting up... 13:20:16 GDFS starting up... 13:20:22 FS starting up... 13:20:22 FS data uploading... ! 13:20:37 1. Deconnecter la batterie et le cable du telephone! ! 13:20:37 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 13:20:37 3. Connect the phone again ! 13:20:37 4. If asked, Install phone drivers ! 13:20:37 5. Choose 'PHONE MODE' in the phone ! 13:21:33 After choosing 'PHONE MODE' press the Ready button 13:23:12 Se connecte via SEMC WMC Device (COM15, COM14)… 13:23:12 Device driver version: 4.38.6.1 13:23:12 Device driver date: 9-19-2006 ! 13:23:23 1. Deconnecter la batterie et le cable du telephone! ! 13:23:23 2. Connecter le telephone en maintenant le bouton C… 13:23:38 Se connecte via Generic EMP USB Flash Device (USB1)… 13:23:38 Device driver version: 1.1.0.12 13:23:38 Device driver date: 9-25-2006 13:23:38 Connexion a la Baseband CPU en cours… 13:23:38 Baseband CPU service mode entrant… 13:23:39 Chipset detecte: PNX5230 13:23:39 Boot mode: EROM 13:23:39 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 13:23:39 Envoi du loader en cours… 13:23:39 Envoi du loader en cours… 13:23:39 Pret a flasher 1 le MB du data... 13:23:55 Effectue. ! 13:23:55 Deconnecter la batterie et le cable du telephone! |
06-17-2008, 11:39 | #10 (permalink) |
Freak Poster Join Date: May 2006 Location: SUDAN Age: 39
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Successful Unlock K800i Cid53 with A1JavaUnlocker v1.02 13:22:04 SE A1 Java Unlocker v1.02 by Cruiser Team 13:22:04 Initializing... ! 13:22:04 1. Choose the phone model ! 13:22:04 2. Select main firmware flash file (*.a1sw) ! 13:22:04 3. Select raw FS flash file (*.a1fs) ! 13:22:04 4. Please connect the phone while holding its C button… 13:22:22 Connecting via SEMC USB Flash Device (USB3)… 13:22:22 Device driver version: 1.0.0.8 13:22:22 Device driver date: 3-30-2006 13:22:22 Connecting to the baseband CPU... 13:22:22 Entering baseband CPU service mode... 13:22:23 Detected chipset: DB2020 13:22:23 Boot mode: EROM 13:22:23 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 13:22:23 Initializing flash files... 13:22:30 Sending loader... 13:22:30 Sending loader... 13:22:30 About to flash 45 MB of data… 13:28:34 Sending loader... 13:28:35 System starting up... 13:28:35 GDFS starting up... 13:28:59 FS starting up... 13:29:06 FS data uploading... ! 13:29:16 1. Please disconnect battery and cable from the phone! ! 13:29:16 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 13:29:16 3. Wait to customize finish ! 13:29:16 4. Turn off the phone ! 13:29:16 5. Please connect the phone while holding its C button… 13:33:01 Connecting via SEMC USB Flash Device (USB3)… 13:33:01 Device driver version: 1.0.0.8 13:33:01 Device driver date: 3-30-2006 13:33:01 Connecting to the baseband CPU... 13:33:01 Entering baseband CPU service mode... 13:33:02 Detected chipset: DB2020 13:33:02 Boot mode: EROM 13:33:02 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 13:33:02 Sending loader... 13:33:02 Sending loader... 13:33:02 Sending loader... 13:33:04 System starting up... 13:33:04 GDFS starting up... 13:33:20 FS starting up... 13:33:26 FS data uploading... ! 13:33:41 1. Please disconnect battery and cable from the phone! ! 13:33:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 13:33:41 3. Connect the phone again ! 13:33:41 4. If asked, Install phone drivers ! 13:33:41 5. Choose 'PHONE MODE' in the phone ! 13:34:47 After choosing 'PHONE MODE' press the Ready button 13:35:08 Connecting via SEMC WMC Device (COM16, COM15)… 13:35:08 Device driver version: 4.34.0.2705 13:35:08 Device driver date: 4-28-2006 ! 13:35:20 1. Please disconnect battery and cable from the phone! ! 13:35:20 2. Please connect the phone while holding its C button… 13:35:34 Connecting via SEMC USB Flash Device (USB3)… 13:35:34 Device driver version: 1.0.0.8 13:35:34 Device driver date: 3-30-2006 13:35:34 Connecting to the baseband CPU... 13:35:34 Entering baseband CPU service mode... 13:35:35 Detected chipset: DB2020 13:35:35 Boot mode: EROM 13:35:35 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 13:35:35 Sending loader... 13:35:36 Sending loader... 13:35:36 About to flash 1 MB of data… 13:35:54 Done. ! 13:35:54 Please disconnect battery and cable from the phone! Last edited by Mainboard; 06-17-2008 at 11:54. |
06-17-2008, 20:29 | #11 (permalink) |
