Hardware Repair by brands All about hardware problems sorted by brands inside subsections. |
08-11-2002, 01:53 | #1 (permalink) |
Insane Poster Join Date: Apr 2002 Location: Denmark
Member: 10692 Status: Offline Thanks Meter: 0 | Reballing uBGA? - HOW? Please shoe us step by step for changing uBGAs. Many thanks |
08-11-2002, 08:08 | #4 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: Reballing uBGA? - HOW? AlQuds , If your BGA chip has no glue, then you try to put enough flux to put under BGA chip, then exercise many time, try to remove BGA chip, and detain all ball in PCB! for you reball to chip, i think, use 0.5 mm bga ball for CCONT, COBBA, Hager , even CPU ! please do not use tin paste ....it make ball different size ! Willy Quote:
08-15-2002, 22:33 | #5 (permalink) |
Member: 10692 Status: Offline Thanks Meter: 0 | Hello Willy How to get these 0.5 mm bga ball. I have the mask to make balls with tin paste. But I new to it and could not do it well. Any instructions to do a good reballed BGA? Thanks for your help |
08-16-2002, 08:39 | #6 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Alquds, You can try to check : http://www.alphametals.com i order 0.5 mm ball from them they also have some instructions to do ! Willy Quote:
Reballing IC Method / Flash IC Reballing (for beginers) **** | khem | Nokia Hardware & Hardware Repair | 17 | 08-16-2010 20:30 |
ubga reball kit wanted | VELIKI | Wanted Products | 0 | 08-04-2007 15:11 |
ubga reball kit need | VELIKI | Hardware Repair Item Wanted | 1 | 07-22-2007 12:19 |
How to Reball? | feverdj | Nokia Hardware & Hardware Repair | 4 | 10-12-2003 04:49 |
I need PROFESSIONAL uBGA reballing kit!!! | XenKo78 | Wanted Products | 1 | 07-01-2003 02:04 |
