Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPGIndustries Cables > GPGUFC - The best Universal Fbus Cables ever made
Old 08-27-2009, 17:26   #1 (permalink)
Member: 295102
Thanks Meter: 9
6700c pinout needed
Can anyone please highlight me the pinouts needed for flash on 6700c as seen on picture below and what UFC cable and resistor setting to use ?
Many thanks in advance!
S.
Old 08-27-2009, 19:20   #2 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
Here you go brother
pinout is :
1 - rxd1 - tx2
2 - rxd0 - tx
3 - gnd - gnd
4 - clk - mbus
5 - clk2 - mbus
6 - txd - rx
Battery connector here. Pin 1 on the top right.
There is only a small secret.
MBus line must be connected to both 4 & 5 pins
If you like my post don't forget to hit
The Following 42 Users Say Thank You to gsmpointhrp For This Useful Post:
Old 08-29-2009, 19:11   #3 (permalink)
Member: 295102
Thanks Meter: 9
Thanks for the pinouts itsmesoul! Really appreciate it.
I have J.A.F. box with original J.A.F UFC and tried to connect with cable No. 2 as seen on picture below with resistor value of 7.5k but for some reason J.A.F does not see the phone.
You mentioned that "MBus line must be connected to both 4 & 5 pins"
My question is. Does this cable supports that cross-connection already, or I have to do it manually ???
The Following User Says Thank You to sasovics For This Useful Post:
Old 08-29-2009, 20:01   #4 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
You must build a small adapter using a bit of lan cable and an RJ45 socket.
This pinouts doesn't exist in the UFC set
here the list of the jig's pinouts
Alex
The Following 3 Users Say Thank You to moulnisky For This Useful Post:
Old 08-30-2009, 15:15   #5 (permalink)
moulnisky's Avatar
Member: 947561
You can use for the job the Jig n. 1.
Considering the pin 1 of the jig is not connected you can cut it off (i did as well cos help me to understand where is the pin 1 )
then you can make the adaptor using a plug RJ45 and a socked RJ45 (Used a bit of Lan cable and a normal socket easy to find in any computer shop)
schematic :
Plug RJ45 Socket RJ45
1 ----------------- 2
2 ----------------- 1
4 ----------------- 8
5 -------------- 4 and 5
6 ----------------- 6
this adapter must be used netween the Jig and the UFC
Just for the user curiousity the pinouts of the UFC Jig socket RJ 48 are
1 - NC
2 - GND
3 - (F) RX
4 - NC
5 - (F) TX
6 - MBUS
7 - (F) RX2
8 - NC
9 - VPP (only if connected to MT or Genie)
10 - NC
Alex
The Following 5 Users Say Thank You to moulnisky For This Useful Post:
Old 08-31-2009, 23:10   #6 (permalink)
Member: 295102
Thanks Meter: 9
itsmesoul is also mentioning a 68k resistor between GND and BSI. Now how would I utilize this with my UFC cable ???
Old 09-01-2009, 02:44   #7 (permalink)
moulnisky's Avatar
Member: 947561
the 68kohm resistor is already in the ufc.. you must just set the BSI to 7.5.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 09-01-2009, 18:28   #8 (permalink)
Member: 295102
Thanks Meter: 9
Would anyone please provide the RJ45 (not RJ48) pinouts for UFC and JAF cable ?
I modded my cable as follows:
TX2    - PIN6 (RJ45)
TX     - PIN4 (RJ45)
GND    - PIN1 (RJ45)
MBUS   - PIN5 (RJ45)
MBUS   - PIN5 (RJ45)
RX     - PIN2 (RJ45)
However JAF is still unable to communicate. I set BSI resistor to 7.5K
Old 09-01-2009, 19:22   #9 (permalink)
Member: 295102
Thanks Meter: 9
Update: I am using JAF's UFC, meaning cable pinouts my vary from the original UFCv1 or v2. So here's the RJ45 pinout connectivity that goes directly to JAF box:
JIG2            RJ45 (JAF side)
Pin 1. TX2    - PIN8
Pin 2. TX     - PIN4
Pin 3. GND    - PIN7
Pin 4  MBUS   - PIN6
Pin 5. MBUS   - PIN6
Pin 6. RX     - PIN5
I tested it with other cables and the RJ45 pinouts on JAF side match. What am I doing wrong then ???
Old 09-01-2009, 22:52   #10 (permalink)
moulnisky's Avatar
Member: 947561
swap TX and RX.. sometime there is a bit of confusion if the name refer to the box RX of the mobile RX
Alex
Old 09-01-2009, 23:11   #11 (permalink)
Member: 295102
Thanks Meter: 9
I actually did, as you can see on post #2 the picture refers to RX2, RX on pins (1,2) and my cable to TX2, TX (same pins). Also pin 6 on schematic says TX while mine on cable is RX... Dunno where might be the problem.
Could be that I burned the FBUS circuit in the phone ? Before I knew that the pinouts of Jig 2 are completely different from actual phone's pinouts as seen on post #2 I tried to make connection with JAF. Obviously this did not work. Could the original Jig 2 pinouts burn the FBUS circuitry ????
Old 09-02-2009, 03:58   #12 (permalink)
moulnisky's Avatar
Member: 947561
I don't think it could be as the VPP is not used in the n. 2 by Jaf..
Anyway if you check the JAf pinouts:
Pin5=Phone RX
Pin4=phone TX
Pin8=phone rx2
so the wiring is wrong and you should swap TX and RX
Alex
Old 09-02-2009, 04:02   #13 (permalink)
Member: 295102
Thanks Meter: 9
Oh, I forgot to mention. The phone works just fine! I just want to flash it over FBUS to a different variant
Old 09-02-2009, 07:14   #14 (permalink)
Member: 295102
Thanks Meter: 9
OK, swapping RX with TX fixed the problem! Now I am able to communicate over FBUS and possibly flash this phone (will try tomorrow). Many thanks moulnisky, you did really help!
Old 09-02-2009, 07:23   #15 (permalink)
moulnisky's Avatar
Member: 947561
You are wellcome
Alex
6700c Pinout wanted!!! freaky Chinese Models & Cloned Phones 1 03-17-2010 13:38
Erase file 6700c in need...pls help ! riah Nokia Base Band 5 ( BB-5 ) 0 11-28-2009 10:57
A8+ Need help - Pinout Needed 2lits Infinity-Box 17 11-25-2009 02:36
Pinout for N95 RM-17 like origin pinout needed ..::alexis::.. Infinity-Box 7 05-09-2008 17:54
c520 pinout needed for fun Lez Motorola Old Legacy (EMMI) 0 07-03-1999 20:53
Page generated in 0.20519 seconds with 9 queries
