Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3 > 3GKey / BB-Box
Old 02-18-2010, 08:43   #1 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
unlock HTC Touch Diamond error [SOLVED USING v1.0.2]
here is log:
Device Connected...Sending App...
Please Push YES in You Device Screen
Please Wait Black Screen...
Delaying Detecting New Device...Wait...
Device connected OK...
<after that I reconnect and connect again Device,and when klik read code get error lile is:
Searching Device...
Connecting...
ERROR Please Again...
thanks,
ps:my device HTC Touch Diamon P3700
Old 02-18-2010, 09:27   #2 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
I want to know,can or not unlock HTC by BB-Box..?
coz.i searching no bodyone succeed unlock HTC with BB-box.
Old 02-18-2010, 12:06   #3 (permalink)
SUUNNYY's Avatar
Member: 885625
Sonork: 100.1589108
Thanks Meter: 2,432
Originally Posted by tuban_gsm View Post
here is log:
Searching Device...
Connecting...
thanks,
HI FRIEND PLEASE RESET YOUR DEVICE AND FOLLOW THE PROCEDURE.
1.- First, install ActiveSync software “Active_Sync_v45.zip” ( you can find inside /Drivers/HTC )
2.- Remove battery of the HTC phone and put back again ( be sure battery is not empty)
3.- Press power and wait near 60 seconds for be sure power on completely ( more important )
4.- Plug USB datacable and wait till sincronize with ActiveSync Software ( will take few seconds )
5.- Open BB Box software, select correct model and press CONNECT BUTTON
6.- Wait few seconds, and press yes in the HTC screen when phone ask you ( if is necesary )
7.- After press YES, wait until phone will be detected again ( you will hear windows sound )
8.- Wait 5 seconds and press READ CODES button
9.- After few seconds, NCK and SPCK will appear in screen
IF NO SUCCESS REPORT HERE WE WILL CHECK THIS ISSUE.
REGARDS
««««SUUNNYY»»»»
[ POLAR TEAM ]
The Following User Says Thank You to SUUNNYY For This Useful Post:
Old 02-18-2010, 12:12   #4 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
yes htc is supported at 100%,many test report for success unlock htc models exemple here :http://forum.gsmhosting.com/vbb/show...3&postcount=33
after u see this :
disconnect phone,connect again then press read codes
luck
Old 02-18-2010, 12:37   #5 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
REGARDS
««««SUUNNYY»»»»
[ POLAR TEAM ]
after step 8 still get error:
Searching Device...
Connecting...
Old 02-18-2010, 12:41   #6 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
Searching Device...
Connecting...
before step8,disconnect connect again
bRo toutou_gsm
The Following User Says Thank You to toutou_gsm For This Useful Post:
Old 02-18-2010, 12:48   #7 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
bRo toutou_gsm
yes, i do it.but result still same.
Old 02-18-2010, 12:53   #8 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
after disconnect and connect wait a while untill phone detected again then press read codes
bRo toutou_gsm
Old 02-18-2010, 13:00   #9 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
bRo toutou_gsm
after that,phone not detected by pc.
Old 02-18-2010, 13:02   #10 (permalink)
luciform's Avatar
Member: 311517
Thanks Meter: 75
Since 2 months that i bought my bb-box and i never unlock none HTC, always the same error that you wrote here, i don't know where is my mistake because i do all that support wrote and same error.
Thanks !!
Old 02-18-2010, 13:07   #11 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
Thanks !!
I don't knows,maybe software bug or really bb-box can't unlock htc device.
Old 02-18-2010, 13:13   #12 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
hi tuban_gsm:
make sure phone is detected on computer after disconnect and connect if yes wait a while then clic read codes,u can try also by hard reset then test again
Old 02-18-2010, 13:21   #13 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
hi tuban_gsm:
ok,i will try tomorrow.
Old 02-18-2010, 13:49   #14 (permalink)
luciform's Avatar
Member: 311517
Thanks Meter: 75
I will be wainting the log
Thanks !!
Old 02-18-2010, 14:02   #15 (permalink)
tuban_gsm's Avatar
Member: 589534
Thanks Meter: 251
after hard reset still same error.........
Page generated in 0.23320 seconds with 9 queries
