02-04-2006, 11:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Peh Bhooti, Pakistan Age: 41
Member: 49896 Status: Offline Thanks Meter: 14 | Why my K750i has 4 locks closed after IMEI change how do i get around this?? |
02-04-2006, 11:51 | #2 (permalink) |
Registered User Join Date: Jul 2005
Member: 166406 Status: Offline Thanks Meter: 3 | You'll have to flash the phone and check "Disable OTP IMEI check" before changing the IMEI, or else the phone security area gets "corrupted", resulting in a four-lockdown. There must be consistancy between the phones IMEI and the lock-codes. |
02-05-2006, 13:08 | #4 (permalink) |
Member: 49896 Status: Offline Thanks Meter: 14 | Guys i have flashed my K750i with the main and raw FS and now when i switch my phone it says please wait and then it just stays there, what shall i do?? |
02-05-2006, 13:25 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | You shall direct unlock it, is what you shall do. If that does not work, you shall use the search button, I know this has been the discussed many the time. |
02-05-2006, 13:35 | #6 (permalink) |
Member: 166406 Status: Offline Thanks Meter: 3 | OK, let me explain the procedure in crayon: 1: Convert the phone to BROWN36. 2: Flash the phone with the latest available firmware (Just flash both Main+Raw) with "Disable OTP..." checked. 3: You now need to recreate the phones security area, this is done in the "Security AVR" tab. Enter the desired IMEI in the proper field and press "Write...". This will also unlock the phone if you don't play around with the settings. 4: Convert the phone back to RED36. Presto, you now have an unlocked K750 with the IMEI of your choice. |
02-05-2006, 13:43 | #8 (permalink) | |
Major Poster Join Date: Aug 2003 Location: Slovakia Age: 50
Member: 37180 Status: Offline Thanks Meter: 0 | Quote:
use cruiser version 6.10 britva | |
02-05-2006, 13:43 | #9 (permalink) | |
Member: 166406 Status: Offline Thanks Meter: 3 | Quote:
02-05-2006, 15:48 | #12 (permalink) |
Member: 49896 Status: Offline Thanks Meter: 14 | Guys i give up this version of Cruiser is completly **** I have done everything possible flash main , raw, customize and shutdown fs, write security zone, direct unlock, disable OTP IMEI, convert to phone brown n still 4 locks closed. I had no problems with version 6.1 but that has expired. Lead sort it out cus u cant blame the phone for this |
02-06-2006, 12:03 | #14 (permalink) |
Member: 49896 Status: Offline Thanks Meter: 14 | I did quite a few with version 6.1 and that never had a problem but is there a way i can re-install version 6.1 on my comp without getting the time expiry message? |
02-06-2006, 13:39 | #15 (permalink) | |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Quote:
T230 4 locks closed after div 8.4!!! | .:SkiR:. | Sony Ericsson | 4 | 01-07-2004 09:32 |
4 Locks Closed after Rebuild SP from OTP Imei | Kenas | Sony Ericsson | 11 | 11-26-2003 12:09 |
T68 4 Locks Closed After Reset Gdfs Help Please!!! | XenKo78 | Sony Ericsson | 8 | 09-15-2002 12:43 |
5110i (NSE-2) 4-locks closed after nk_calc & rolis soft | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 04-04-2002 17:13 |
Another Solution For Rom3 All 4 Locks Closed After Dejan......also Tested.... | Abe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 03-03-2002 02:34 |
