12-10-2020, 16:44 | #256 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1703324 Status: Offline Thanks Meter: 2 | Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : DAF51343EC9BD498B966AA26 ========================================= Please Try Again Later (Server Busy) |
12-10-2020, 17:20 | #257 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Quote:
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post: |
12-15-2020, 12:34 | #258 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2346218 Status: Offline Sonork: djawalak Thanks Meter: 1 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B7B95F50C89B42A8B58D0BEE ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software |
01-18-2021, 22:05 | #259 (permalink) |
Freak Poster Join Date: Apr 2004 Location: tunis Age: 61
Member: 63299 Status: Offline Sonork: 100.1616476 Thanks Meter: 11 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : F7C4A577850ADD09AF2A65D1 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software |
01-19-2021, 05:04 | #260 (permalink) |
Junior Member Join Date: Jul 2019 Location: budgam
Member: 2917908 Status: Offline Thanks Meter: 1 | AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : E2A927F98FDA54DDDFAEE8AF ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Please help me Atf team thankoooooooooo |
01-19-2021, 08:45 | #261 (permalink) |
Freak Poster Join Date: Jul 2016 Location: ubauro Distik Ghotki
Member: 2601587 Status: Offline Thanks Meter: 201 | Driver Version : 00020828 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : C2C2C07DBD745BFB89C585A7 ========================================= Please Try Again Later (Server Busy) |
04-21-2021, 10:02 | #263 (permalink) |
Junior Member Join Date: Jun 2009 Location: constantine algeria Age: 45
Member: 1050938 Status: Offline Sonork: no Thanks Meter: 1 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 91900C21A54368AEF7B39E0C ========================================= Please Try Again Later (Server Busy) |
04-21-2021, 10:03 | #264 (permalink) |
04-25-2021, 17:07 | #265 (permalink) |
Insane Poster Join Date: Jan 2014 Location: Ordubad Age: 51
Member: 2104824 Status: Offline Thanks Meter: 28 | Dear ATF product support, I still don't understand you, have we done anything wrong to you? why does everyone throw their customers halfway? I have boxing on one computer working as it should, I need it to work on the main computer, cloning the full C drive did not help, are there solutions or can we forget about you? |
The Following 2 Users Say Thank You to edik622 For This Useful Post: |
05-04-2021, 14:10 | #266 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2151773 Status: Offline Thanks Meter: 4 | I cloned the entire disk and the box started with activation. Previous system work on RAID 0. After cloning process to regular SATA SSD everything is OK. I used HDClone from Miray Software - paid version. |
The Following 2 Users Say Thank You to Sky-com For This Useful Post: |
05-15-2021, 09:16 | #267 (permalink) |
No Life Poster Join Date: Oct 2004 Location: italy
Member: 85139 Status: Offline Thanks Meter: 68 | maestro,ci avete abbandonati !! [QUOTE=Advance-Box;10832179]Before Posting Here about problems in Activating NEW or OLD ATF Boxes, Please follow Simple Steps Below: 1. Upgrade Your ATF Software to 11.90 which you can download here: ATF_v11.90_Full_Installer.rar 2. Update Your Box Firmware to 11.0.10 via ATF 11.90 which you downloaded from Step 1. 3. Show Complete LOGS of Error Message Moderators will AUTOMATICALLY DELETE POSTS if: 1. You are showing Logs from ATF Software which is LOWER than 11.90 2. You are showing Logs from ATF Firmware LOWER than 11.0.10 3. You are not showing COMPLETE LOGS 4. Your problem is NOT related to Box Activation 5. If you Blah Blah too much... [/QUOTE master, you have abandoned us !! we bought the box and now it's dead, why don't you implement the box with a new huawei mtk, alcatel or other brand software? if you do this we will all be grateful to you. |
The Following User Says Thank You to topline For This Useful Post: |
06-23-2021, 14:49 | #268 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2690503 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : C9844955B6ECBF53AD6DF50F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-06-2021, 17:38 | #269 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1550235 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : AA59E63FEB84C5D0D6BC862C ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-13-2021, 11:27 | #270 (permalink) |
Insane Poster Join Date: Jan 2014 Location: Indonesia
Member: 2108563 Status: Offline Thanks Meter: 19 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EA38DD25E8701E8FB070D0F2 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done |
