unlock HTC Touch Diamond error [SOLVED USING v1.0.2] here is log: Device Connected...Sending App... Please Push YES in You Device Screen Please Wait Black Screen... Delaying Detecting New Device...Wait... Device connected OK... <after that I reconnect and connect again Device,and when klik read code get error lile is: Searching Device... Connecting... ERROR Please Again... thanks, ps:my device HTC Touch Diamon P3700 |
I want to know,can or not unlock HTC by BB-Box..? coz.i searching no bodyone succeed unlock HTC with BB-box. |
1.- First, install ActiveSync software “Active_Sync_v45.zip” ( you can find inside /Drivers/HTC ) 2.- Remove battery of the HTC phone and put back again ( be sure battery is not empty) 3.- Press power and wait near 60 seconds for be sure power on completely ( more important ) 4.- Plug USB datacable and wait till sincronize with ActiveSync Software ( will take few seconds ) 5.- Open BB Box software, select correct model and press CONNECT BUTTON 6.- Wait few seconds, and press yes in the HTC screen when phone ask you ( if is necesary ) 7.- After press YES, wait until phone will be detected again ( you will hear windows sound ) 8.- Wait 5 seconds and press READ CODES button 9.- After few seconds, NCK and SPCK will appear in screen IF NO SUCCESS REPORT HERE WE WILL CHECK THIS ISSUE. REGARDS ««««SUUNNYY»»»» [ POLAR TEAM ] |
yes htc is supported at 100%,many test report for success unlock htc models exemple here :http://forum.gsmhosting.com/vbb/show...3&postcount=33 after u see this : Device Connected...Sending App... Please Push YES in You Device Screen Please Wait Black Screen... Delaying Detecting New Device...Wait... Device connected OK... disconnect phone,connect again then press read codes luck |
Searching Device... Connecting... ERROR Please Again... |
bRo toutou_gsm |
after disconnect and connect wait a while untill phone detected again then press read codes bRo toutou_gsm |
Thanks !! |
make sure phone is detected on computer after disconnect and connect if yes wait a while then clic read codes,u can try also by hard reset then test again |
Thanks !! |
after hard reset still same error......... |
