05-30-2015, 09:03 | #91 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
NOKIA, (dead market), that are the brand most request at the moment... you can do many money with Samsung and Lumia...can ask much more for one repair and always search for these MTK that in 1 mounth in my shop is entered only one and total cost of phone was of 70$ ...how need request for one repair?... goes where do goes the market if want do this work...and Atf release all this Update for FREE not forgot this.... RIFF for one "EMMC DIRECT" implemented have open a POLL for change also HW, RIFF 2....so use Atf and do money. BR | |
05-31-2015, 10:49 | #93 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Sometimes I got this error, I think I forget turn off avast antivirus. The solution that works for me. 1. Uninstall atf. 2. Delete atf folder. 3. RESTART COMPUTER!!! 4. Install 12.30 5. Update to 12.31 6. Update important files. This always works for me. I thinks avast makes some trouble. Because if this is off, I never face this problem. Wbr dazexy |
05-31-2015, 13:38 | #96 (permalink) | |
If you post anywere you not will have good help for you problem.... BR allumts | |
06-01-2015, 09:56 | #97 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2130316 Status: Offline Thanks Meter: 0 | HI, after installing ATF 12.30, i make update to 12.31 using auto update funcion. When operation end, ATF program close but don't restart. I check in ATF directory and the advancebox exe file will be deleted. After check, i see Microsft Securiry Essentials antivirus blocked the file becouse recognised as tojan WIN32 Gheugent.A!plock. Need info! Thanks for replys |
06-01-2015, 11:11 | #98 (permalink) | |
Meantime, Uninstall 12.30 full setup, reboot pc, Stop you AV and launch other time the 12.30 full setup, (ceck if you AV not has damaged also the launcher) update "Important file", Update the 12.31 version the Update "Important files". Now goes in you AV and Put in Exclusion List ALL .Exe file you find in ATF FOLDER, ALL also Action .dll itc... and shortcut. Goeas in Firewall and Put in Exclusion also here all files above how have done for Antivirus.... Now after installed ALL drivers can Run you Atf Program as Admin and open you AV. If have other type of problem NOT reply here but Open you thread (it's free), posting Log and screenshoot of the problem BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
06-18-2015, 10:44 | #100 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | atf root done within 8 seconds Nokia Android Root Kit 1.5 ================================================== ==== Fully Tested Phones: Nokia X - RM-980 : All Versions Nokia X - RM-981 : All Versions Nokia X+ - RM-1053 : All Versions Nokia X2 - RM-1013 : All Versions Nokia XL - RM-1030 : All Versions Nokia XL - RM-1042 : All Versions Nokia XL 4G - RM-1061 : All Versions Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options Credits Goes To: Chainfire - author of SuperSU.zip ================================================== ==== Starting Connection... Checking ROOT Status... ROOT Status: OFF Preparing Local Directory... Starting Connection... Copying Files... Task Done! Total Rooting Time : 00:00:08 |
06-20-2015, 12:44 | #102 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @tehmoor @salem2833 You know that from Forum Rules writing TKANKS POST can be banned for an time? USE ONLY THANKS BUTTON...if not want goes a little in holydays... P.D. i only putting alert from Forum Rules, carefully with these Thanks Post. BR allumts |
06-21-2015, 08:50 | #103 (permalink) |
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== ================================================ Basic Phone Information ================================================ SW Version : 02074.00000.15234.28004 IMEI Plain : 359737060273806 IMEI2 Plain : 359737060273814 Phone Type : RM-1031 HW Version : 1000 Product Code : 059W9B2 Basic Product Code: 059V7D7 Module Code : 0206088 PSN Number : 73FB9D0AU Operator Name : 000-PK Phone Version : BuildDate : Apr 24 2015 , BuildType : Release , HelloString : NCSd for WP8 , Version : 5.0 Manufacturer ID : RM-1031_1023 Security Mode : Restricted ================================================ Extended Phone Information ================================================ Public ID : E9D25D681C58B9F2AAED4D2024154AA83CAF665C Wireless Lan 0 ID: 48:50:73:53:0B:70 Wireless Lan 1 ID: 48:50:73:53:0B:71 Wireless Lan 2 ID: 48:50:73:53:0B:72 Wireless Lan 3 ID: 48:50:73:53:0B:73 Bluetooth ID : 48:50:73:52:ABF ================================================ Simlock Information ================================================ SIMLOCK STATE : Not Locked Booting Flash Mode Initiated... Please wait upto 15 Seconds for HW Reset Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8212.P6169.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01000F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020222023B00 UEFI App: FLASH APP Flash App Protocol Version: 2.34 Flash App Implementation Version: 2.59 Query ROOT KEY HASH... ROOT_KEY_HASH: 54104908CCBD13A4993FFCCDC78DF192B904AD0210B1F60882 094096DEE16920 Query PUBLIC ID... PUBLIC_ID: E9D25D681C58B9F2AAED4D2024154AA83CAF665C Query eMMC Info... EMMC Manufacture ID: HYNIX EMMC Product SN : CC9A6A6C EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 40% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:05:57 |
