09-07-2009, 01:56 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: tunisia Age: 64
Member: 12001 Status: Offline Thanks Meter: 3 | UFC Cable not working on UFS box On JAF box the set work perfectly, but on UFS not work. So JAF box is dead and i want to use my old UFS. i must perhaps use an adapter, if some one have schematic, please post here. thanks |
09-07-2009, 03:02 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Hi, UFC works in UFS, i using it with my N-Box and not need any adapter... it works with DCT-4 & BB5 (tested 6131, 5200, N80, E71, 1208, 6103, 6230 etc ) maybe your UFS HW fault BR |
09-07-2009, 22:10 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | jaf and ufs have same rj45 socket = unibox pinouts ==> UFC cables work great in both box's. Tested many times by peoples all over the world including me br, free1600 |
09-07-2009, 23:40 | #5 (permalink) |
Member: 12001 Status: Offline Thanks Meter: 3 | when i clic CHECK on JAF software, the result is : Booting phone... Error sync the phone... Booting phone... Error sync the phone... Booting phone... Error sync the phone... I tryed to change the resistor from 3,3 KOhm to 10 KOhm no change but whene i clic INF in JAF software, the result is OK : FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v38.2 27-03-07 RM-133 (c) Nokia. HW version: 6012 PCI version: RFIC version: 17191719 DSP version: scarfe_05wk46v41p1 Retu version: 15 Tahvo version: 21 Production serial number: SAL829636 Product code: 0539101 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35275701xxxxxxxx IMEI spare to net: 3A 25 57 07 31 09 39 04 IMEI SV to net: 33 25 57 07 31 09 39 24 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0539101 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ Searching for default location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_4.0812.4.0.1_western_C00_PRD_cc.fpsx PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_4.0812.4.0.1_PRD.V08 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_4.0812.4.0.1.U01 APE Variant file: NONE Languages in ppm: English,Arabic,French Done! I think i must modify the UFC set to work with UFS box, because UFS box no need to insert a resistor between GND and BSI. Before whene the JAF box working, whene i use a normal cable, work fine with UFS box but with JAF i must insert an adapter with resistor to work. I think i must remove the resistor. What you think ? thanks |
09-10-2009, 15:47 | #6 (permalink) |
Member: 12001 Status: Offline Thanks Meter: 3 | Solved with this : http://forums.****************/showthread.php?t=11945 |
scdr2 x-5 cable not working on v55 | shruti | SagMaster Team OLD Products | 1 | 12-15-2006 06:07 |
3100 cable won't work on ufs box | Black-Axe | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 08-01-2005 10:14 |
4in1 uc-10 cable not work on Sharp 902? | Raklm | Cruiser Suite | 7 | 07-17-2005 20:14 |
USB Cable not working on Z1010? | Pauly__86 | TOTAL MultiServer | 2 | 12-16-2004 12:19 |
