please help me for this phone , is locked ,but ATF showing maybe unlock already , ........ code: 20:22:07 : ================================================== ==== 20:22:07 : ================================================== ==== 20:22:07 : Lumia Test Point Connection Module 20:22:07 : ================================================== ==== 20:22:07 : ================================================== ==== 20:22:07 : 20:22:07 : 1. DO NOT USE THE PHONE"S BATTERY 20:22:07 : 2. Connect the Soldered TP Connections to ATF Box 20:22:07 : 3. Disconnect the USB Cable and Wait until the 20:22:07 : the ATF Software will tell you to Connect the USB. 20:22:07 : 20:22:09 : 20:22:09 : Interface Reset OK! 20:22:09 : Reading Platform Information... 20:22:09 : Selecting Active Handle... 20:22:09 : Select Handle OK! 20:22:09 : Sending Ping... 20:22:09 : Ping Reply OK! 20:22:09 : 20:22:09 : 20:22:09 : Storage Device Information 20:22:09 : Manufacturer ID: 11 20:22:09 : Application ID : 0100 20:22:09 : Product Name : 016G4B 20:22:09 : Product Rev : 00 20:22:09 : Product SN : D189C986 20:22:09 : 20:22:09 : Protection Information 20:22:09 : Write Protect A: OFF 20:22:09 : Write Protect B: OFF 20:22:09 : 20:22:09 : 20:22:09 : Dumping AMSS FAT16 Region 20:22:09 : Please wait for 10-20 Minutes... 20:22:36 : ================================================== ==== 20:22:36 : ================================================== ==== 20:22:36 : Lumia Test Point Connection Module 20:22:36 : ================================================== ==== 20:22:36 : ================================================== ==== 20:22:36 : 20:22:36 : 1. DO NOT USE THE PHONE"S BATTERY 20:22:36 : 2. Connect the Soldered TP Connections to ATF Box 20:22:36 : 3. Disconnect the USB Cable and Wait until the 20:22:36 : the ATF Software will tell you to Connect the USB. 20:22:36 : 20:22:38 : 20:22:38 : Interface Reset OK! 20:22:38 : Reading Platform Information... 20:22:38 : Selecting Active Handle... 20:22:38 : Select Handle OK! 20:22:38 : Sending Ping... 20:22:38 : Ping Reply OK! 20:22:38 : 20:22:38 : 20:22:38 : Storage Device Information 20:22:38 : Manufacturer ID: 11 20:22:38 : Application ID : 0100 20:22:38 : Product Name : 016G4B 20:22:38 : Product Rev : 00 20:22:38 : Product SN : D189C986 20:22:38 : 20:22:38 : Protection Information 20:22:38 : Write Protect A: OFF 20:22:38 : Write Protect B: OFF 20:22:38 : 20:22:38 : 20:22:38 : Dumping AMSS FAT16 Region 20:22:38 : Please wait for 10-20 Minutes... 20:46:16 : 20:46:16 : WARNING: Patch Bit NOT FOUND! 20:46:16 : Maybe Phone is already UNLOCKED! 20:46:16 : |
thanks ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 03845918 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:20 Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
please help...unlock done but, show invalid sim. no asking code. use atf 9.15 Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 01FDB083 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:32 |
Br - srinibas |
thanks sir. i will try |
thanks post.............................. |
nice job very useful post |
================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 001931A2 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time |
Hello guys, i unlocked my firsts 800 :) Now i have one doubt, after unlocking can i upgrade de software??? He is unlocked after de upgrade?? Thanks |
================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 04EEC6AE Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:30 |
how to downgrade bootloder lumia 800 how to downgrade bootloder lumia 800 i unlock atf box but code not accept |
Hello guys, i unlocked my firsts 800 http://forum.gsmhosting.com/ubb/smile.gif Now i have one doubt, after unlocking can i upgrade de software??? He is unlocked after de upgrade?? Thanks |
Lumia Unlock is a patch type so Flash after unlock will lock the set again Br - srinibas |
