03-30-2012, 10:44 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: INDIA
Member: 130050 Status: Offline Thanks Meter: 83 | Cant RUN ATF 8.60 After Update FW - (Solved) to day i update my SW 8.55 to 8.60 and Update Box FW then i try to restart my ATF SW 8.60 but Now Cant RUB SW....i already uninstall and reinstall ATF NEW Drivers but same problem...Thax in ADV. |
03-30-2012, 10:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Download and Install Full setup from here: http://forum.gsmhosting.com/vbb/8276235-post2.html BR |
03-30-2012, 11:28 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
delete C:\AdvanceBox Turbo Flasher\ then reinstall Make sure you save your C:\AdvanceBox Turbo Flasher\Nokia\Backup\ folder | |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
03-30-2012, 13:33 | #6 (permalink) | |
No Life Poster Join Date: Feb 2004
Member: 52597 Status: Offline Thanks Meter: 275 | Quote:
Code: CMT Secondary Loader: E:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... ERROR: MCU_CONFIGURATION_RESPONSE is not VALID TIPS: 1. Make Sure your Battery Power is Enough... 2. Make Sure Connectivity Drivers are installed... 3. DO NOT USE USB HUBS... 4. Use an ORIGINAL NOKIA CA-101D USB Cable... Flashing Failed.... ERROR: USB Boot Failed Time Taken to Complete Tasks: 00:00:10 | |
03-30-2012, 13:38 | #7 (permalink) | |
Freak Poster Join Date: Sep 2006
Member: 353717 Status: Offline Sonork: 1001647526 Thanks Meter: 147 | Quote:
tester by me | |
03-30-2012, 16:36 | #11 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Ok, we are looking into this matter. I just authorize the same HASH phone - C7-00, all was good. Logs: Quote:
Also, did you try second or third time? BR Last edited by ..::Angel::..; 03-30-2012 at 16:42. | |
03-30-2012, 18:02 | #12 (permalink) | |
Code: ====================================================== ====================================================== USB Phone Authorization Boot ====================================================== ====================================================== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeded After 0 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 15E00013 ID DWORD 1 : F2D80344 ID DWORD 2 : 9019D365 ID DWORD 3 : D86441B3 ID DWORD 4 : 63DB2E14 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: E:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... ERROR: MCU_CONFIGURATION_RESPONSE is not VALID TIPS: 1. Make Sure your Battery Power is Enough... 2. Make Sure Connectivity Drivers are installed... 3. DO NOT USE USB HUBS... 4. Use an ORIGINAL NOKIA CA-101D USB Cable... Flashing Failed.... ERROR: USB Boot Failed Time Taken to Complete Tasks: 00:00:12 Before this new update USB hash read worked great. | |
03-31-2012, 12:36 | #13 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @silhouette Thanks for reporting. We are looking into this matter already. Will be fixed. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
04-01-2012, 13:56 | #14 (permalink) | |
I'd like to clarify the history of my box, this one http://ucables.com/img/extra/ADVANCE...-R291666-0.jpg This box has always given me trouble (probably defective). Works on only one usb port among many operating systems/computers with/without usb hub. Was working fine before current update plugged in via extension usb cable. After new update old problems returned. Now plugged into that same usb port WITHOUT the usb extension cable and working fine again. So problem solved for now, thanks | |
==== FREE DOWNLOAD ==== site updated | cimbalo | GSM Mobile Links | 31 | 04-29-2012 20:43 |
cant unlock CSI eeprom | Stryker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-20-2000 13:00 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
