Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
10-30-2002, 03:16 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | Rssi iam wondering about RSSI (Return Strenght Signal Indicator) values. Its easy to read in Wintesla but what do the values mean & how can they help us? If anybody knows what are the range of values & what they mean. ie -120 = faulty ??? -110 = Normal range - 80 = VCO problem???? If anybody knows what fault causes incorrect values, could they please respond. Thanks!! |
10-30-2002, 07:55 | #2 (permalink) |
No Life Poster Join Date: Mar 2002 Location: khonkean,thailand
Member: 10084 Status: Offline Thanks Meter: 283 | wow good idea this test by me me -113-118 db is good work -80 db check C508 -85-87 db clean and rehot HARGAR -73-75 db clean and rehot COBBA -140 db clean and rehot COBBA i try test without VCO all vale not change this i can't solve it -91 db can't recieve and transmit any band -148 db can't recieve and transmit any band -112 db recieve ok but can't transmit any band i change CCONT,COBBA,HARGAR,26Mhz,VCO but not help .now i waiting for Mr.willy (best for nokia repair)reply more info by willy (see page2) Last edited by SE-THAILAND; 10-30-2002 at 08:13. |
10-31-2002, 06:50 | #7 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | DREAMGSM use search old post in forum will help and use oscilloscope to measure Hager to COBBA ( make sure which part is problem ) RX IP/QP signal , then you will see is it correct and balance ! Willy |
11-11-2002, 18:28 | #9 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | Hakika, "write" correct values to ME ! Wintesla has RX caibrition , it need signal generator to provide a standard signal and level to phone ( like for GSM at CH 60 947.06771Mhz and level -55 and -80 dbm) , and let ME to "learn" what is correct level ! if phone function correctly, then that two different level will be A/D convert and save to eeprom ! Willy |
Low RSSI reading ?!?!?!?! | unlockphone | Nokia Hardware & Hardware Repair | 3 | 04-14-2003 10:35 |
read rssi dct4... | bigcservice | GSM Programming & Reverse Engineering | 1 | 03-15-2003 12:16 |
5110 RSSI reading | insidebga | Nokia Hardware & Hardware Repair | 1 | 01-04-2003 16:31 |
RSSI reading. | sjakie | Nokia Hardware & Hardware Repair | 8 | 12-13-2002 00:05 |
Please help with RSSI Reading | mujie | Nokia Hardware & Hardware Repair | 3 | 11-05-2002 17:00 |
