11-12-2015, 19:22 | #5656 (permalink) |
Freak Poster Join Date: May 2013 Location: Nigeria
Member: 1931004 Status: Offline Sonork: 100.1662382 Thanks Meter: 85 | Nokia X2 RM-1013 Root and Gapps Injection Done With ATF Nokia X2 RM-1013 Root Done With ATF Code: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.50 AdvanceBox SN : F39C236BA0363AD9FC44B668 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Enable USB debugging on your Phone Go to Settings -> About phone, and tap 5 times "Model", then tap 5 times "Software version", then go to Settings -> Developer Options and Enable USB debugging ====================================================== Nokia Android Root Kit 1.5 ====================================================== Fully Tested Phones: Nokia X - RM-980 : All Versions Nokia X - RM-981 : All Versions Nokia X+ - RM-1053 : All Versions Nokia X2 - RM-1013 : All Versions Nokia XL - RM-1030 : All Versions Nokia XL - RM-1042 : All Versions Nokia XL 4G - RM-1061 : All Versions Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options Credits Goes To: Chainfire - author of SuperSU.zip ====================================================== Starting Connection... Checking ROOT Status... ROOT Status: OFF Preparing Local Directory... Starting Connection... Copying Files... Task Done! Total Rooting Time : 00:00:05 Nokia X2 RM-1013 Gapps Installed through ATF Code: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.50 AdvanceBox SN : F39C236BA0363AD9FC44B668 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Enable USB debugging on your Phone Go to Settings -> About phone, and tap 5 times "Model", then tap 5 times "Software version", then go to Settings -> Developer Options and Enable USB debugging ====================================================== Nokia Android Root Kit 1.5 ====================================================== Fully Tested Phones: Nokia X - RM-980 : All Versions Nokia X - RM-981 : All Versions Nokia X+ - RM-1053 : All Versions Nokia X2 - RM-1013 : All Versions Nokia XL - RM-1030 : All Versions Nokia XL - RM-1042 : All Versions Nokia XL 4G - RM-1061 : All Versions Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options Credits Goes To: Chainfire - author of SuperSU.zip ====================================================== Starting Connection... Checking ROOT Status... ROOT Status: OFF Preparing Local Directory... Starting Connection... Copying Files... Task Done! Total Rooting Time : 00:00:05 ====================================================== Google Services Kit 2.0 ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options Credits Goes To: Kasha*****a - author of Google Tweak ====================================================== Starting Connection... Operation Cancelled... Enable USB debugging on your Phone Go to Settings -> About phone, and tap 5 times "Model", then tap 5 times "Software version", then go to Settings -> Developer Options and Enable USB debugging ====================================================== Google Services Kit 2.0 ====================================================== Power On the Phone and Connect it to the USB Port USB Debugging MUST BE Enabled in Developer Options Credits Goes To: Kasha*****a - author of Google Tweak ====================================================== Process Cancelled... Starting Connection... Preparing Local Directory... Copying Services Files... Copying Kitkat Launcher Files... Start Cleanup... Rebooting Phone... Task Done! Total Installation Time : 00:02:02 |
The Following User Says Thank You to binadam23 For This Useful Post: |
