Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-13-2021, 11:28   #271 (permalink)
Member: 2108563
Thanks Meter: 19
Advance Turbo Flasher Found
Driver Version : 00021206
Library Version : 00030210
Box Type : ATF Nitro
Box Firmware : LogiCore 11.0.10
Software Version : v12.70
AdvanceBox SN : EA38DD25E8701E8FB070D0F2
Please Try Again Later (Server Busy)
ATF SOFTWARE IS NOT ACTIVATED ON THIS PC
Please Activate your ATF Software
* Follow these Instructions
1. Connect this PC to the INTERNET
2. Restart ATF Software
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 07-13-2021, 11:31   #272 (permalink)
Member: 2108563
Thanks Meter: 19
Old 07-26-2021, 13:01   #273 (permalink)
Member: 2346218
Sonork: djawalak
Driver Version : 00020824
Library Version : 00030207
Box Type : AdvanceBox Turbo
AdvanceBox SN : B7B95F50C89B42A8B58D0BEE
Old 07-27-2021, 06:40   #274 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
ATF box is now Dead Product
i have a same Problem after installing a new windows Box Not active on my PC
use ATF Old version ATF_v8.90_Full_Installer
****************************/file/obgac...aller.rar/file
The Following 7 Users Say Thank You to .::Mustafa::. For This Useful Post:
Old 08-17-2021, 17:42   #275 (permalink)
Member: 363376
Sonork: 100.1620874
Please check the Activation of My Box. Logs Shown Below:
Driver Version : 00021234
Library Version : 00030216
AdvanceBox SN : A22B64AC9B8663A38842CE51
Box Status : NOT ACTIVATED
Old 10-14-2021, 20:06   #276 (permalink)
Member: 310418
Thanks Meter: 13
i see the posts are fresh, so i have a problem too...
AdvanceBox SN : B82C0AD4A2B1CCA2D0D001C2
BOX NOT ACTIVATED ;(
The Following User Says Thank You to lampik For This Useful Post:
Old 11-22-2021, 20:15   #277 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
AdvanceBox SN : A8E54466B43C002B88097E08
SET BSI Load Done
Old 11-22-2021, 20:16   #278 (permalink)
Member: 112185
Sonork: 100.1612613
Thanks Meter: 163
atf box activation fail !!
SET BSI Load Done
The Following User Says Thank You to recan21 For This Useful Post:
Old 02-14-2022, 03:09   #279 (permalink)
Member: 2189405
ATF not active
Software Version : v11.90
AdvanceBox SN : B58FF72AC3AB4853D958DC91
Page generated in 0.17898 seconds with 8 queries
