08-27-2009, 17:26 | #1 (permalink) |
Junior Member Join Date: Jun 2006
Member: 295102 Status: Offline Thanks Meter: 9 | 6700c pinout needed Many thanks in advance! S. |
08-27-2009, 19:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Here you go brother pinout is : 1 - rxd1 - tx2 2 - rxd0 - tx 3 - gnd - gnd 4 - clk - mbus 5 - clk2 - mbus 6 - txd - rx Battery connector here. Pin 1 on the top right. There is only a small secret. MBus line must be connected to both 4 & 5 pins If you like my post don't forget to hit |
The Following 42 Users Say Thank You to gsmpointhrp For This Useful Post: |
08-29-2009, 19:11 | #3 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | Thanks for the pinouts itsmesoul! Really appreciate it. I have J.A.F. box with original J.A.F UFC and tried to connect with cable No. 2 as seen on picture below with resistor value of 7.5k but for some reason J.A.F does not see the phone. You mentioned that "MBus line must be connected to both 4 & 5 pins" My question is. Does this cable supports that cross-connection already, or I have to do it manually ??? |
The Following User Says Thank You to sasovics For This Useful Post: |
08-29-2009, 20:01 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You must build a small adapter using a bit of lan cable and an RJ45 socket. This pinouts doesn't exist in the UFC set here the list of the jig's pinouts BR Alex |
The Following 3 Users Say Thank You to moulnisky For This Useful Post: |
08-30-2009, 15:15 | #5 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You can use for the job the Jig n. 1. Considering the pin 1 of the jig is not connected you can cut it off (i did as well cos help me to understand where is the pin 1 ) then you can make the adaptor using a plug RJ45 and a socked RJ45 (Used a bit of Lan cable and a normal socket easy to find in any computer shop) schematic : Plug RJ45 Socket RJ45 1 ----------------- 2 2 ----------------- 1 4 ----------------- 8 5 -------------- 4 and 5 6 ----------------- 6 this adapter must be used netween the Jig and the UFC Just for the user curiousity the pinouts of the UFC Jig socket RJ 48 are 1 - NC 2 - GND 3 - (F) RX 4 - NC 5 - (F) TX 6 - MBUS 7 - (F) RX2 8 - NC 9 - VPP (only if connected to MT or Genie) 10 - NC BR Alex |
The Following 5 Users Say Thank You to moulnisky For This Useful Post: |
08-31-2009, 23:10 | #6 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | itsmesoul is also mentioning a 68k resistor between GND and BSI. Now how would I utilize this with my UFC cable ??? |
09-01-2009, 02:44 | #7 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | the 68kohm resistor is already in the ufc.. you must just set the BSI to 7.5. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-01-2009, 18:28 | #8 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | Would anyone please provide the RJ45 (not RJ48) pinouts for UFC and JAF cable ? I modded my cable as follows: Code: TX2 - PIN6 (RJ45) TX - PIN4 (RJ45) GND - PIN1 (RJ45) MBUS - PIN5 (RJ45) MBUS - PIN5 (RJ45) RX - PIN2 (RJ45) |
09-01-2009, 19:22 | #9 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | Update: I am using JAF's UFC, meaning cable pinouts my vary from the original UFCv1 or v2. So here's the RJ45 pinout connectivity that goes directly to JAF box: Code: JIG2 RJ45 (JAF side) Pin 1. TX2 - PIN8 Pin 2. TX - PIN4 Pin 3. GND - PIN7 Pin 4 MBUS - PIN6 Pin 5. MBUS - PIN6 Pin 6. RX - PIN5 |
09-01-2009, 22:52 | #10 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | swap TX and RX.. sometime there is a bit of confusion if the name refer to the box RX of the mobile RX BR Alex |
09-01-2009, 23:11 | #11 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | I actually did, as you can see on post #2 the picture refers to RX2, RX on pins (1,2) and my cable to TX2, TX (same pins). Also pin 6 on schematic says TX while mine on cable is RX... Dunno where might be the problem. Could be that I burned the FBUS circuit in the phone ? Before I knew that the pinouts of Jig 2 are completely different from actual phone's pinouts as seen on post #2 I tried to make connection with JAF. Obviously this did not work. Could the original Jig 2 pinouts burn the FBUS circuitry ???? |
09-02-2009, 03:58 | #12 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | I don't think it could be as the VPP is not used in the n. 2 by Jaf.. Anyway if you check the JAf pinouts: Pin5=Phone RX Pin4=phone TX Pin8=phone rx2 so the wiring is wrong and you should swap TX and RX BR Alex Last edited by moulnisky; 09-02-2009 at 04:04. |
09-02-2009, 04:02 | #13 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | Oh, I forgot to mention. The phone works just fine! I just want to flash it over FBUS to a different variant |
09-02-2009, 07:14 | #14 (permalink) |
Member: 295102 Status: Offline Thanks Meter: 9 | OK, swapping RX with TX fixed the problem! Now I am able to communicate over FBUS and possibly flash this phone (will try tomorrow). Many thanks moulnisky, you did really help! |
6700c Pinout wanted!!! | freaky | Chinese Models & Cloned Phones | 1 | 03-17-2010 13:38 |
Erase file 6700c in need...pls help ! | riah | Nokia Base Band 5 ( BB-5 ) | 0 | 11-28-2009 10:57 |
A8+ Need help - Pinout Needed | 2lits | Infinity-Box | 17 | 11-25-2009 02:36 |
Pinout for N95 RM-17 like origin pinout needed | ..::alexis::.. | Infinity-Box | 7 | 05-09-2008 17:54 |
c520 pinout needed for fun | Lez | Motorola Old Legacy (EMMI) | 0 | 07-03-1999 20:53 |
