06-07-2010, 22:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | connection points for all eeprom IBM ThinkPad A2* Series you treat it as a 24RF08 Includes A20m A20p A21m A21p A22m A22p Locating the A2* series connection points
The Following 6 Users Say Thank You to ABOUSHADY For This Useful Post: |
06-07-2010, 22:15 | #2 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | 390 390E 390X you treat it as a 24RF08 Locating the 390 series connection points
The links above are to the IBM/Lenovo site, if it doesn't work, don't panic, it isn't broken, their site is shut down daily for maintenance and at those times they display spurious messages like the page you requested cannot be found, wait a good while and try again.Using the HMM link above, once you select a model and are on the page that has the PDF HMM for that model, it is best to right click on the PDF HMM for your model then select Save Target AS, that way you will have the PDF HMM on your PC to refer to any time you need it. Locating the eeprom
The Following 5 Users Say Thank You to ABOUSHADY For This Useful Post: |
06-07-2010, 22:20 | #3 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | 600 EEPROM you treat it as a 24C01 Locating the TP 600 eeprom
06-07-2010, 22:25 | #4 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | 600e EEPROM you treat it as a 24RF08 Locating the eeprom
06-07-2010, 22:29 | #5 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | 600x EEPROM you treat it as a 24RF08 Locating the eeprom
06-07-2010, 22:32 | #6 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | A30 A30p A31 A31p you treat it as a 24RF08 Locating the A30 series connection points
06-07-2010, 22:45 | #8 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | R40 EEPROM you treat it as a 24RF08 Locating the R40 connection pointsSwitch the R40 OFF. You should have downloaded the hardware Maintenance Manual already, if you have not done so, Determine which model R40 you have, the Model number can be found on a Label underneath your TR40 Find your model then click on the appropriate hyperlink below to download the PDF file containing the R40 Hardware Maintenance Manual, you will need to install Adobe Acrobat Reader to view the manual, Adobe Acrobat is FREE and can be obtained here -> Adobe Downloads once you have downloaded the files, close the browser window to return to this page. R40 Hardware Maintenance Manuals
Once you have your HMM search the manual for "Removing and replacing a FRU" then scroll down to System Board, follow the instructions in the manual to remove all the other FRUs to gain access to and remove the System Board. R40You need to access the 8 pin chip ATMEL 24RF08, there are a few versions of the R40, your board may not have the 24RF08 exactly in the location show, however it will be a 24RF08 in roughly that location Keep individual modules and their screws separate to make it easier to re assemble it correctly |
06-07-2010, 22:49 | #9 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | R50 and R51 EEPROM you treat it as 24RF08 Locating the R50 or R51connection points
06-07-2010, 22:58 | #10 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | R52 EEPROM you treat it as LSI ---------R52 Password recovery procedure ---------- Locating the R52 connection points
06-07-2010, 23:06 | #11 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | R60 you treat as EEPROM Type LSI ----------R60 Password recovery procedure ---------- |
06-07-2010, 23:09 | #12 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | Locating the R61 connection points
06-07-2010, 23:14 | #13 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | R400 EEPROM you treat it as a 24RF08 Locating the R400 connection points
06-07-2010, 23:18 | #14 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | T20 T21 T22 T23 EEPROM you treat it as a 24RF08 Locating the T20 series connection points
Using the HMM link above, once you select a model and are on the page that has the PDF HMM for that model, it is best to right click on the PDF HMM for your model then select Save Target AS, that way you will have the PDF HMM on your PC to refer to any time you need it.The link above is to the IBM/Lenovo site, if it doesn't work, don't panic, it isn't broken, their site is shut down daily for maintenance and at those times they display spurious messages like the page you requested cannot be found, wait a good while and try again. Locating the eeprom
06-07-2010, 23:22 | #15 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | T30 EEPROM you treat it as 24RF08 Locating the T30 connection points
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
