Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
12-18-2002, 21:39 | #3 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | Is there any differance between AMD and Intel? Both of them manufacture Flashes and CPUs. But the way acting with them is different. About PAs: you should do calibration. |
12-19-2002, 06:52 | #6 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | To B0ba ---> whay do calibraion ...? To Culibin ---> goto mobile-tech.net ...! To Scaramouche ---> which resistor shall i change/why...?and from where can i get resistors for nokia phones ..? |
12-19-2002, 20:51 | #8 (permalink) |
Freak Poster Join Date: Aug 2002 Location: __inside__ Age: 41
Member: 14792 Status: Offline Thanks Meter: 1 | .............3310(NHM-5)................. for pcb ver.up to 09:RFMD add R312 del R311...philips del R312 add R311....hitachi del R312,R311... for pcb ver.10 and later:RFMD mounted R312,R311...philips mounted R311....hitachi mounted R312...hope that helps you... __jero__ |
12-21-2002, 10:16 | #12 (permalink) |
Member: 14792 Status: Offline Thanks Meter: 1 | @raheeeeb yes,look at key side of pcb as Scaramouche said.. @MrHazeem for hardware changing of pcb for pa..i mean replacing hitachi pa. instead of philips pa.or replacing philips pa. instead of rfmd... __jero__ |
12-21-2002, 20:23 | #14 (permalink) |
Member: 6772 Status: Offline Thanks Meter: 17 | Becouse: different PAs use different Output Power control levels. So to calibrate the PA's output level especially in nokia where the PA's output level is controlled by HAGAR IC you need to change the resistor(s) to tell the phone what type of PA is used. Regards |
12-21-2002, 20:33 | #15 (permalink) |
Member: 13545 Status: Offline Thanks Meter: 2 | Ok ... I understand.... , but if we did not change these resistors how this will effect the phone ...? in other words what will happen to the phone ...is it going to show signal bar or it will droped after 3 sec ...?Or phone will be No Coverage all the time ...? |
How to Register my smatclip,S Card & Scout | makasa | Smart-Clip | 1 | 03-29-2010 12:11 |
Furious 1 & 2 Dongle & Phillips Delok | fonetech | Sell ur Old and Used Stuff | 5 | 09-09-2005 19:32 |
Cobba's Pa's Resistors etc, where from? | Fasterbaby | Hardware Repair Item Wanted | 1 | 03-01-2003 20:51 |
SPARE PA's FOR REPAIRING "NO ACCESS? | dannyogolo | Sony Ericsson Hardware Repair | 6 | 01-24-2003 13:07 |
Phillips Diga & Spark | datalife2000 | Philips | 5 | 03-06-2002 11:30 |
