================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 0042 Product Name : F Product Rev : 0C Product SN : 03CEF80E Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:23 |
hello i am facing this problem. please check this error. Code: ====================================================== |
good post thanksssssssssssssssss keep it up |
ATF Software already tells you where is the problem. So you just correct it... |
1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 00 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 8E4FB402 Protection Information Write Protect A: OFF Write Protect B: OFF Total Elapsed Time 00:11:24 |
gave me a sollution thanks |
Lumia 800 UNLOCK DONE BY ATF ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 80 Application ID : 0000 Product Name : Product Rev : 0C Product SN : 00084302 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:18 |
another lumia 800 done another lumia 800 from orange uk. done superbly.. Code: 13:24:19 : ====================================================== gurinder |
Toshiba chip Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 0C4418F0 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:06 toshiba chip, cant be unlocked? |
1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 04E25A34 Protection Information Write Protect A: OFF Write Protect B: OFF Writing MBR... Write Success! Writing SEC_BOOT... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:00:27 thanks team |
