Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-17-2013, 18:40   #121 (permalink)
naizersky's Avatar
Member: 540512
Thanks Meter: 340
can anyone help me. i was face this problem.
the underlying connection was closed;could not establish trust relationship for the ssl/tls secure channel
Old 07-18-2013, 17:53   #122 (permalink)
Member: 1863004
Thanks Meter: 11
usergroupsconfiguration,cfg
Has something now changed since Nokia Care Suite PST 5.0.2013.27.1.3 has been released as now getting "The remote name could not be resolved. "***.caresuite_nokia_com" using 5.0 2013.13.4.4 at beginning of this thread I might add (sorry about * instead of w)
Old 07-19-2013, 07:21   #123 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 25
jam with xp pack 2 it has failed to install
please help
br
Old 07-19-2013, 10:21   #124 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi, make sure you are using: Nokia_Care_Suite_PST_5.0_2013.13.4.4
newer versions will not work with this trick, you will need NOL login for it.
Old 07-20-2013, 07:06   #125 (permalink)
Member: 617140
Thanks Meter: 4
This is very good thannnkkkssss,.............
Old 07-20-2013, 09:13   #126 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Originally Posted by sadek2011 View Post
Hello,
Friends.
NokiaCareSuiteForStore-2013_1_3_4 support is windows xp Service Pack -3. Nokia Care Suite PST 5.0 2013.10.1.3 support is windows 7. I think, old version example 2690 software version is 10.10. this old flash file.
New version is :
Download wper com Nokia Care Suite PST 2013 rar
Or
Nokia_Care_Suite_PST_5.0_2013.13.4.8
Now download this software and tested report please.
same version showing wts is it
Old 07-20-2013, 12:51   #127 (permalink)
Member: 1881601
Thanks Meter: 17
what refer to the product code give details of it team for regrads thanksss
Old 07-20-2013, 12:58   #128 (permalink)
Member: 1881601
Thanks Meter: 17
thanks now i understand correctly
Old 07-21-2013, 09:49   #129 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
but sir g where i am making mistake,i am unable to find nokia care suite.look it-------
Uploaded with ImageShack.us
Old 07-21-2013, 17:03   #130 (permalink)
Member: 1863004
Thanks Meter: 11
Sorry can't post links but "Google" for "microsoft vc++ 2010 redistributable" from Microsoft and install and then NCS installation will complete.
Old 07-21-2013, 23:53   #131 (permalink)
Member: 1178560
Advance Turbo Flasher Found
Driver Version : 00020817
Library Version : 00030206
Box Type : ATF Lightning
Box Firmware : LogiCore 10.3.50
Software Version : v9.90
AdvanceBox SN : C15F8BC8FC70E0C2A3ADEA3E
Box Status : NOT ACTIVATED
Old 07-24-2013, 06:10   #132 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
plz help me download flash file problem
Old 07-24-2013, 08:01   #133 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
plz urgent help download flash file
Old 07-24-2013, 10:52   #134 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,346
Hi, loock here
Bro, please LOOCK HERE:
1) After all operation, REPLACE THE "usergroupsconfiguration.cfg" file, it's file that not requiere login to u, is IMPORTANT,
2) INSTALL "Microsoft VC++ 2010 and 2005 if not have just installed or if the same program not install these, ceck from REMOVE/INSTALL PROGRAMs
3) NOT USE OFF-LINE,
4) After Open "Nokia Care Suite", when show the Login u not put anythingh inside, only press OK,
5) Search u P.Code, copy/paste or write manual in the field, PRESS DOWNLOAD, DONE!!!!!
Tip: Not use they directory, u can change whith other that u want..
COMPLETE FOLDER:
REPLACE LOGIN FILE:
WHEN ASK FOR LOGIN, PRESS "SIGN IN", not write nothinghs:
ENTER P.CODE AND DOWNLOAD, ALL DONE !!!!
Max
Old 07-24-2013, 13:33   #135 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
need solving my problem plz help
Page generated in 0.19592 seconds with 9 queries
