Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-21-2015, 11:20   #31 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Originally Posted by dazexy View Post
in my workplace i have only a dump_620_lumia if it is enough for test, i send Tv login now.
I am TV now with Product Supporter with Win 7 32-bit.
I will check the problem on his PC first.. Then I will make a new Drive32.exe for testing publicly.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 05-21-2015, 13:40   #32 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Ok
@X-Shadow so is useless send you my TV for my Win 7 to 32BIT or modific same settings of my pc....wait you new "Drive32.exe" first? is from yesterday that try to modific setting in my 32Bit Win7 but nothingh always same error: "Can't Mount".... and if i click in Help>Ceck for Updates in exFat Paragon say me of ceck my internet connection...but connection is full working...
Anyway if want to test with my PC i've 2 DUMP of I9505 that if select one of these .Bin and press Mount show all partition but cannot Mount VHD...
allumts
Old 05-21-2015, 17:43   #33 (permalink)
Member: 122442
Thanks Meter: 4
       eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
   the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010030313647393200CC8E2AC0106D
CSD : D00E00320F5903FFFFFFFFEF92400045
eMMC Boot Information
Revision 1.6 (for MMC v4.5, v4.51)
BOOT PARTITION     : BOOT PARTITION 1
PARTITION ACCESS   : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT  : DISABLED
BOOT MODE          : x8 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH    : ENABLED
eMMC FirmW UPDATE  : DISABLED
EMMC CACHE SIZE    : 0 KB
SUPER PAGE SIZE    : 4096 KB
HC ERASE GROUP SIZE: 4096 KB
USER AREA SIZE     : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 512 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type    : Embedded BGA
Application ID : 00
Product Name   : 016G92
Product Rev    : 0.0
Product SN     : CC8E2AC0
Manufactured   : January 1997
Card Specific Data
CSD_STRUCTURE     : Extended
SPEC_VERS         : Version 4.1/4.2/4.3
TAAC              : 3 ns
TRAN_SPEED        : 4000000 KHz
READ_BL_LEN       : 512 Bytes
C_SIZE            : HIGH CAPACITY
WP_GRP_ENABLE     : YES
WRITE_BL_LEN      : 512 Bytes
CONTENT_PROT_APP  : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010030313647393200CC8E2AC0106D.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Dumping Custom Region
Please wait for some time...
Partition Selected: USER AREA
(eMMC Clock 7500000 Hz)
Custom Block Read OK
File Saved: C:\AdvanceBox Turbo Flasher\eMMC\Recovered\eMMC_GPT.bin
Total Elapsed Time 00:00:00
EFI Partition Table Header
Signature: EFI PART
Revision: 0x00000100
Header Size: 0x0000005C
Header CRC32: 0x472D90DF
Reserved: 0x00000000
Current EFI Partition Header LBA: 0x0000000000000001
Backup EFI Partition Header LBA: 0x0000000001D59FFF
First Usable LBA: 0x0000000000000022
Last Usable LBA: 0x0000000001D59FFF
Disk GUID: 0x4EC3AE69485946975F0EA8D4F9F21FFF
LBA of EFI Partition Entries: 0x0000000000000002
Number of Partition Entries: 128
Size of each Parition Entry: 128
Partition Entries CRC32: 0x3AF2C0E3
Partition Name: xloader
Partition Type GUID: A2A0D0EBE5B9334487C068B6B72699C7
Unique Partition GUID: 001FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000000100
Ending LBA: 00000000000008FF
Partition Attributes: 0000000000000000
Partition Name: round
Unique Partition GUID: 011FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000000900
Ending LBA: 0000000000001FFF
Partition Name: nvme
Unique Partition GUID: 021FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000002000
Ending LBA: 0000000000003FFF
Partition Name: misc
Unique Partition GUID: 031FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000004000
Ending LBA: 0000000000005FFF
Partition Name: splash