11-13-2015, 16:55 | #5659 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia 1101 Direct Unlock done... Today.. yahoooooooo... Code: Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... MCU: V 3.05 15-05-05 RH-75 (c) NMP IMEI: 355698006552543 Product Serial Number: PGJ023496 Product Code : 0528604 Module Code : 0202683 Basic Production Code: 0522644 PPM SW Version : V 3.05 15-05-05 RH-75 (c) NMP AE MCU SW Version : V 3.05 15-05-05 RH-75 (c) NMP HW Version : 0501 PCI Version : B UEM Version : 1092 UPP Version : 8705 RFIC Version : 0300 DSP Version : PEU2.14-@ LCD Version : PHILIPS 2 3 ********** SIMLOCK INFO ********** CONFIG_DATA : 2720300000000000 PROFILE_BITS : 0000000000000002 ASIC : 2 PROVIDER : Meteor Mobile Communications Ltd. ;Ireland [GSM] Block [1] 1:Close ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED MASTER_CODE : 5201720014 PHONE_MODE : LOCAL Generating Simlock Table... Uploading Default Simlock Table... OK: Simlock Table Accepted MCU: V 3.05 15-05-05 RH-75 (c) NMP IMEI: 355698006552543 Product Serial Number: PGJ023496 Product Code : 0528604 Module Code : 0202683 Basic Production Code: 0522644 PPM SW Version : V 3.05 15-05-05 RH-75 (c) NMP AE MCU SW Version : V 3.05 15-05-05 RH-75 (c) NMP HW Version : 0501 PCI Version : @ UEM Version : 1092 UPP Version : 8705 RFIC Version : 0300 DSP Version : PEU2.14-@ LCD Version : PHILIPS 2 3 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000000002 ASIC : 2 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED MASTER_CODE : 5201720014 PHONE_MODE : LOCAL Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
The Following User Says Thank You to razib143 For This Useful Post: |
11-16-2015, 14:21 | #5664 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia 1661 Unlock done.. Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... MCU: V 04.30 06-07-09 RH-122 (c) Nokia IMEI: 358233038070160 Product Serial Number: HMF214995 Product Code : 0586442 Module Code : 0204019 Basic Production Code: 0591753 PPM SW Version : V 04.30 06-07-09 RH-122 (c) Nokia AE ADSP Version : p V 04.30\n06-07-09\nRH-122\n(c) NMP\nae MCU SW Version : V 04.30 06-07-09 RH-122 (c) Nokia HW Version : 1003 UEM Version : 1328 UPP Version : 8851 RFIC Version : 0700 DSP Version : ICPR81_09w17_U LCD Version : SDI:BOHAIv92 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 2340000100000000 PROFILE_BITS : 8000000000030002 ASIC : 11 PROVIDER : British Telecom;UK [GSM] Block [1] 1:Close 2:Close ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : ÿ MASTER_CODE : 2727206025 PHONE_MODE : LOCAL MCU: V 04.30 06-07-09 RH-122 (c) Nokia IMEI: 358233038070160 Product Serial Number: HMF214995 Product Code : 0586442 Module Code : 0204019 Basic Production Code: 0591753 PPM SW Version : V 04.30 06-07-09 RH-122 (c) Nokia AE ADSP Version : p V 04.30\n06-07-09\nRH-122\n(c) NMP\nae MCU SW Version : V 04.30 06-07-09 RH-122 (c) Nokia HW Version : 1003 UEM Version : 1328 UPP Version : 8851 RFIC Version : 0700 DSP Version : ICPR81_09w17_U LCD Version : SDI:BOHAIv92 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100100000000 PROFILE_BITS : 000000000003000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : ÿ MASTER_CODE : 2727206025 PHONE_MODE : LOCAL |
11-19-2015, 18:06 | #5670 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia 6111 Unlock done.. :D Code: in the "PRODUCT PATH TO SCAN" List... MCU: V 03.77 23-05-06 RM-82 (c) NMP. IMEI: 353657011877594 Model : Nokia 6111 Product Serial Number: MEH957823 Product Code : 0541482 Module Code : 0202648 Basic Production Code: 0520794 PPM SW Version : V 03.77 23-05-06 RM-82 (c) NMP. C ADSP Version : p TIKU_PB_05w21_06_w12 MCU SW Version : V 03.77 23-05-06 RM-82 (c) NMP. HW Version : 4008 UEM Version : 400 UPP Version : 8273 RFIC Version : p 10ff11ff0205 DSP Version : p P05w19.v15 LCD Version : SUEZ Content Pack Version : Content: c V 03.77 23-05-06 RM-82 (c) NMP. ********** SIMLOCK INFO ********** CONFIG_DATA : 2341500000000000 PROFILE_BITS : 8000000000000006 ASIC : 6 PROVIDER : Vodafone Ltd;UK [GSM] Block [1] 1:Close ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 1317102172 PHONE_MODE : LOCAL Generating Simlock Table... Uploading Default Simlock Table... OK: Simlock Table Accepted |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
