03-18-2020, 16:44 | #109 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | http://forum.gsmhosting.com/vbb/f609.../#post14032788 Server is working fine actually - FEB, 2020[ FALSE!!!!!! FALSE!!!!!! FALSE!!!!!! Server down dead product,, BR, -=MR_Gsm=- |
04-22-2020, 10:23 | #111 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1317917 Status: Offline Sonork: oonn66 Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 8FB0D3899435AA5AC4BFE2F9 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
04-24-2020, 09:56 | #112 (permalink) | |
Major Poster Join Date: Apr 2020 Location: AT Work
Member: 2954831 Status: Offline Sonork: 100.1678373 Thanks Meter: 63 | Advance Turbo Flasher Quote:
04-24-2020, 10:10 | #113 (permalink) |
Member: 2954831 Status: Offline Sonork: 100.1678373 Thanks Meter: 63 | ATF BOX Team Plz Reply Solution for Atf Box Activation Why ur are ignore our Msgs ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EDCC921A96D5DF0CC5F768D5 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Solution Plz |
04-24-2020, 10:39 | #114 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Koronadal City, Ph/Riyadh, KSA
Member: 1240161 Status: Offline Thanks Meter: 159 | Quote:
04-25-2020, 14:10 | #115 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2327468 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : AF2AD1E9E25753A5ECDBFF0D ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
