07-27-2017, 08:55 | #91 (permalink) |
Crazy Poster Join Date: Jun 2014
Member: 2201938 Status: Offline Sonork: baloch Thanks Meter: 3 | Delete " hosts " file from C:\WINDOWS\system32\drivers\etc Try to update box & post result still error conection |
12-07-2017, 14:54 | #93 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2779413 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : EB1E186BE388BBD7D8421021 ========================================= Please Try Again Later (Server Busy) ========================================= |
12-07-2017, 15:01 | #94 (permalink) |
Member: 2779413 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : EB1E186BE388BBD7D8421021 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software |
12-21-2017, 04:52 | #95 (permalink) |
Freak Poster Join Date: May 2006
Member: 275677 Status: Offline Thanks Meter: 22 | Please help us with this problem. Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.10 AdvanceBox SN : C78AE24FC93FFE44A4F4C039 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
12-21-2017, 09:31 | #96 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | Quote:
C:\WINDOWS\system32\drivers\etc | |
04-11-2019, 15:01 | #98 (permalink) |
Insane Poster Join Date: Jun 2016 Location: pakistan
Member: 2592409 Status: Offline Thanks Meter: 15 | plz solve my problm ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : A043248ED9849204EEEF0F51 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-16-2019, 11:34 | #99 (permalink) |
Freak Poster Join Date: Jan 2012 Location: 1 Age: 50
Member: 1710813 Status: Offline Sonork: gsmhosting.com Thanks Meter: 38 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : C78EAE1A9181C39ED8833A46 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-16-2019, 16:13 | #100 (permalink) |
Freak Poster Join Date: Jan 2005 Location: iran Age: 41
Member: 103931 Status: Offline Thanks Meter: 31 | Atf ActivationServer Error! ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : FA7A04949BEA2E00ED980EE8 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
11-10-2019, 07:29 | #103 (permalink) | |
Freak Poster Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 144 | ATF Box Server Busy Problem Hellp me ATF Box Server Busy Problem Hellp me (11-10-2019) Quote:
11-10-2019, 14:58 | #104 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | sever down dead Product......... BR, -=MR_Gsm=- |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
