12-22-2015, 10:49 | #5701 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | nokia 1280 white screen done after reset with atf box |
The Following User Says Thank You to naveedsialkoti For This Useful Post: |
12-23-2015, 07:03 | #5704 (permalink) |
Freak Poster Join Date: Oct 2015 Location: eArTh
Member: 2470191 Status: Offline Sonork: 100.1652036 Thanks Meter: 308 | Where Is Atf Team.... WHERE IS ATF support team no update for long time We need update, product LIKE NOKIA 108,TO 225 sir, please update update PLZZZZ where ATF team.!!!!! |
The Following User Says Thank You to rsa7262 For This Useful Post: |
12-23-2015, 09:51 | #5705 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 105 flash Code: Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted after 2 attempts... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: D:\NOKIA\RM-908\rm908_02.700 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\NOKIA\RM-908\rm908_02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\NOKIA\RM-908\rm908_nai02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:54 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.70 22-02-13 RM-908 (c) Nokia IMEI: 359176055194877 Product Serial Number: 388869FBH Product Code : 059R449 Module Code : 0205453 Basic Production Code: 059T865 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia IJ ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nij MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BEIHAIv82 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
The Following User Says Thank You to maanarman For This Useful Post: |
12-23-2015, 09:51 | #5706 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 101 flash Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: D:\NOKIA\RM-769\rm769_006.650 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: D598 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 047E Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\NOKIA\RM-769\rm769_006.65ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00100000~0x005C677E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5007232 bytes Data Checksum: 357F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\NOKIA\RM-769\rm7690_nai06.65ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00E60000~0x00F121BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 729536 bytes Data Checksum: 3DFE Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:08 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.65 07-11-11 RM-769 (c) Nokia IMEI: 359070042039206 Product Serial Number: 4966A83AH Product Code : 059G7N6 Module Code : 0204883 Basic Production Code: 059F6L6 PPM SW Version : V 06.65 07-11-11 RM-769 (c) Nokia IJ ADSP Version : p V 06.65\n07-11-11\nRM-769\n(c) NMP\nij MCU SW Version : V 06.65 07-11-11 RM-769 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BOHAIv94 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
12-27-2015, 10:54 | #5709 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Nokia 105 flash Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted after 2 attempts... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: D:\NOKIA\RM-908\rm908_02.700 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 02 of 03 IMAGE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Processing Section 03 of 03 IMAGE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\NOKIA\RM-908\rm908_02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: D:\NOKIA\RM-908\rm908_nai02.70ij Data Block Found... Number of Sections: 01 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 01 IMAGE Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... IMAGE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:53 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 02.70 22-02-13 RM-908 (c) Nokia IMEI: 358146058036962 Product Serial Number: 20251EABH Product Code : 059R449 Module Code : 0205453 Basic Production Code: 059Q858 PPM SW Version : V 02.70 22-02-13 RM-908 (c) Nokia IJ ADSP Version : p V 02.70\n22-02-13\nRM-908\n(c) NMP\nij MCU SW Version : V 02.70 22-02-13 RM-908 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BEIHAIv82 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
12-27-2015, 17:59 | #5710 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | nokia 206 read code Code: Booting Phone via USB... ====================================================== ====================================================== USB Phone BUSCheck Boot ====================================================== ====================================================== Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12401C0D0E11282F Original Product Code: 059R6D9 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356703059384387\356703059384387_75528.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356703059384387\356703059384387_CERTIFICATE_47A76517.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356703059384387\356703059384387_PMM_PROT_623C5FB5.bin Security Code: 330099 Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... |
12-31-2015, 14:07 | #5714 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Nokia 6303_RM-443 Logo Pw Off Flash Successfully,Done,Time 07:46" .:: BY ::. ..::: Advance-Box :::.. Code: Number of Image Files: 3 Processing Image File : rm443__10.12.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1597 Entry Point: 0x5050 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm443__10.12.ppm_i CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 429 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm443__10.12.image_i_matt_black CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 640 Entry Point: 0x00C8 Page Format : -1 MAX PAGE : 0x00004000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13400101 ID DWORD 1 : 9E397F56 ID DWORD 2 : DAB277F4 ID DWORD 3 : EF717664 ID DWORD 4 : A73D5B0E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F ADL_SERVER: PROCESSING rm443__10.12.mcusw ADL_SERVER: ROOT_KEY_HASH MATCH FOUND ADL_SERVER: PROCESSING rm443__10.12.mcusw ADL_SERVER: CMT CERTIFICATE BLOCK FOUND ADL_SERVER: CMT DATA BLOCKS FOUND ADL_SERVER: CONSOLIDATING CMT BLOCKS ADL_SERVER: PASUBTOC BLOCK FOUND BB5 ADL Loader Start Up... (Please Wait...) Found Nokia BB5 ADL Loader USB Generic... ======================================================= Processing : rm443__10.12.mcusw ======================================================= Erase Block Found >> Erasing area 0x00000000 - 0x0001FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00040000 - 0x0005FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00060000 - 0x0007FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00080000 - 0x0015FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00160000 - 0x0023FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x01740000 - 0x0191FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00240000 - 0x0173FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x022E0000 - 0x0261FFFF, Type: NOR , Subsystem: CMT Erase Complete : No Error - 0 (0x00) Data Block Found : 1597 Blocks >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2] >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : ISA+DYNSW Continue Flash Complete : No Error - 0 (0x00) ======================================================= Processing : rm443__10.12.ppm_i ======================================================= Erase Block Found >> Erasing area 0x01920000 - 0x022DFFFF, Type: NOR , Subsystem: CMT Erase Complete : No Error - 0 (0x00) Data Block Found : 429 Blocks Continue Flash Complete : No Error - 0 (0x00) ======================================================= Processing : rm443__10.12.image_i_matt_black ======================================================= Erase Block Found >> Erasing area 0x02620000 - 0x029BFFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x029C0000 - 0x03FBFFFF, Type: NOR , Subsystem: CMT Erase Complete : No Error - 0 (0x00) Data Block Found : 640 Blocks Continue Flash Complete : No Error - 0 (0x00) Flashing Done... Total Flashing Time (Erase + Flashing) : 00:07:46 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 10.12 08-04-10 RM-443 (c) Nokia IMEI: 353199036533662 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 00786 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
The Following 3 Users Say Thank You to kabul For This Useful Post: |
12-31-2015, 14:21 | #5715 (permalink) |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Nokia Lumia 535_RM-1090 Touch Not Working Problem Flash Successfully,Time 07:28" .:: BY ::. ..::: Advance-Box :::.. Code:
The Following 5 Users Say Thank You to kabul For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
