07-22-2014, 03:19 | #17 (permalink) |
Freak Poster Join Date: Sep 2007 Location: philippines
Member: 580233 Status: Offline Thanks Meter: 27 | Cherry Mobile Hyper V2.0 Hang on Logo then off.. Logs on ATF JTAG: Default language ID 0x0409 JTAG Interface Connected, S/N xxxxxxxx Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/9/2014 12:22:00 AM ================================================== ======== Phone Type : Cherry Mobile Hyper V2 CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : FACTORY RESTORE (WITHOUT IMEI CHANGE) Android Version: 4.0.4 Kernel Version : 3.0.21-perf-svn479 Build Number : CHERRY_HYPER_S250_V18_B479_20130408 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs 8. Full Factory Restore takes 40 minutes to Finish ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Hynix XINYH, 3.61 GiB Partition Config: No boot enabled, Boot ACK OFF (0x00) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91470 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x71 what is the problem? what is the solution? tnx atf team.... |
