03-15-2017, 10:52 | #76 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2695288 Status: Offline Thanks Meter: 0 | Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.60 AdvanceBox SN : B39FCC25F3DCE8EACA518356 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done IP Address is 197.38.66.202 helllllllp me hellllllllp me |
03-15-2017, 15:29 | #77 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Those are still facing server problem >>>>> Delete " hosts " file from C:\WINDOWS\system32\drivers\etc Try to update box & post result Br - srinibas |
The Following 7 Users Say Thank You to srinibas For This Useful Post: |
03-24-2017, 10:19 | #79 (permalink) |
Freak Poster Join Date: Mar 2014 Location: PAKISTAN
Member: 2145475 Status: Offline Thanks Meter: 100 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : C8019E2C84556CD6DCEF47A7 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-01-2017, 11:13 | #82 (permalink) |
No Life Poster Join Date: Apr 2006 Location: .:Islam:.:Peace:.Pakistan:. Age: 48
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | Initializing Target Device... Reading Security... Performing Data Authentication.................................... .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ................. Programming UROW... Programming Array............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ........ Verifying Array............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ..........r Programming Rlock... Programming SILSIG... Advance-Box Secure AES-128 Channel Open Port Success... Exit code = 0... Status: Firmware Update was a Success! Elapsed time = 00:03:55 still on start ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level |
04-02-2017, 00:50 | #84 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: San Fernando La Union Age: 34
Member: 2068959 Status: Offline Thanks Meter: 252 | Quote:
The Following User Says Thank You to omairlee01 For This Useful Post: |
06-27-2017, 01:41 | #90 (permalink) |
Junior Member Join Date: Sep 2008
Member: 861252 Status: Offline Thanks Meter: 5 | ================================================ 23:50:35 : Advance Turbo Flasher Found 23:50:35 : ================================================ 23:50:35 : Driver Version : 00021000 23:50:35 : Library Version : 00030207 23:50:37 : Box Type : ATF Nitro 23:50:37 : Box Firmware : LogiCore 11.0.10 23:50:37 : Software Version : v12.60 23:50:37 : AdvanceBox SN : F2538C39A53995DA9916D9E3 23:51:16 : ========================================= 23:51:16 : Please Try Again Later (Server Busy) 23:51:16 : ========================================= 23:51:16 : 23:51:16 : 23:51:16 : 23:51:16 : ================================================ 23:51:16 : ATF SOFTWARE IS NOT ACTIVATED ON THIS PC 23:51:16 : Please Activate your ATF Software 23:51:16 : ================================================ 23:51:16 : 23:51:16 : * Follow these Instructions 23:51:16 : 1. Connect this PC to the INTERNET 23:51:16 : 2. Restart ATF Software |
