03-14-2012, 21:56 | #2206 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Somewhere in Spacetime Age: 48
Member: 168364 Status: Offline Thanks Meter: 174 | Quote:
Just watch them every 1-2 hours. If You fall asleep, that's Your additional wastage. I suggest You to make multiple command lines for both PC. When one bf finishes, the next is starting and so on. You have to watch that which is the first and press "q" on the other. If I were You then I would calculate only 1 bf on each PC without splitting. PC 1 must finish within 37 hours, the PC 2 must finish within 45 hours. That's 2 BF 100% within 2 days. It's better not to hurry. BF is for patient customers. I bundled off my impatient ones. (And the chaeap-jacks) B R | |
03-14-2012, 23:45 | #2207 (permalink) | |
Freak Poster Join Date: Jan 2004
Member: 48396 Status: Offline Thanks Meter: 82 | Quote:
Code: Lock Type 15-digit NCK Level 1 [MNC+MCC ] #pw+394609328040010+1# Level 2 [GID1 ] #pw+150229974828606+2# Level 3 [GID2 ] #pw+598776349153686+3# Level 4 [MSIN ] #pw+565469061187256+4# Level 5 [MNC+MCC+GID1 ] #pw+859975119583077+5# Level 6 [MNC+MCC+GID1+GID2] #pw+680044828790737+6# Level 7 [ALL SIMLOCK(s) ] #pw+922399131214629+7# | |
The Following User Says Thank You to UnReality For This Useful Post: |
03-15-2012, 15:38 | #2208 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: Africa
Member: 8843 Status: Offline Thanks Meter: 117 | Quote:
also which mobo are u using for the three 7970? and whats the calculation speed? | |
The Following User Says Thank You to datalife2000 For This Useful Post: |
03-16-2012, 21:20 | #2209 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 711274 Status: Offline Thanks Meter: 7 | Im have one question? If one pc with 4 x 6670 (1920 Stream processors) delayed 248 hours in decode only one. If one pc with 4 x 6970 (6144 Stream processors) delayed 77 hours in decode only one. If one pc with 4 x 7870 (8192 Stream processors) delayed 55.12 hours in decode only one. this is correct? |
03-17-2012, 15:19 | #2211 (permalink) | |
Freak Poster Join Date: May 2003
Member: 28760 Status: Offline Thanks Meter: 4 | Quote:
7870 have 1280 streams | |
03-17-2012, 17:14 | #2213 (permalink) |
Freak Poster Join Date: May 2008 Location: Durres, Albania
Member: 772321 Status: Offline Sonork: Edi Thanks Meter: 46 | hello to all, halp me for this NOKIA C3 is read by ATF logos, cmt id 000000000065589FA78BE474779BFCD7DA2FE7EF8 CMT HASH 1B0D74C532CA1C6133940C740E8C786E IMEI 356247041499598 |
03-18-2012, 10:12 | #2214 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | Quote:
3x6970 =6340Mh/s = 44hr for 100% scan | |
03-18-2012, 10:24 | #2215 (permalink) | |
The Following User Says Thank You to irfaN_vu For This Useful Post: |
03-18-2012, 14:08 | #2216 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | ? What knowledge you need? simply run software from same shared directory and if result file will be created hashcat will terminate job on other pc's. So: 1 PC have file imei_1.bat 2 PC have file imei_2.bat Both bat files create same out.txt and if one pc found result and created out.txt second one in 60 sec will terminate. B.R. Alkapone |
The Following 5 Users Say Thank You to Alkapone For This Useful Post: |
03-18-2012, 17:23 | #2217 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Moro
Member: 918056 Status: Offline Sonork: 1636876 Thanks Meter: 70 | hi any one test ati hd5970 with this component I buy 3 pieces of this component in May not worked any one when i power the machine there appears nothing in the screen only one bip Last edited by ORACHI; 03-18-2012 at 17:33. |
03-18-2012, 23:29 | #2218 (permalink) |
Member: 711274 Status: Offline Thanks Meter: 7 | See this HD 7970 At 1000 mhz 3150 m/s / 3220 m/s At 1125 mhz 3340 m/s / 3430 m/s See overclock in this CARD 1680 MHZ GPU / 1900 MHZ MEMORY AT 1680 4100 m/s / 4270 m/s Last edited by Hatman23; 03-18-2012 at 23:35. |
03-20-2012, 17:35 | #2219 (permalink) | |
03-20-2012, 17:44 | #2220 (permalink) |
Member: 19265 Status: Offline Thanks Meter: 92 | he he he! my linux nodes runs like this for a YEAR already ... Hashcat controls this process by itself. If you don't have enough brain to understand, take already calculated file, put it into same dir as cat and run calculation of that file again. In max 60 sec you will get Cracked status. B.R. Alkapone |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
