10-26-2005, 16:06 | #18 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: PL Age: 41
Member: 5268 Status: Offline Thanks Meter: 24 | Quote:
10-27-2005, 02:40 | #19 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | Quote:
i done on K700i and S700i.. 100% once again big thanks to Lead | |
10-27-2005, 04:11 | #20 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 53
Member: 1841 Status: Offline Thanks Meter: 469 | The correct sequence is: 1. Convert to brown if CID=36 or CID=37, otherwise do nothing. 2. Disable OTP IMEI check. 3. Write GDFS IMEI. The step #2 may be performed at any time, i.e. before converting to brown or after writing GDFS IMEI. |
01-13-2006, 20:46 | #23 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | bep-bep: See the search button? Often if you put error messages in there, you'll get an answer. In this case that's true, this questions has been asked many times but hell, why not repeat the answer one more time. V7.x has a bug with SEMC flash patching. Use v6.10 until this bug is fixed. |
i have flshed twice w995 to remover the security code not workin how should i do | observer123 | Sony Ericsson | 3 | 07-25-2009 17:31 |
***k310a Warning! OTP IMEI, and GDFS IMEI are not the same!*** | plopez | Universalbox | 11 | 11-27-2008 23:08 |
OTP Imei locked! How to remove? | hungco | Smart-Clip | 3 | 08-04-2007 09:04 |
k750 otp imei and gdsf imei not same! | ntrkulja | Universalbox | 1 | 08-29-2006 13:29 |
Disable OTP IMEI check not working :( | qwerthj | Cruiser Suite | 19 | 05-04-2006 10:56 |