Unique Partition GUID: 041FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000006000
Ending LBA: 0000000000009FFF
Partition Name: oeminfo
Unique Partition GUID: 051FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000000A000
Ending LBA: 0000000000019FFF
Partition Name: reserved1
Unique Partition GUID: 061FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000001A000
Ending LBA: 000000000001DFFF
Partition Name: reserved2
Unique Partition GUID: 071FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000001E000
Ending LBA: 0000000000021FFF
Partition Name: splash2
Unique Partition GUID: 081FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000022000
Ending LBA: 0000000000025FFF
Partition Name: recovery2
Unique Partition GUID: 091FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000026000
Ending LBA: 000000000002DFFF
Unique Partition GUID: 0A1FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000002E000
Ending LBA: 0000000000035FFF
Partition Name: boot
Unique Partition GUID: 0B1FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000036000
Ending LBA: 0000000000039FFF
Partition Name: modemimage
Unique Partition GUID: 0C1FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000003A000
Ending LBA: 0000000000079FFF
Partition Name: modemnvm1
Unique Partition GUID: 0D1FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000007A000
Ending LBA: 000000000007DFFF
Partition Name: modemnvm2
Unique Partition GUID: 0E1FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 000000000007E000
Ending LBA: 0000000000081FFF
Partition Name: system
Unique Partition GUID: 0F1FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000082000
Ending LBA: 0000000000381FFF
Partition Name: cache
Unique Partition GUID: 101FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000382000
Ending LBA: 0000000000401FFF
Partition Name: cust
Unique Partition GUID: 111FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000402000
Ending LBA: 0000000000501FFF
Partition Name: userdata
Unique Partition GUID: 121FF2F9D4A80E5F9746594869AEC34E
Starting LBA: 0000000000502000
Ending LBA: 0000000001D59FFF
Partition Selected: userdata
Total Blocks: 0x0000000001858000
First LBA: 0x0000000000502000
Last LBA: 0x0000000001D59FFF
Interface Reset OK!
Selected Drive Letter: E
Mounting Drive...
Failed!
same problem on Win7x64
Old 05-21-2015, 20:58   #34 (permalink)
allumts's Avatar
Member: 1564612
@X-Shadow, please meantime solving this small bug with "Drive32.exe" can abylite 3V from Pin 2 of Big Atf?,
If cannnot take out from RJ45 pin2 the 3V cannot connect VCC and VCCQ in this pinout....
allumts
Old 05-22-2015, 10:54   #35 (permalink)
lionfinger2007's Avatar
Member: 576282
Thanks Meter: 145
Originally Posted by allumts View Post
Other link working 100% by 4Shared
allumts
Nice link and with resumable. Why I need resumable is that data connection is costly in out country and the speed is as slow as snail, so you dont need to be repeating from afresh when ever the connection lost, so programmers take notice and put yourselves in other countries's *****.
The Following User Says Thank You to lionfinger2007 For This Useful Post:
Old 05-22-2015, 11:40   #36 (permalink)
Member: 122442
Thanks Meter: 4
WIN7 X64
Mount binary file
Signature: EFI PART
Mounting Drive...
Failed!
Old 05-22-2015, 11:56   #37 (permalink)
allumts's Avatar
Member: 1564612
@lionfinger2007
but you've only ever clai to do? but live happy you life and particularly NOT insult never...other country...
You will be reported for INSULTING and and you can have a bit of holiday in you BEST country not ******
Good holidays
allumts
Old 05-22-2015, 14:09   #38 (permalink)
Member: 2241654
Thanks Meter: 6
sir plz support mtk hardwere plz
Old 05-22-2015, 20:57   #39 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Sorry, I didn't found 12.31 public discussion thread, so I post experiences here.