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Succesfully unlock w200 with A1javaUnlocker 22:09:56 SE A1 Java Unlocker v1.02 by Cruiser Team 22:09:56 Initializing... ! 22:09:56 1. Choose the phone model ! 22:09:56 2. Select main firmware flash file (*.a1sw) ! 22:09:56 3. Select raw FS flash file (*.a1fs) ! 22:09:56 4. Please connect the phone while holding its C button… 22:11:30 Connecting via SEMC USB Flash Device (USB3)… 22:11:30 Device driver version: 1.0.0.8 22:11:30 Device driver date: 3-30-2006 22:11:30 Connecting to the baseband CPU... 22:11:30 Entering baseband CPU service mode... 22:11:31 Detected chipset: DB2012 22:11:31 Boot mode: EROM 22:11:31 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 22:11:31 Initializing flash files... 22:11:34 Sending loader... 22:11:34 Sending loader... 22:11:35 About to flash 29 MB of data… 22:15:39 Sending loader... 22:15:42 System starting up... 22:15:42 GDFS starting up... 22:16:03 FS starting up... 22:16:30 FS data uploading... ! 22:16:41 1. Please disconnect battery and cable from the phone! ! 22:16:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 22:16:41 3. Wait to customize finish ! 22:16:41 4. Turn off the phone ! 22:16:41 5. Please connect the phone while holding its C button… 22:19:52 Connecting via SEMC USB Flash Device (USB3)… 22:19:52 Device driver version: 1.0.0.8 22:19:52 Device driver date: 3-30-2006 22:19:52 Connecting to the baseband CPU... 22:19:52 Entering baseband CPU service mode... 22:19:52 Detected chipset: DB2012 22:19:52 Boot mode: EROM 22:19:52 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 22:19:52 Sending loader... 22:19:52 Sending loader... 22:19:53 Sending loader... 22:19:55 System starting up... 22:19:55 GDFS starting up... 22:20:22 FS starting up... 22:20:35 FS data uploading... ! 22:20:50 1. Please disconnect battery and cable from the phone! ! 22:20:50 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 22:20:50 3. Connect the phone again ! 22:20:50 4. If asked, Install phone drivers ! 22:20:50 5. Choose 'PHONE MODE' in the phone ! 22:21:52 After choosing 'PHONE MODE' press the Ready button 22:25:35 Connecting via SEMC WMC Device (COM7, COM6)… 22:25:35 Device driver version: 4.34.0.2705 22:25:35 Device driver date: 10-24-2006 ! 22:25:47 1. Please disconnect battery and cable from the phone! ! 22:25:47 2. Please connect the phone while holding its C button… 22:25:56 Connecting via SEMC USB Flash Device (USB3)… 22:25:56 Device driver version: 1.0.0.8 22:25:56 Device driver date: 3-30-2006 22:25:56 Connecting to the baseband CPU... 22:25:56 Entering baseband CPU service mode... 22:25:56 Detected chipset: DB2012 22:25:56 Boot mode: EROM 22:25:56 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 22:25:56 Sending loader... 22:25:57 Sending loader... 22:25:57 About to flash 1 MB of data… 22:26:18 Done. ! 22:26:18 Please disconnect battery and cable from the phone! Thanks to Mainboard for best help |
06-18-2008, 02:29 | #14 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 627885 Status: Offline Thanks Meter: 27 | K800i CID53 using version 1.10 without flashing Very fast!! Code: 21:33:18 SE A1 Java Unlocker v1.10 by Cruiser Team 21:33:18 Initializing... ! 21:33:18 1. Choose the phone model ! 21:33:18 2. Select main firmware flash file (*.a1sw) ! 21:33:18 3. Select raw FS flash file (*.a1fs) ! 21:33:18 4. Please connect the phone while holding its C button… 21:40:57 Connecting via SEMC USB Flash Device (USB2)… 21:40:57 Device driver version: 2.0.0.4 21:40:57 Device driver date: 9-12-2007 21:40:58 Connecting to the baseband CPU... 21:40:58 Entering baseband CPU service mode... 21:40:58 Detected chipset: DB2020 21:40:58 Boot mode: EROM 21:40:58 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 21:40:58 Initializing flash files... 21:41:04 Sending loader... 21:41:04 Sending loader... 21:41:04 Sending loader... 21:41:06 System starting up... 21:41:06 GDFS starting up... 21:41:20 FS starting up... 21:41:32 FS data uploading... ! 21:41:41 1. Please disconnect battery and cable from the phone! ! 21:41:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 21:41:41 3. Connect the phone again ! 21:41:41 4. If asked, Install phone drivers ! 21:41:41 5. Choose 'PHONE MODE' in the phone ! 21:42:38 After choosing 'PHONE MODE' press the 'Ready' button 21:42:44 Connecting via SEMC WMC Device (COM54, COM53)… 21:42:44 Device driver version: 4.40.2.0 21:42:44 Device driver date: 4-3-2007 ! 21:42:51 1. Please disconnect battery and cable from the phone! ! 