Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-12-2013, 17:39   #166 (permalink)
Member: 1730266
Originally Posted by Mirken View Post
i'm having this error while trying to download
Access is denied. Verify credentials.
whats wrong? i've replaced userconfig file
did u got the solution plz reply
Old 08-13-2013, 17:18   #167 (permalink)
Member: 1735447
Sonork: 100.1614319
Thanks Meter: 18
Good Work.................
Old 08-22-2013, 16:40   #168 (permalink)
Member: 1115725
Sonork: 100.1653957
Thnx Man it's works for meeeeeeeeeee..............
Old 08-23-2013, 19:14   #169 (permalink)
Denva's Avatar
Member: 1274304
Sonork: 100.1617965
Thanks Meter: 195
Originally Posted by Kuji2013 View Post
Br flash file download 100% but where file....
C:\ProgramData\Nokia\Packages\Products
Here is the exact place for Win7(86)
Old 08-23-2013, 19:31   #170 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,346
Or u can change directory where save u downloaded files, i've put in C:/Program Files/Nokia/Phoenix/Products
no matter the original location u can change it,
Max
Old 08-30-2013, 18:30   #171 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
Originally Posted by Indyss View Post
I FOUND THE SOLUTION!!!!
go to control panel and found the option "Users account configuration control" or something like that.
You will find a big notification BAR, poush it to the bottom (NO NOTIFICATIONS)
IMPORTANT: RESTART YOUR PC!!!
Then try to install again NCS AND BOOT
Dont forget to say thanks!!!
Your solution worked for me, Thanks so much!!!!!!!!!!!!!!!!!!!!!!
Old 09-01-2013, 19:00   #172 (permalink)
Member: 2016043
I have a "stupid" question... if I flash my locked asha 309 RM-843 it will stay unlocked?
Old 09-02-2013, 09:45   #173 (permalink)
allumts's Avatar
Member: 1564612
Yes my dear, is a small lol Question it, FLASH is Only Flash, when Unlocke a phone u Bypass any LOCK of SIM and Network... was very good if whith a easy Flash u can Unlock Phones,
Max
Old 09-05-2013, 07:42   #174 (permalink)
Member: 2018550
Followed all the steps, but the firmware is not downloading. "Download in progress: 0". Need your help guys
Old 09-05-2013, 08:15   #175 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Bro, ceck u Internet Connection, it's not work off-line,
br
Max
P.d. but now use the NaviFw 2.4+ any issue or other, just download this version then start to work whith FREE vers. by P.Code how this above or FULL Version from any worlwide RM, Name of the Phone itcc.., classic NaviFw, only whith a small donation of 3€ and u not have more problems of P.Code, Fw version itcc..., find it in one my post oe in Advance Box section,
regards
Old 09-05-2013, 08:22   #176 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
FOR ALLs,
Here all explanation of NaviFw 2.4+
http://forum.gsmhosting.com/vbb/9690175-post73.html
Max
The Following User Says Thank You to .:Ripgsm:. For This Useful Post:
Old 09-06-2013, 07:49   #177 (permalink)
Member: 2019290
I was able to download the firmware
please tell me how I can update the firmware manually or automatically on my Nokia lumia 520
thanks
Old 09-08-2013, 06:30   #178 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
download Zune Setup for nokia lumia update......
Old 09-08-2013, 09:28   #179 (permalink)
allumts's Avatar
Member: 1564612
thanks
Hello, you not write whith Tool are using, but:
- Whith "Nokia Care Suite": insert P.Code of u LUMIA 520, find it under battery, then insert in P.Code field, it find the Latest version when Download Full Package,
- Whith NaviFw 2.4+, (latest release), simply search by RM or Model of Phone or P.Code, whith RM or Lumia 520 it is showing All Full List of Version/variant, choise which u want and Download
- When have the Full Fw package, if have BOX just put Directory where are these files, if use Phoenix use Refurbish, if Use other Original Nokia Program it download only latest version for u P.Code in the phone, like Nokia Pc Suite or similar, carefully first of Flash LUMIA Phones, if not know good what are u flashing can Brick u Lumia 520,
Max
Old 09-08-2013, 09:34   #180 (permalink)
allumts's Avatar
Member: 1564612
Bro, this is Advance Box Section, if u are using it, haven't need of any Setup, go in "Product Support" > "Update Important Files" and will have always updatate Zune List of Lumia Phones, or whith "Nokia Care Suite" same whith P.Code only,
Max
Page generated in 0.19253 seconds with 9 queries
