01-06-2006, 17:43 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | w600i network problem after unlock "no network coverage." sometimes phone finds network but signal is very low and fluctuates but still can't make any calls. sometimes i see "no access to network" message. how do i solve this problem? Version 7.15 beta ready! Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! Sending applet body... Time spent entering bootstrap: 6s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Defeating RSA protection... Defeated! Sending applet... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Red Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Analyzing firmware... Preparing to program flash... Baudrate = 921600Bd Programming flash... Time: 00:00:02 Flash process done. Turning off phone... Phone automatically detached. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Preparing to program flash... Baudrate = 921600Bd Programming flash... Time: 00:00:06 Flash process done. Reading security zone... Unlocking phone... Recalculating CRCs... Phonecode: 0000 (default) Turning off phone... Phone automatically detached. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. All threads terminated. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. All threads terminated. Connecting via Fighter USB Cable... Powering on the phone... All threads terminated. Connecting via Fighter USB Cable... Powering on the phone... All threads terminated. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. All threads terminated. |
01-07-2006, 14:16 | #5 (permalink) |
Member: 28559 Status: Offline Thanks Meter: 85 | the band lock option is greyed out when conect with normal boot, band lock writing is only enabeled when i connect via testpoint but when i try to write band lock nothing happens. i converted back to brown and also unlock rsa but still can't write band lock. i think that i have damage gdfs. how do i fix? |
01-08-2006, 14:49 | #6 (permalink) |
Member: 28559 Status: Offline Thanks Meter: 85 | i flashed phone main plus fs and i wrote full gdfs W600i_FullGDFS_Brown49.cw6sw that i downloaded from support then direct unlock phone. but phone still can't make calls. i also tried format to security area and recalc security area and rewrite bandlock but nothing happens when i click on "write security zone" why? any suggestions? Last edited by gorgans; 01-08-2006 at 16:22. |
01-08-2006, 16:22 | #7 (permalink) | |
Freak Poster Join Date: Dec 2005
Member: 210229 Status: Offline Thanks Meter: 12 | I don't have a W600 so don't know ~ But should there be a Secondary Certificate? Quote:
As you've done "W600i_FullGDFS_Brown49.cw6sw " might as well...
Now try SIM. Those with * are as I don't have W600 but works with K750... ...Hope you get it working ~ maybe charge it for a while before re-attempts. | |
network problem after unlocking t630 | gsmservices | Cruiser Suite | 5 | 07-29-2006 18:51 |
sharp 903 network problem after unlocking | google_uk | Sharp 3G (USB-Smart) | 3 | 07-04-2006 19:17 |
V800 Network Problems After Unlock | mamanacusa | HWK | 0 | 12-09-2005 14:20 |
Z1010 network problems after unlock | osama | HWK | 8 | 10-15-2005 19:48 |
Z1010 network problems after unlock with multiserver | dsimka | TOTAL MultiServer | 13 | 08-06-2005 17:40 |