The new bug fix was a half success for me. It can work now with dump I previously made with my advance box. It mounts great, quick, and also exploring is working. But if I connect via ISP it working really strange. I will try describe what exactly happens:
The emmc seems mount correctly, say: success! A drive letter is coming also, but if I try to open via explorer or total commander it say: "no disk inserted" but drive32 window constantly show mounted, and the hex numbers is also changing. It's does not matter if I mount read only or not. Tired on xp/win7 32bit.
I try change tomorrow my wires because they are to thin. Maybe this can cause this malfunction? Tomorrow I post screenshot about this kind off error.
Many thanx for your work.
Web
Dazexy
Old 05-23-2015, 00:24   #40 (permalink)
Member: 1038939
Thanks Meter: 99
Mount EMMC not work,2 WinXP(work and clean install),have probably read a full dump 32 GB 10 hours, using the adapter version 2...
Or maybe it will be fixed in the near future? Two emmc larger is available, pour a very long time ...
By the way make the option to specify which dump to drain for easy sorting. If the course is easy.
Maybe only on Win 7 runs? Install and test no problem.
Old 05-23-2015, 01:58   #41 (permalink)
Member: 651945
@dazexy
Are you trying to mount DATA from Windows Phone?
If so do this:
1. Mount with UNCHECK "Read Only"
2. If Drive is not accessible within 30 seconds, click Dismount and wait until the drive is properly dismounted.
3. Mount again with UNCHECK "Read Only"
This time wait until drive is accessible. Morning NTFS takes longer, but it will mount. The problem only happens when you do an improper dismount of any NTFS partition. Take a look again at my video demonstration of Lumia 630. You will see I always wait until drive is fully mounted and windows detecs the contents of the drive.
@Mumang
I tested on WinXP 32bit. Win7 32/64bit. Win 8.1 64bit.
Exe 12.31 should work on your PC.
Old 05-23-2015, 06:54   #42 (permalink)
Member: 1038939
Thanks Meter: 99
Test today, I have a Lumia 920, Lg D410 and Sony Z1.
I accomplish your goal by the result from the logs.
Old 05-23-2015, 08:40   #43 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
@X-Shadow
sent U (pm) a link to a video lumia 620 tryings via D.R.I.V.E. Today night i try it with lumia 520 too.
many thanx
dazexy
Old 05-23-2015, 08:42   #44 (permalink)
Member: 1734313
Sonork: 100.1620886
Thanks Meter: 70
can anyone provide me bin file link for just have a test
Old 05-23-2015, 09:59   #45 (permalink)
Member: 1038939
Thanks Meter: 99
ERROR: EMMC Virtual Disk Driver NOT FOUND! - update and error?What is it?
language
sound
skins
imageicon
nokia
  >> Flashid.ini
  >> Nokia.ini
  >> Phoenix.ini
  >> Phonecontrol.ini
  >> Phoneinfo.ini
  >> Providers.ini
nokia\bb5_loader\new
  >> _COPY_PASTER_READ_ME_.txt
nokia\bb5_loader\old
nokia\bb5_loader\patched
nokia\xg213_loader
nokia\dcc\common
nokia\dct4_loader
nokia\dct4_adlloader
nokia\loader
nokia\lumia
nokia\lumia\partitions
nokia\lumia\tp_pix
nokia\pm files
nokia\pm files\sx4
nokia\rpl_wout_npc
nokia\android\root
nokia\android\google\services
logs
  >> atfResellerList.ini
logs\63
driver
driver\lumia and asha phone drivers
driver\lumia and asha phone drivers\amd64
driver\lumia and asha phone drivers\ia64
driver\lumia and asha phone drivers\x86
driver\lumia and asha phone drivers\xp
driver\atf_new_drivers
driver\atf_new_drivers\amd64
driver\atf_new_drivers\i386
sd_card\sdc_image\pit
emmc\boot
emmc\firmware
emmc\emmc_tp
emmc\recovered
nokia\lumia\mprg
Update Important Files Done!!!!!!!!
Please restart application....
Log update.
Page generated in 0.27468 seconds with 9 queries
