05-12-2015, 08:09 | #2 (permalink) |
Junior Member Join Date: May 2012 Location: YellowKnife Long Lake
Member: 1756451 Status: Offline Thanks Meter: 6 | @atf team please help me what's wrong with this..?? File Author: ATF Team @ X-Shadow Date Created: 21/02/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMVTU000LM-B503 eMMC Product Name: VTU00M eMMC Product Rev: 15.7 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Verifying eMMC Firmware... ERROR: eMMC Firmware Verify FAILED! Total Elapsed Time 00:00:06 |
05-12-2015, 09:40 | #3 (permalink) |
Member: 1756451 Status: Offline Thanks Meter: 6 | Quote: Code: eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 8589934592 BYTES BOOT PARTITION SIZE: 1024 KB RPMB PARTITION SIZE: 1024 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000003 Product Rev : 3.3 Product SN : 33330212 Manufactured : January 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010030303030303333333302120083.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
05-14-2015, 11:36 | #4 (permalink) |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | Hello. Have some problems with p5100 emmc KLMAG2GE4A-A002. Here is log: Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501003030303030305620110726589D CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 67108864 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 5.6 Product SN : 20110726 Manufactured : January 2005 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501003030303030305620110726589D.ext_csd Backup Directory: H:\atf\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung eMMC Firmware Update ====================================================== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ====================================================== Please Manually Select the Correct Part Number of your eMMC Device. ====================================================== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ====================================================== ====================================================== Loading ATF eMMC Firmware File... (Please Wait) ====================================================== File Author: ATF Team @ X-Shadow Date Created: 16/04/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KLMAG2GE4A-A001 eMMC Product Name: MAG2GA eMMC Product Rev: 0.6 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Verifying eMMC Firmware... eMMC Firmware Verify OK! Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... ERROR: eMMC Firmware Programming Failed 0x02 Total Elapsed Time 00:01:00 Any Idea? Thanks in advance |
05-20-2015, 12:31 | #7 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | @VELIKI, you must need of DISCONNECT "TP" first of write the fw...this is one error that get when you not disconnect TP after "Scan emmc" for write fw. BR allumts |
06-06-2015, 09:26 | #10 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Hi, but you cannot open one you thread and post Screenshoot for help more good you? Meantime if show "no Box" and you are sure that you are using Right and working Cable, (post what type of Box you have), change USB 2.0 any HUB port connected directly in you pc motherboard, Install "New Driver" correct for you SO, put in exlusion of AV and FW "Atf Setup.exe" then restart pc open Sw and connect you Box, post what light you see in Box... BR |
