nice work, thanks for sharing |
thanks super job............................. |
how to remove that steel shield ???? |
Br - srinibas |
WAO bro great job it is very sharp |
i encountered problem with some LUMIA 800 with TOSHIBA CHIPS. IT FAILS TO READ AND PATCH.HERE IS THE LOG 08:43:22 : 1. DO NOT USE THE PHONE"S BATTERY 08:43:22 : 2. Connect the Soldered TP Connections to ATF Box 08:43:22 : 3. Disconnect the USB Cable and Wait until the 08:43:22 : the ATF Software will tell you to Connect the USB. 08:43:22 : 08:43:25 : 08:43:25 : Interface Reset OK! 08:43:25 : Reading Platform Information... 08:43:25 : Selecting Active Handle... 08:43:25 : Select Handle OK! 08:43:25 : Sending Ping... 08:43:25 : Ping Reply OK! 08:43:25 : 08:43:25 : 08:43:25 : Storage Device Information 08:43:25 : Manufacturer ID: 00 08:43:25 : Application ID : 0000 08:43:25 : Product Name : 08:43:25 : Product Rev : 00 08:43:25 : Product SN : 480604E0 08:43:25 : 08:43:25 : Protection Information 08:43:25 : Write Protect A: OFF 08:43:25 : Write Protect B: OFF 08:43:25 : 08:43:25 : 08:43:25 : Dumping AMSS FAT16 Region 08:43:25 : Please wait for 2-4 Minutes... 08:43:25 : ERROR: Dump Aborted, Too much CRC Failures! 08:43:25 : 08:43:25 : Total Elapsed Time 00:00:03 08:44:04 : ================================================== ==== 08:44:04 : ================================================== ==== 08:44:04 : Lumia Test Point Connection Module 08:44:04 : ================================================== ==== 08:44:04 : ================================================== ==== 08:44:04 : 08:44:04 : 1. DO NOT USE THE PHONE"S BATTERY 08:44:04 : 2. Connect the Soldered TP Connections to ATF Box 08:44:04 : 3. Disconnect the USB Cable and Wait until the 08:44:04 : the ATF Software will tell you to Connect the USB. 08:44:04 : 08:44:08 : ERROR: Phone WAS NOT Detected! 0x01 08:44:08 : Check your Test Point Soldering! 08:44:08 : 08:44:08 : Total Elapsed Time 00:00:04 08:44:35 : ================================================== ==== WERE this model with this TOSHIBA CHIPS NOT SUPPORTED? |
SEE BELOW LINK ANY ONE CAN HELP http://forum.gsmhosting.com/vbb/f609...3/#post9000002 |
thanx very nice post atf is the best box for all nokia |
done! for 2nd time Code: 12:34:32 : ====================================================== |
================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 80 Application ID : 0000 Product Name : Product Rev : 0C Product SN : 00000C81 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:05:37 br, s1emens |
strange still invalid sim, at first using simcard always said invalid sim, is this blocked or? br, s1emens |
the shield and sold it ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 01C69C5F Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:06:02 |
thanks thanks thanks |
my product name is empty it should be HYNIX ? i recieved phone form customer when insert sim it said invalid sim, it didn't ask for PIN, is this means it locked? or maybe counter blocked? still new in WP NOKIA unlocking i'll try again tomorrow br, s1emens |