21:42:51 2. Please connect the phone while holding its C button… 21:43:12 Connecting via SEMC USB Flash Device (USB2)… 21:43:12 Device driver version: 2.0.0.4 21:43:12 Device driver date: 9-12-2007 21:43:13 Connecting to the baseband CPU... 21:43:13 Entering baseband CPU service mode... 21:43:14 Detected chipset: DB2020 21:43:14 Boot mode: EROM 21:43:14 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 21:43:14 Sending loader... 21:43:15 Sending loader... 21:43:15 About to flash 1 MB of data… 21:43:28 Done. ! 21:43:28 1. Please disconnect battery and cable from the phone! ! 21:43:28 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 21:43:28 3. Go to Entertainment and select Games. ! 21:43:28 4. Delete executor file. ! 21:43:28 5. Turn off the phone |
06-18-2008, 10:24 | #15 (permalink) |
Banned Join Date: Sep 2004 Location: msaken Age: 43
Member: 82201 Status: Offline Sonork: 1576982 Thanks Meter: 32 | SUCCESSFUL UNLOCK K320 THX CRUISER TEAM Code: 11:05:51 SE A1 Java Unlocker v1.10 by Cruiser Team 11:05:51 Initializing... ! 11:05:51 1. Choose the phone model ! 11:05:51 2. Select main firmware flash file (*.a1sw) ! 11:05:51 3. Select raw FS flash file (*.a1fs) ! 11:05:51 4. Please connect the phone while holding its C button… 11:06:06 Connecting via SEMC USB Flash Device (USB1)… 11:06:06 Device driver version: 1.1.0.12 11:06:06 Device driver date: 9-25-2006 11:06:06 Connecting to the baseband CPU... 11:06:06 Entering baseband CPU service mode... 11:06:06 Detected chipset: DB2012 11:06:06 Boot mode: EROM 11:06:06 EROM version: R3A017 prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB 11:06:06 Initializing flash files... 11:06:10 Sending loader... 11:06:11 Sending loader... 11:06:11 About to flash 29 MB of data… 11:09:45 Sending loader... 11:09:48 System starting up... 11:09:48 GDFS starting up... 11:10:08 FS starting up... 11:10:34 FS data uploading... ! 11:10:39 1. Please disconnect battery and cable from the phone! ! 11:10:39 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 11:10:39 3. Wait to customize finish ! 11:10:39 4. Turn off the phone ! 11:10:39 5. Please connect the phone while holding its C button… 11:13:59 Connecting via SEMC USB Flash Device (USB1)… 11:13:59 Device driver version: 1.1.0.12 11:13:59 Device driver date: 9-25-2006 11:13:59 Connecting to the baseband CPU... 11:13:59 Entering baseband CPU service mode... 11:14:00 Detected chipset: DB2012 11:14:00 Boot mode: EROM 11:14:00 EROM version: R3A017 prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB 11:14:00 Sending loader... 11:14:00 Sending loader... 11:14:00 Sending loader... 11:14:03 System starting up... 11:14:03 GDFS starting up... 11:14:26 FS starting up... 11:14:35 FS data uploading... ! 11:14:44 1. Please disconnect battery and cable from the phone! ! 11:14:44 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 11:14:44 3. Connect the phone again ! 11:14:44 4. If asked, Install phone drivers ! 11:14:44 5. Choose 'PHONE MODE' in the phone ! 11:15:56 After choosing 'PHONE MODE' press the 'Ready' button 11:15:58 Connecting via SEMC WMC Device (COM58, COM57)… 11:15:58 Device driver version: 4.34.0.2705 11:15:58 Device driver date: 7-13-2006 ! 11:16:05 1. Please disconnect battery and cable from the phone! ! 11:16:05 2. Please connect the phone while holding its C button… 11:16:15 Connecting via SEMC USB Flash Device (USB1)… 11:16:15 Device driver version: 1.1.0.12 11:16:15 Device driver date: 9-25-2006 11:16:15 Connecting to the baseband CPU... 11:16:15 Entering baseband CPU service mode... 11:16:15 Detected chipset: DB2012 11:16:15 Boot mode: EROM 11:16:15 EROM version: R3A017 prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB 11:16:15 Sending loader... 11:16:16 Sending loader... 11:16:17 About to flash 1 MB of data… 11:16:31 Done. ! 11:16:31 1. Please disconnect battery and cable from the phone! ! 11:16:31 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 11:16:31 3. Go to Entertainment and select Games. ! 11:16:31 4. Delete executor file. ! 11:16:31 5. Turn off the phone |
Post here successfully unlocked phones by Nero-Key | mikolaj | NEROkey | 45 | 11-23-2011 20:48 |
Please Post Here SuccessFully Unlock Phones With Samsung Rocker | MOBIL CLINIC | Rocker Dongle (By Legija) | 1 | 11-22-2009 20:24 |
Please Post Here SuccessFully Unlock Phones With Spt-Box | MOBIL CLINIC | SPT BOX | 1 | 11-01-2009 18:41 |
Post here Successfully unlocked phones by free patches | reactos | Sony Ericsson | 3 | 01-10-2008 22:06 |
